Old 05-21-2015, 09:23 PM   #1
Astroboy
Astroboy's Avatar
Drives: None
Is installing an oil cooler dificult?
So I recently ordered an Avo oil cooler with the thermostat for my car and I was wondering how long it takes to install one and if it's difficult to install or not?
Astroboy is offline   Reply With Quote
Old 05-22-2015, 01:01 PM   #2
Juggles
Drives: 2013 FRS
I installed my first oil cooler recently. Is it difficult? No. How long it takes will really depend on how familiar with your car you are. I had never removed my front bumper up to that point... but now that Ive done it a couple times I can have that thing on/off in a flash.
All in all you will most likely spend a couple hours start to finish.
Pro tip: Make sure you torque everything down properly. Make sure your fittings are on straight and do not over torque em, as you can misalign things causing yourself leaks.
A zen master once told me "Do the opposite of everything I say", so I didn't.
Juggles is offline   Reply With Quote
Old 05-22-2015, 01:07 PM   #3
malave7567
malave7567's Avatar
Drives: (formerly) 2013 Raven FR-S
Haven't done it to this car in particular, but to add the great suggestions Juggles already said, be sure to check all the lines after you start the car for any leaks. Then drive around the block a bit without your front bumper cover, pull back into the driveway/garage, and re-check all your lines before re-installing your front bumper cover.
malave7567 is offline   Reply With Quote
Old 05-22-2015, 02:43 PM   #4
themajesticone
themajesticone's Avatar
Drives: '13 UM86
Not really - just time consuming. It is difficult if you don't have the proper tools.
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 05-22-2015, 03:16 PM   #5
DarkSunrise
DarkSunrise's Avatar
I did my Perrin last week. The hardest part was removing the front bumper and finding a 27mm socket thin enough to tighten the oil filter bolt. Other than that, it was just time-consuming, but not too hard.
2022 BRZ Build
2013 FR-S Build
Old 05-22-2015, 03:36 PM   #6
Xuningshen
Drives: Subaru BRZ
dunno how the avo kit looks but make sure the lines aren't rubbing up against anything sharp. after the initial install, test drive, and then recheck i would wait a few weeks to a month and then recheck everything again.
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
Old 05-23-2015, 03:21 PM   #7
Astroboy
Astroboy's Avatar
Drives: None
Would it be best that I use new oil for the install, or is the current oil ok
Old 05-23-2015, 04:29 PM   #8
jflogerzi
jflogerzi's Avatar
Its not hard, just make sure the fittings are super tight. I did mine and it leaked out of several. Other then that its pretty easy. If you never taken the front bumper off, that can be a PITA
Old 05-23-2015, 04:52 PM   #9
Astroboy
Astroboy's Avatar
Drives: None
Would I need to put in new oil beforehand?
Old 05-23-2015, 04:53 PM   #10
jflogerzi
jflogerzi's Avatar
I would do a fresh change. So empty old oil. Install cooler and then fill with fresh oil
2013 Series 10 FRS #553
Installing Resonator? l0aded Engine, Exhaust, Transmission 36 07-14-2022 10:06 PM
Need help installing some coils tysoNgwaNg Northern California 14 03-24-2014 08:20 PM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
Installing a hood for the fr-s? Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 11 08-16-2013 11:06 AM
need help installing this chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 6 07-14-2013 01:17 PM
