#15 |
LOL join the group! There seems to be a few. I find it funny because we are 3 years into these cars and we are still not sure about some basic things like safe drop heights. My previous research was pretty clear that TRD springs did not require any additional changes when running the stock wheels and tires. It did however get a little gray if changing tire sizes.
| The Following User Says Thank You to Tcoat For This Useful Post: | pinski (05-13-2015) |
#16 | ||
Drives: BRZ Limited
You do however at least want an alignment to make sure your toe is good after any change. Each car ends up with different specs after dropping, so you can't really assume your specs are the same as someone elses on the same springs unless you get it aligned. |
| The Following User Says Thank You to TheVoiceOfReason For This Useful Post: | pinski (05-13-2015) |
#17 |
Drives: 2013 FR-S M/T Ultramarine
Just a rule of thumb for any vehicle. Anytime you lift or lower a vehicle get an alignment done. You'd be surprised how far off your toe can get from such a small drop.
2013 Ultramarine 6MT- Feal 441 coils, Whiteline 20mm front/18mm rear swaybars.
RPF1 17x9 +35. 245/40/17 RS-3 V2. OFH, Invidia OP, Spencer Fab HFC FP, Invidia N1 C38 JRSC, JROC, Delicious Tune, Radium PCV Catch Can |
#18 | |
They did align mine after installing the springs (it was months before I bought it) and the records showed that it was done. What they didn't have was the sheet saying exactly what the numbers were after the alignment and this is what I am curious about. Not to mention that after driving on the snows for 4 months and through the winter conditions I would like to verify that I am indeed in as good position as it appears to be.
#19 | |
![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | chaoskaze (05-13-2015) |
#20 | |
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#21 |
No Money, No Problems
Instead of lowering it, you can do what I did and put on 18x8.5 wheels to fill out the gap a bit more. I live in a town with some awful roads so I didn't want to lower it.
Pics in my sig. |
#22 | |
Loading...████████] 99%
Drives: #0517
W/ the toe straightened out (at minimum, made equal on both sides), the car feels tighter going in a straight line. And w/ the added camber up front, grip feels improved in corner. Definitely worth it, imo. |
#23 |
Drives: FR-S,GTI
I have the Eibach Pro Kit with 235/45/17 Conti's. It's not that low but this urethane bumper-bumper thing has saved my front end many times. I got it on ebay for like 79 bucks. Probably my most practical mod to date. Note what the bottom looks like.
| Anyone with a Carbon Fiber Fender? (The whole Fender) | Stayreal | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 03-13-2014 04:55 PM |
| Stock Fender or C-WEST Fender? | Stayreal | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 03-12-2014 08:06 AM |
| TRADE: FT86 Fender Vent for BRZ Fender Vent | xia | Exterior Parts (Aero, Lighting, Etc.) | 0 | 10-04-2013 10:56 PM |
| Want to trade my white Frs fender vents for Brz fender vents | White0utFrs | Exterior Parts (Aero, Lighting, Etc.) | 0 | 09-23-2013 04:17 AM |
| TRADE: brz fender for fr-s fender | dun3 | Exterior Parts (Aero, Lighting, Etc.) | 1 | 07-04-2013 11:06 PM |
