Drives: LR BRZ Limited
protecting the extended top nut/stud on rear coilovers
not sure if this product exists or not but i need a way to protect the top nut/stud on my rear coilovers. It extends a few inches taller than stock and it definitely hits the carpet walls if i had it installed. However right now my subaru trunk liner hits it on both sides. I could go with a rear strut bar or just simply cut my trunk liner to fit but i'd rather not go with those options right now. (I love my trunk liner to death)
I think i saw someone here had some kind of metal brace that could be bolted on top of the strut assembly and protect the top nut/stud. I cant find it at the moment. Any ideas? |
#2 | |
Because compromise ®
Drives: Red Herring
I'm not sure which nut/stud you are referring to so I don't know if this is of help.
#3 |
Drives: FRS
hmm...i never even thought about this before. now ill have to check tmw lol
#4 | |
thats the exact picture i was referring to. however arent you worried the metal tubing moves around while the car is in motion and keeps hitting the top of the adjuster or stud? maybe a softer material of the same dimension tubing could work? say maybe like PVC pipe? |
#5 | |
Drives: Red Herring
Having just inspected (2 minutes ago) the tube over the adjuster I am thinking it is not as much a prevention as I thought. There is movement of the tube that can still impact against the top of the adjuster. (I have different dampers from the one pictured.) Maybe a tube that was a tighter fit through the sheet metal of the body would be a better solution. I don't know if PVC tubing would be up to the task.
| The Following User Says Thank You to Captain Snooze For This Useful Post: | wparsons (05-02-2015) |
#6 |
The ideal solution would be something that slips over the studs on the upper mount and gets held in place by the nuts that hold the shock to the car, then extends upwards just enough to block anything from hitting the adjuster.
A simple curved piece of steel with a 90* bend at each end would do the trick.
#7 |
Drives: 2013 BRZ Limited SWP 6MT
I've got Koni adjustables and I cut a hole in the carpet and used the dust caps from the front struts because they didn't fit any more. Fixed the issue of covering them up in the back, but they're still exposed in the front
OVR-SCCA Course Design and SSSI |
| Protecting ignition area from scratches | TheThunderbird | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 05-16-2013 07:09 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Just curious. Anyone buy some detecters or camera for protecting their FRS? | ShowTime_DW | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 04-12-2013 06:27 PM |
| Tips for protecting the paint on the new car | brianc | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 0 | 06-25-2012 09:45 AM |
| Protecting plastic door threshold | BMWDavid | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 0 | 06-19-2012 10:04 PM |
