Drives: Toyota GT86 , 2.0L FA20 , RED
Toyota GT86 Basic Drift Setup
Hello ,
So I have my 2013 GT86 manual gear and want to start building it as a drift car but keeping the same engine without upgrading, reading and asking alot about what to do, the car as we know it does not have so much power but with correct setup it might give you more, Ive been practicing on drifting for a while now using a 350Z and G35 which had basic setup ( suspensions, wheels, E-Brake ) using the stock engine , knowing that the GT86 is lighter it could do better What I have in mind to change is the following : 1. change the current LSD with a LSD 2-Way 2. Coilovers system 3. Semi-Slick Tires 195-210/35 and 16 inch or 15 inch rims 4. Hydraulic Handbrake 5. Airfilter/Headers/Catback This is how i want to start with the car problem is im not that good to know which parts to buy, if someone can advice me would be better |
#2 |
Drives: 13 FRS Satin
You're missing high angle steering knuckles. It's what makes a drift car.
#3 |
Double camber bolts.
Drift button. Air pump. Clutch adjustment. |
#4 |
Drives: 2014 Pearl BRZ Limited
2jz
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully | | Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns | |
#5 |
Im only putting basic setup without angle @swarb : hydraulic handbrake is better the drift button , and im not changing the engine , which brands or models should i get from what I mentioned
#8 |
Drifter
i drifted mine descent completely stock, still mostly stock but its fun to get out to the track and let loose,
#9 |
Drives: 2015 Halo FR-S
So much trolling in this tread right now.. The car is RWD and has an LSD, increase your rear tire pressure and that is enough to start.
| The Following User Says Thank You to gtslow For This Useful Post: | Jyn (05-04-2015) |
#10 |
Drives: 2015 Fire
Funny, setting up my RC drift cars has definitely given me much more insight into setting up my real car. Tires, very important, camber and toe, and lastly suspension rebound. after that some practice and skill will go a long way
#11 |
Drives: Toyota GT86 Coupe Red (UK)
But jeremy clarkson says you can drift it while reading a book and none of you propose buying a book!
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
| The Following 7 Users Say Thank You to paulca For This Useful Post: | Chimera (05-04-2015), GT86_PRAGUE (05-04-2015), JoeC (01-30-2020), meWant (05-04-2015), Tcoat (05-04-2015), whataboutbob (08-07-2021), YamahaR86 (01-17-2020) |
#12 | |
Drives: GT86
| The Following User Says Thank You to GT86_PRAGUE For This Useful Post: | Tcoat (05-04-2015) |
#13 |
Drives: GT86
#14 |
Drives: 2005 Toyota Camry
To "drift well" the only real thing you need is a 2-way clutch-type LSD.
Everything else is secondary. On stock tires you can slide all day. This is me with the stock Torsen LSD: [ame="https://www.youtube.com/watch?v=cGwnf2tyDPA"]BRZ drifting @ Vegas Drift 05.30.14 - YouTube[/ame] I could've done better as far as connecting the manji transitions, it's really just poor driving skills + the Torsen acting like an open diff with sloppy transitions. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | ChrisD (12-22-2015) |
| Tags |
| drift, drifting, gt86 |
| GT86 drift video | mrbbs | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-03-2018 03:54 PM |
| circuit versus drift suspension setup | chadori | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 05-23-2014 12:10 AM |
| Drift video GT86 | mrbbs | BRZ Photos, Videos, Wallpapers, Gallery Forum | 0 | 09-22-2013 05:24 AM |
| 8 different GT5 Nordschleife leaderboards with the Toyota GT86 (stock, tuned, drift) | RaceR | Other Vehicles & General Automotive Discussions | 56 | 11-21-2012 10:56 PM |
