Old 01-31-2015, 07:32 PM   #379
skye67
skye67's Avatar
Drives: 2013 black AT, OFT, 4.65
Finally, got around to installing my diff I got off ebay with the 4.67weir gear set. As a note, if you have a Perrin exhaust be prepared for one of the clamps to get mess up on you and have extras on hand.
Now I have a auto tranny and drive in sport mode most of time. I also have OFH and OFT. The car goes through the gears much faster now, hitting red line fast. Turning on to the main road, the inside tire even chirped a little. And that was only with about a half throttle. The car feel locked in to the gears more, down shifting very aggressively. Yes, There was a bit of noise from the gear set but nothing that was to concerning. Getting on and off the throttle you could hear the change in pitch, but there was a smooth transition in the sound indicating the gear set was set up pretty good. Anyone looking for more performance out of the car this is a definite must do! In fact I'm already thinking of a new set of gears and limited slip for my spare differential. Oh, and thank you for Dustin for the fantastic write up on how to remove the diff without removing the axles.
Living the dream in a nightmare.
skye67 is offline   Reply With Quote
The Following 2 Users Say Thank You to skye67 For This Useful Post:
Captain Insano (02-14-2015), Lonewolf (02-01-2015)
Old 02-14-2015, 10:38 AM   #380
Captain Insano
Thanks for the review, glad to hear it went well and you are liking it. I am thinking 4.88 on the AT. Would be slightly even more aggressive.
Captain Insano is offline   Reply With Quote
Old 02-14-2015, 11:22 AM   #381
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I have the AT and 4.88s and love them.
Lunatic is offline   Reply With Quote
Old 03-26-2015, 10:09 AM   #382
emirdtm
Drives: Toyobaru
Any videos with the gears?
emirdtm is offline   Reply With Quote
Old 03-26-2015, 11:14 AM   #383
mrk1
Drives: Sterling BRZ Ltd
My 4.44 just came in from MFactory, cant wait to install it. My car is boosted so I didn't want to go real aggressive. The slogan on the side of the box is "The Replacement for Displacement" I got a kick out of that.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 04-06-2015, 08:00 AM   #384
PauloGavr
Drives: Subaru BRZ
Cusco 4.55 kit
Hi everyone! Could you please advice me about that "shims" not included in cusco kit (It tells you all the shims you will need in order to shim the final drive tolerance. I bought all 22 because each car will be different. We only use 1 so that means you will have 21 left over.)
What kind of shims are needed exactly with stock diff?
PauloGavr is offline   Reply With Quote
Old 04-07-2015, 12:19 AM   #385
kodyo
Drives: Scion FR-S
Stock diff has two sets of shims. One set look like thin flat washers and multiple shims can be stacked to adjust the depth of the pinion gear in and out of the diff. The second set are two thick shims that adjust the differential/ring gear backlash (side to side). The total thickness of these two shims remain constant. So if you take .002 off one, you add it to the other. So if you are modding your stock diff, you can use a mic to measure what you have as a base for what shims you will need in the future. These shims are about $8 each, so I ordered them 2 at a time till I got a set I was happy with.
Hope that helps.
kodyo is offline   Reply With Quote
The Following User Says Thank You to kodyo For This Useful Post:
jcw99 (07-27-2017)
Old 05-09-2015, 11:48 AM   #386
Byrd
Drives: 2013 BRZ Limited
is the cusco 4.556 final drive possible to install on a AT?
Byrd is offline   Reply With Quote
Old 05-09-2015, 11:58 AM   #387
mrk1
Absolutely
The Build Thread
Old 05-10-2015, 10:40 AM   #388
xwd
I actually was looking to go to a 3.91 out of the IS250 so I bought an entire unit off Ebay for like $100 with an open LSD so I could swap in an aftermarket LSD. I'm assuming everything about the diff is the same as what we have so it's just a matter of getting right parts to shim it correctly.
Old 05-13-2015, 04:28 AM   #389
Paewrblue
Drives: BRZ WR Blue, E85, Fully modified.
Just one question from me, Im currently running about 194whp with e85 tuned on MT. Im facing one issue is that when I shift red-line from 5th gear to 6th gear. Right after im in 6th, the car just doesn't accelerate, it feels like the car is out of power due to the ratio of the 6th gear. So my question is if I change to 4.55 ratio, will I be able to accelerate and go faster after 210km/h ? With my current setup, my top speed maxed out at 218km/h with RPM of 5600-5700.
Thanks
Pae
Paewrblue is offline   Reply With Quote
Old 05-13-2015, 04:45 AM   #390
churchx
churchx's Avatar
Drives: 2014 GT86
That max speed limit might be due ECU firmware limiting max speed and not letting for throttle to be fully open after said gear/rpms (no clue, if it can be fixed with tune or not). While you'll improve acceleration (in 6th and other gears) to get there, max speed itself will be even lower, due you reaching those rpms at lower speed due different final drive ratio. As in normal legal daily driving or on track with lot of corners and not too much straights one can rarely reach max speed, for most final drive install is worth it. If you reached max speed even on stock final drive, then maybe it's worth reconsider to install it or not, if max speed matters more then acceleration to get there ..
Paewrblue (05-13-2015)
Old 05-29-2015, 02:32 AM   #391
Lunatic
Lunatic's Avatar
Originally Posted by CajunFRS View Post
How did you calculate these runs?
With a SS Meter.
http://www.gtechpro.com/ss_fanatic.html
Old 05-30-2015, 03:11 PM   #392
8686
8686's Avatar
Drives: 86
Originally Posted by Lunatic View Post
I am having dificulty calibrating the rpm.
Any advice?
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
cusco final drive
PST Carbon Fiber Drive Shaft Installed msile Engine, Exhaust, Transmission 155 08-28-2018 08:53 PM
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 03:21 AM
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin JM Auto Racing Brakes, Suspension, Chassis 271 03-22-2014 01:17 PM
Is my Cusco catch can correctly installed? wbradley Engine, Exhaust, Transmission 9 02-24-2014 10:49 PM
Has anyone actually seen any of the Cusco roll bar / roll cages installed? xenocharger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-03-2013 07:54 PM
