#113 |
Senior Misanthrope
| The Following User Says Thank You to kch For This Useful Post: | 8R6 (05-15-2015) |
#114 | |
Drives: 14 Ultramarine FR-S
Check this ridiculous thread out... http://forums.officer.com/t73003/
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD ![]() |
#115 | |
Road-hole
Drives: 2013 Whiteout FR-S
if that is the case...
This will likely end up going to the supreme court as well as the cases of right to search. That is a semantic distinction, it is still searching the car and as has been stated, you have the fifth amendment right not to incriminate yourself and the fourth amendment right to be secure in your person and effects. Your car has already been ruled by the supreme court to be considered effects. Jaden |
#116 | |
"First off, your 4th Amendment rights are not in question here. When a cop looks under your hood, it's an inspection....not a search. Since it's not a search, a warrant is a moot point. That's how you have diesel inspection stations. If you fail to comply with the inspection, you can be arrested and go to jail. Your car then goes to car jail". Regardless its probably better to comply with the officer, I haven't seen anyone try to say no to vehicle inspection. It would be an interesting experiment, if you have the balls go for it lol. If you take a look at that thread I posted, those are officers posting that crap.
| The Following User Says Thank You to Phantobe For This Useful Post: | Toyarzee (05-15-2015) |
#117 | |
Road-hole
oh I have the balls.
Jaden p.s. and I don't do illegal mods to my car, it's not about that. It's about the continuous usurpation of authority that they don't have. |
| The Following User Says Thank You to Jaden For This Useful Post: | Phantobe (05-15-2015) |
#118 | |
Shibby!
Drives: '14 White FR-S, '01 turbo mini taco
"Just as an FYI I profile your POS rice rocket and YES I would have you pop the hood. It is not a search in MD to have you pop the hood. I am allowed by MD law once I have my PC for a stop to conduct a FULL vehicle inspection on the side of the road to include driving it for a breif distance if I so choose to. However thats a bit much. Poping the hood looking for the turbo or the NOS tubes is plenty enough for me.* If you refuse? Then you get to go to jail for failure to obay a lawful order and I yank you through the vent window, you go to jail, and I impound your car......after I inspect it." A stock evo... and he's told by cops if you don't like it, sell your car. Wtf? They can't say give me your keys I wanna take it for a spin.. at that point I for sure would fail to comply. |
#119 |
Shibby!
Another assumption of police officers according to that forum is apparently that, the ONLY reason someone modifies a car is to street race. Da fuk?
#120 | |
Drives: FRS
#121 | |
Road-hole
He drives a stock car....
How does that make him an immature idiot??? Now mind you, I only read the op and the first couple of posts so he may become an idiot in later posts... Jaden |
#122 | |
Drives: FRS
#123 |
Road-hole
Here you go they cited the actual code in that thread...
2804. A member of the California Highway Patrol upon reasonable
belief that any vehicle is being operated in violation of any provisions of this code or is in such unsafe condition as to endanger any person, may require the driver of the vehicle to stop and submit to an inspection of the vehicle, and its equipment, license plates, and registration card. 2806. Any regularly employed and salaried police officer or deputy sheriff, or any reserve police officer or reserve deputy sheriff listed in Section 830.6 of the Penal Code, having reasonable cause to believe that any vehicle or combination of vehicles is not equipped as required by this code or is in any unsafe condition as to endanger any person, may require the driver to stop and submit the vehicle or combination of vehicles to an inspection and those tests as may be appropriate to determine the safety to persons and compliance with the code. Yep, not at the whim of the officer... They need to have resaonable suspicion that the vehicle is not in compliance. This should require NO ACTION on the part of the person being pulled over. If they have reasonable suspicion to conduct an inspection, they can conduct an inspection. If they ask me to pop the hood, I would say "Officer, I do not consent to an inspection, if you have reasonable suspicion to believe that I am not in compliance, then you should not need my consent, but know that I will file a complaint after you find nothing not in compliance and may file a lawsuit against you, your department and the county or state as is applicable for which you will have to provide evidence for your reasonable suspicion per VC 2804 and 2806". Jaden p.s. The officers KNOW this. The officer that inspected my vehicle asked me to TURN my steering wheel to the other direction so that he could hear my exhaust when I turned the engine on. He knew he couldn't request that I turn my engine on and rev it for him because he had no reasonable suspicion. The only reason he could ask me to turn my wheels is that my tires were a little too worn on the inside because of camber so he had reasonable suspicion to inspect the tires. None of this changes the fact that it is ridiculous that an officer can arbitrarily decide to write you up for a violation that isn't a violation based on nothing but his whim and in the case of 27150A, as it stands that is exactly what happens. p.p.s I can't even read any more in that thread, some of those officers attitudes is what gives police bad names. I mean one posted that an officer can't know that you don't have a weapon unless he pats you down...duh...he's not supposed to know whether you have a weapon and he's not supposed to search you unless he has reasonable suspicion that not only that you have a weapon, but that the having a weapon is in violation of law. Even seeing a gun in your belt is not justification for a search as he has no reasonable suspicion that the possession of the gun is in violation of law. This is exactly what I'm talking about. So many people have consented to so many violations of their liberties that both citizens and officers don't know what is legitimate and not any more. Last edited by Jaden; 05-15-2015 at 02:37 PM. |
#124 |
@Jaden
I think an aftermarket catback exhaust which most people run, is enough probable cause to have an officer want to pop your hood. Sad to say street racing has ruined the scene & you can see from that thread how vain officers can be. They pretty much orient car modding with street racing, granted the thread is over 7 years old I doubt much has changed.
| The Following User Says Thank You to Phantobe For This Useful Post: | 8R6 (05-15-2015) |
#125 | |
Senior Misanthrope
It's great that you value your personal liberties so highly. I mean it. You seem passionate about it and I can tell you've done some research. However, you won't be successful suing the state/city/county every time you get pulled over and inspected. That's a bullshit suit. You know it, the cop knows it, the judge will know it. In fact, any attorney you approach for the suit will also know it and will turn you down. The reality is this: the standard for when an officer can ask you to pop your hood is intentionally vague to give the police more leeway. "Reasonable suspicion" isn't some imaginary video game stat that increases +2 for each obvious mod, so that the officer can only inspect you when you get to +10. All a police officer needs is a plausible reason to think you're modded (and heck, he can even be flat-out wrong like with the Evo owner in the above linked thread). So basically, if you complain to the police department, all that will happen (if anything) is that the officer will say you looked non-stock and were driving aggressively or something. They can come up with a reason that meets the "reasonable suspicion" standard. Also, when the officer "asks" you to pop your hood, it's not because they're trying to trick you into consenting to a search (at least in this case). It's because it's safer for them than pulling you out of the car and popping it themselves, or reaching into your car while you're still in it. That's seriously not safe. Also note that I'm not saying this is right or appropriate. It's just the way things work at the moment. |
#126 | |
Drives: FRS
| quiet and loud exhaust both in 1 | JonMotoring | Engine, Exhaust, Transmission | 28 | 04-24-2020 03:22 PM |
| Loud exhaust / Buddy Club Spec II exhaust help! | chiefshayan | Engine, Exhaust, Transmission | 26 | 12-06-2019 06:59 PM |
| How loud is the n1 exhaust? ( in db) | jon2 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-22-2015 04:04 AM |
| My exhaust is loud | mike2100 | Mid-Atlantic | 1 | 08-25-2013 10:13 PM |
| Looking for a loud exhaust | Itssrayyxd | Engine, Exhaust, Transmission | 66 | 04-01-2013 04:53 PM |
