Old 05-01-2015, 11:19 PM   #1
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Leaking oil next to o2 sensor! Updated
Started the car this morning to go to work and I noticed a little whine on throttle. Got to work popped the hood and noticed a small amount of smoke from the passenger side by the direct injector ecu. Took some pictures tonight Any ideas.... car is a auto 28k miles.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 05-01-2015, 11:29 PM   #2
steve99
Drives: FT86
Is that the side where cam plate is, above 02 sensor if so check cam plate.
you guys have everything opposite to us :-)
Old 05-11-2015, 10:29 AM   #3
feldy
feldy's Avatar
update
So ended up having time to get the car up on jacks and removed the skid plate. It seems like oil is leaking out of the bottom even more on the drivers side then the passengers side.
Looks like valve covers maybe? Car is going to the dealer on Wednesday to get a look. Must be a slow ass leak or something as the dipstick level was fine.
Old 05-11-2015, 07:04 PM   #4
vgi
Drives: frs
There is a bunch of threads already
http://www.ft86club.com/forums/showp...97&postcount=6
vgi is offline   Reply With Quote
Old 05-11-2015, 08:26 PM   #5
Low&Slow
Low&Slow's Avatar
Drives: 10 Series #845
Either the cam cover or timing cover, been through this way too many times, still have a minor leak. Seems like Toyota just can't get it right. Goodluck!
Low&Slow is offline   Reply With Quote
Old 05-11-2015, 11:40 PM   #6
stevesnj
stevesnj's Avatar
It's a Subaru Engine
My 2016 Build thread
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 03:20 PM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 09:11 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 07:39 PM
Oil leaking? grgonium CANADA 7 07-30-2013 05:08 AM
