Old 05-20-2015, 02:04 PM   #1
philooo
Drives: 13' Scion FRS Track car
Camber plate recommandation : RaceSeng Vs Ground Control
I have narrowed down my camber plate choice between RaceSeng and Ground Control
I see tons of feedback on the Raceseng, but can anybody with the Ground Control plate chime in on their experience ?
This will be for a full gutted track car with Tarmac2's
philooo is offline   Reply With Quote
Old 05-20-2015, 02:06 PM   #2
puma
crew chief
puma's Avatar
Drives: Race car FR-S
check my build i have this exact setup, GC camber plate with their stress bar and Tarmac2, really love it, only thing i changed is the bolts on the stress bar because i hated the allen key and it was a weird size i didn't have in my tool box, installed regular graded bolts but otherwise really nice product. ight not be as fancy looking as the raceseng though.
puma is offline   Reply With Quote
Old 05-20-2015, 02:07 PM   #3
CSG David
CSG David's Avatar
They do exactly the same job and both are good quality. Raceseng has control over the caster adjustment. Raceseng's customer service and manufacturing quality is top notch. There's a reason behind every product manufacturer we support.
The Following User Says Thank You to CSG David For This Useful Post:
ZionsWrath (05-20-2015)
Old 06-07-2015, 09:26 PM   #4
Alan
Alan's Avatar
Drives: 2013 SWP BRZ Ltd. / E60 M5
I know this thread is a little old, but I figured I'd throw in my .02 as I had the same question as I put things together on my car.
Thanks to strong recommendations from @CSG Mike and my local shop, I ended up going with the Racesengs and have been very happy. While I can't comment on durability as I have only had the car on the track for three days since install, there is no noise from the plates, no movement in the adjustment once set and no other issues I or my shop have identified. They sure do look pretty as well!
I'll add a big thanks to CounterSpace Garage again as they have given me excellent advice every step of the way.
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
Alan is offline   Reply With Quote
The Following User Says Thank You to Alan For This Useful Post:
CSG Mike (06-08-2015)
Ground Control Camber Plates and Eibach R2 ReThink Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 04-20-2014 10:54 PM
Testing Waters: FS KWV3s with Ground control camber plates and robispec rear mounts YDNA Brakes, Suspension, Chassis 0 01-25-2014 03:34 AM
Raceseng | CasCam - Caster + Camber Plate Black Friday Sale Raceseng Brakes, Suspension, Chassis 0 11-30-2013 12:09 PM
Ground Control for 86/FRS/BRZ phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 11-14-2012 08:56 PM
Ground Control needs your Help GC_Adam Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 11-13-2012 06:08 PM
