Old 05-16-2015, 06:31 PM   #15
Aozora.BRZ
Aozora.BRZ's Avatar
Drives: '15 WRB Series.Blue
While it may not be malfunctioning, judging by the different responses there may be some way to adjust it to lower the force needed for closing the door.
Aozora.BRZ is offline   Reply With Quote
Old 05-16-2015, 06:34 PM   #16
Agent 86
Drives: 2017 Cayman S
2014 and mine often doesn't catch when closing. It often requires a bit of force to close the trunk.
Funny thing is, if I close it by pushing it down from the driver's side it works the first time almost every time. From the center or passenger's side, more force is required.
Pushing the interior trunk release and it only pops the trunk. I don't mind that, though.
… and loving it! Maxwell Smart
Gone but not forgotten
2014 BRZ Limited - 2013 VW Golf R - 2010 Forester XT - 2006 Mazda 3 GT
Agent 86 is offline   Reply With Quote
Old 05-16-2015, 07:04 PM   #17
alan.chalkley
Drives: 4wd zooks
When mine was new i had to slam the trunk down to make it close.
After two years use it now closes easily.
I think the trunk sealing rubber just compresses down a little with age and then the trunk will close easily.
This is common on any new car.
alan.chalkley is offline   Reply With Quote
Old 05-16-2015, 07:38 PM   #18
If it's being forced closed so much the rubber collapses, then yes. The rubbery parts will last much longer if they aren't mashed down. The latch also sees less force/drag when it is opened.
The trunk lid on my wife's 03 Camry is the same as it was when new.
Granted, there's probably a wide zone of "good enough" but if you have to slam it then, yeah, it's probably too tight.
Old 05-16-2015, 07:40 PM   #19
Choco
Embarrassed Doge
Choco's Avatar
Drives: Shibaru BRZ
Sounds normal to me.
The Following 2 Users Say Thank You to Choco For This Useful Post:
Tcoat (05-17-2015), Ultramaroon (05-16-2015)
Old 05-17-2015, 10:56 PM   #20
immortal_suby
Drives: 2015 BRZ Limited 6MT
My 2013 would close just by letting go of it. My 2015 I have to slam it to get it to close. Neither of them do anything more than pop up a little when opening them with the button.
2015 BRZ , 1992 SVX LSL, 2019 ASCENT
immortal_suby is offline   Reply With Quote
Old 05-18-2015, 05:14 AM   #21
miosaki
miosaki's Avatar
Drives: 2015 CWP BRZ
My roomie drives a twin and she noticed the same thing as well.
We decided to take it to our respective dealers and see what they say.
The Scion dealership said that you just have to be 'firm' about closing the trunk. (whatever that means)
The Subaru dealership said that they've received multiple comment regarding the trunk not closing fully so they're "looking into it".
In the meantime we'll all just have to slam our trunks down. :/
miosaki is offline   Reply With Quote
Old 05-18-2015, 08:46 PM   #22
Aozora.BRZ
Aozora.BRZ's Avatar
I took a quick video. First attempt I just let the door drop down on its own weight. Then 2/3rd are with a normal push equivalent to what is needed for closing the side doors. For the final one I used more force and had to push all the way down.
If you want to close it down without pushing all the way through, you almost have to slam it so there is enough force to counter the resistance of the rubber or the spring loaded lever.
[ame]http://www.youtube.com/watch?v=xxdAravelVg[/ame]
You may say the answer is to not close it like a pansy, but the force needed is so out of line vs closing the side doors or other car trunks that it just takes a while getting used to.
Old 05-18-2015, 09:04 PM   #23
I just let mine go on it's own weight like your first try and it latches every single time.
Old 05-18-2015, 09:14 PM   #24
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Are you guys comparing a properly hinged gas struts equipped trunk lid to a cheap sedan trunk that just swings wide open?
krayzie is offline   Reply With Quote
The Following User Says Thank You to krayzie For This Useful Post:
Choco (05-29-2015)
Old 05-18-2015, 09:41 PM   #25
Outlawstar98
SLOW BRZ
Outlawstar98's Avatar
Drives: 2013 328i xDrive; 2013 BRZ
Mine closes with no issues. But I know the issue you speak of, I detailed a BRZ last weekend and the trunk was like this.
Outlawstar98 is offline   Reply With Quote
trunk opening
Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? 07stealth350z DIY (Do-It-Yourself) Guides 8 08-27-2020 04:27 PM
WTT: Satin White Pearl BRZ Limited Trunk with Spoiler for Wingless Trunk R0ME0 Exterior Parts (Aero, Lighting, Etc.) 3 01-07-2014 10:36 PM
Zeta & Carsmo Armrest, Weathertech front and trunk mats, OEM scion trunk carpet HighbreadEH3 Interior Parts (Incl. Lighting) 16 07-29-2013 11:42 AM
Trade my Crystal Black Silica BRZ limited trunk (w/ wing) for wingless trunk (SF Bay) Iamthebatman Exterior Parts (Aero, Lighting, Etc.) 2 07-18-2013 03:12 PM
