Old 05-10-2015, 02:33 PM   #1
Harvey
Drives: Celica 5th Gen, Tiburon 04, GT86
Check paint job
As you might have guessed from my "Removing front fender" thread, my front left fender as been damaged. The dealer is replacing it.
My car is color code D4S (black metal) and is one year old. I've been to see the paint job, and in dim conditions (in the dealer's garage) I find the metal shines more abundant (more concentrated, more visible) on the new fender than on the rest of the body. In the sunshine it looks fine (homogeneous).
Also, around the fastening bolds (of the fender onto the frame, 3 bolts from memory), the paint is chipped, as thought the socket had "chipped" the pain off.
Overall, what should my acceptance criteria be for this paint job? What should I look for?
Thanks for input... this is urgent as I'll probably go back tomorrow to accept the car or not.
Harvey is offline   Reply With Quote
Old 05-10-2015, 06:38 PM   #2
Well now, if you can't see any difference, in average light, from 10' away, I wouldn't worry about it. Same for the "chips" ...... if you can't see them from 10' away .....
Tcoat (05-11-2015)
Old 05-10-2015, 06:57 PM   #3
xmadror
Drives: BRZ Sport Tech 13
chipped paint would worry me, assuming its to the metal it could rust.
Otherwise its hard to comment on the paint match without pictures.
xmadror is offline   Reply With Quote
Old 05-10-2015, 11:32 PM   #4
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
brb using imagination
Instagram: stimson
The Following User Says Thank You to Turbo95eg6 For This Useful Post:
Jake360 (05-12-2015)
Old 05-11-2015, 10:47 AM   #5
Harvey
Thanks for the input.
For now the fender's back to the paint shop (because of the chipping around the bolts, which the dealer thought wan't acceptable either).
As for the match, when I'll have the car back I'll check in different lighting conditions to see if I can spot differences... if yes I'll try to post pictures
Old 05-11-2015, 11:06 AM   #6
The biggest challenge when paint matching is the owner's brain. You know the paint is different so will always "see" the difference even when there is none.
Whenever I had a section of a car painted I would always ask somebody that didn't know what area had been done where the new paint was. If they can't tell then I called it good enough even if it seemed to stand out like a beacon to me. I think in all the times I did that I had one person ever notice the difference.
Old 05-11-2015, 12:00 PM   #7
HotLavaFRS
HotLavaFRS's Avatar
Drives: 2015 Scion FR-S / Base
The biggest difference in how the paint appears is one year old paint with any swirl marks in it will diffuse light and appear duller than freshly painted parts.
2015 Scion FR-S Manual Base / Stock
1970 Mustang Fastback
HotLavaFRS is offline   Reply With Quote
Big paint chip, is touch up paint sufficient enough? simplydang Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 03-02-2015 05:41 PM
Paint expert opinion needed, paint defect or rocks? ducky369 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 02-08-2015 04:54 AM
Before you accept delivery of your new car check the paint - 2015 Subaru STI DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 05-06-2014 10:41 AM
Paint Correction, Opti-Coating, Car Wraps, Paint Protection & Tinting - LI Detailers LI Detailers Cleaning and Detailing 1 12-27-2012 05:12 PM
paint restoration : Subaru WRX - bringing the paint back to life brianc Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 7 06-25-2012 02:23 PM
