Old 05-01-2015, 05:36 PM   #1
Mcov
Rear LCA Question
I lowered my car around 2 inches on BC Extreme Low Coilovers. Can I keep the stock rear LCA in and get an alignment for just the toe? Or do i have to buy after market LCA?
Mcov is offline   Reply With Quote
Old 05-01-2015, 05:39 PM   #2
gramicci101
Off Topic
It depends on if you're happy with the camber you have from lowering the car. If it's horribly uneven, or if you want more or less than you have, you'll need LCAs in order to adjust it.
Old 05-01-2015, 05:49 PM   #3
Mcov
Ok thank you and without the rear lca the toe can stil be adjusted right?
Old 05-01-2015, 05:52 PM   #4
gramicci101
Off Topic
Yes, toe is adjusted separately with its own arm.
If you're on BC Extreme Lows and you decide you need LCAs, you may want to look into Stance, PBM, or similar that incorporates a lowered geometry. That will allow you to maintain the height you want while giving you a little more travel in your suspension.
lca alignment
KW Rear Top Hat Question Sikkwidit Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 08-07-2015 01:36 AM
Rear seat question mrnurse Cosmetic Modification (Interior/Exterior/Lighting) 2 10-24-2014 07:14 PM
Question on rear toe sidebrake Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-13-2014 12:43 AM
Rear diff LSD question Dephective Engine, Exhaust, Transmission 15 09-01-2013 06:30 PM
TRD Rear Lip question/opinion DC-FRS Cosmetic Modification (Interior/Exterior/Lighting) 2 08-18-2012 02:50 PM
