#953 |
Drives: Subaru BRZ
hey, i havent read the whole 44 pages but i have the same problem. i had nearly an inch of water in my subaru brz tail lights, they ordered 2 new lights and said they replaced them (which im starting to doubt). this was done last summer (2014) and now at the end of winter (we have snow here) i have some frozen water in them AGAIN.
im concerened about eventual electric problems and honestly it looks like shit in the summer when its all fogged up in the lights ill have to go shake the service manager |
#954 |
Sigh....
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | Guff (03-27-2015) |
#955 | |
You can remove the tail light assembly (4 10mm nuts) and a tab on the outermost edge. Then use a low/warm temp hair dryer and funnel, or methyl hydrate? Can't remember, but it will mix with the water and aid quick evaporation. Either way, you can easily dry the moisture without having to disassemble anything (aside from removing the bulbs). Then reapply a new and better gasket. I'd also recommend using a small bead of silicon sealant on each side of the gasket where pressure is applied to ensure there's a true watertight seal. Be careful during reinstallation, don't overtorque the nuts as it can deform the sheet metal. You can even reuse your OEM gasket this way if its still physically in good shape and you can remove it without damage. I had this problem as well on my passenger side and removed the light, dried it, cleaned the OEM gasket, and used silicone on both sides. Even after a VERY wet summer and winter, its still dry. |
#956 |
Drives: Red BRZ
Late last year my 2013 BRZ taillights were replaced under warranty. They leaked again, and were replaced yesterday; again under warranty.
The service tech explained that the boss where one of the mounting studs is located cracks. He showed me the pictures he sent to Subaru NA. The cracking is due to expansion/contraction of the unit during freezing months, I'm told. Here in Pittsburgh this year, we've seen our share of freezing temps. The new replacement units have a redesigned foam gasket that allow the taillight housings to expand/contract without causing stress to the boss. Makes sense, just hope it works. Washed and waxed the car yesterday too, no signs of condensation this morning. |
#957 | |
Drives: 2013 Scion FRS
For me this is just the right small car, but I'll admit it's not of the most rugged construction. |
#958 |
Drives: '13 Firestorm
Will Toyota refuse to replace the lights? Our '13 JUST started doing this?
Thanks, Jim
TRD Lowering Springs
TRD Front and rear sway bars Perrin 3 inch Cat Back Exhaust |
#959 | |
if it is out of the 32K bumper to bumper warranty, yes, at least they did for me. If you have an extended one, not sure. (EDIT: and for clarity when I say "yes" I mean "Yes, the will refuse" not "Yes they will fix it")
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". Last edited by Dadhawk; 05-08-2015 at 06:43 AM. |
| The Following User Says Thank You to Dadhawk For This Useful Post: | Beachnuttz (05-07-2015) |
#960 |
Drives: Toyota 86
Just drilled a small hole in mine to drain the water. Removed the light and ran a silicon bead around the molding. This did not fix the issue and I have no idea where the water is getting in. The unit is not sealed as the orange bulb has no seal around it.
#961 |
Drives: '11 Cayman , '14 Camry, '11 Tacoma
| The Following User Says Thank You to billwot For This Useful Post: | Beachnuttz (05-07-2015) |
#962 | |
Drives: 2013 Scion FR-S - Argento
The root cause is that the gasket is thin, not adhered well, and the top of each light is the drain path for the entire back window of the car. That's a LOT of water able to flow right onto the poorly sealed top of the lights. You can tell how much junk drains there when you pull off the lights and see all the dirt, leaves, and gunk piled up on top of the gaskets. The GasketNinja replacements, with good sealant all around, and some removable putty along the top edge of the lights where the water drains solved it permanently. |
| The Following User Says Thank You to cycleboy For This Useful Post: | wdninja (05-13-2015) |
#963 |
Drives: 2013 satin white brz limited
ive had a condensation issue with my right side tail light that has come and gone for over a year. Sometimes lasts a day other times months. They have been both replaced seal kits upgraded. Issue still remains and the local dealer and SOA claims it is designed that way and there is nothing they can/will do. I personally feal this in a joke and not the truth as I personally know 3 people with brz and 5 people with frs none that have had a issue at all with condensation ever....Let me hear your feedback.
#964 | |
The problem starts with the way the water channels from the trunk to the top of the brake light. it creates a river that collects dirt and debris that slowly works past the seal. The brake light itself is not 100% sealed, the bulb mounts are not airtight and are open to the cabin. (The lens is of course sealed to the housing, but that's it). So when the water eventually works its way past the seal, it wicks along the back of the brake light housing and through the bulb sockets. This is exacerbated by hot cold day/night cycles, rainy seasons, etc. that cause moisture to be pulled in, which then can't evacuate. The solution is to either replace the gasket with something aftermarket that's thicker and more durable, or seal both sides of the gasket with silicon sealant, or both. Others have used a sealant putty to create a dam at the top of the brake light housing... Personally I reused the OEM but cleaned it and added silicone, and haven't had a problem for two years. |
#965 |
Yea I briefly read it. Just frustrating that Subaru does so little to fix the issue. Soa gave me a $500 parts and service voucher today and basicly told me to piss off.
#966 |
well damn you could fix the problem for $5 and about an hour of time. Go spend $495 on hookers and blow!
| The Following User Says Thank You to wheelhaus For This Useful Post: | teamturbo (05-14-2015) |
| Red tail light photoshops | OwenK | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 68 | 02-06-2013 03:48 PM |
| HKS head and tail lamps | DIG1992 | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 05-19-2012 01:04 PM |
| Tail of the Dragon | Tomcat9700 | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 02-10-2012 02:30 PM |
| headlight condensation | MRZ415 | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 01-23-2012 02:24 AM |
| Optional coloured tail lights? | m_life | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 11-30-2011 06:20 PM |
