Old 03-11-2015, 08:35 PM   #155
Top-Secret
Drives: FRS monogram
Size:  318.4 KBjust got a chance to finish my buddies gauges. Little Photoshop and this is what you end up withName:  uploadfromtaptalk1426120512289.jpg
@Prole237
Top-Secret is offline   Reply With Quote
Old 03-11-2015, 08:38 PM   #156
Top-Secret
@KonTheory
Can't edit the stupid tag on my phone
Old 03-12-2015, 03:40 PM   #157
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
Originally Posted by Pwolf View Post
For those that are interested, a little gopro cap of my interior:
Did you change out your head unit for the new on in the 2014+ FR-S? I like the white...Going to have to do that to mine
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 03-12-2015, 03:45 PM   #158
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
Nope. Replaced the red LEDs with white and then used transparent blue vinyl on the back of the gauge insert to make anything I didn't want to be white, blue.
Pwolf is offline   Reply With Quote
Old 03-12-2015, 04:43 PM   #159
Top-Secret
I tried doing the head unit and broke it somehow. Be careful with that one
Old 04-23-2015, 04:49 PM   #160
Pwolf
Pwolf's Avatar
@MemphisR sorry, thought you were talking about the gauge cluster. Not sure what I was smoking when I read it the first time. Lets try this gain:
The HU is actually a Ca-Fa Dashlinq4. The white is stock.
Old 04-24-2015, 12:11 PM   #161
MemphisR
Memphis
MemphisR's Avatar
I have no idea what Ca-Fa Dashlinq4 means. Mine is orange stock. I will send you a picture at some point
Old 04-24-2015, 12:58 PM   #162
Pwolf
Pwolf's Avatar
It's an aftermarket head unit.
Old 04-30-2015, 04:50 PM   #163
natasharae36
natasharae36's Avatar
Drives: 13 SWP BRZ
Hi I had a question... what type of lights am I suppose to order for the BRZ cluster? You said it wasn't too hard so im just trying to see as to if this is actually something that I can do by myself. I either want to change all of mine to white or to blue.
natasharae36 is offline   Reply With Quote
Old 05-03-2015, 11:19 AM   #164
eggncheese
Drives: 2013 Ultramarine Scion FRS MT
PLCC-2
eggncheese is offline   Reply With Quote
Old 06-17-2015, 08:25 PM   #165
natasharae36
Drives: 13 SWP BRZ
Qustion
Just out of curiousity have you made this very detailed video? I am trying to change mine I already have the pink bought and was wondering if this was made. Thanks
Originally Posted by DustinS View Post
The holes in that needle that was pulled apart is from two plastic tabs. I just cut the lip off with an exacto knife. I then used a very fine flat head to carefully pry the black cover (the small one keeping the needle on the big black piece) off. Then after you finish stripping and painting(I painted the bottom flat white, though I did also buy gloss white, and silver) the needles, you insert them back into the casing(take note as the clear plastic of the needles are thin and flex a lot, they might be easy to break). Then put the black cover back over the clear part and eight use the soldering iron the melt the cover to the remaining black tab to keep it closed, or there might be enough of a lip to just snap it back on.
I am thinking about buying another gauge cluster from eBay and making a very detailed video. I didn't this last time because I started working on it last minute and was kinda rushing to get it done.
Edit: I wonder how pink would look... I think purple wouldn't be too bad.
Old 06-18-2015, 10:04 AM   #166
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I haven't yet. It got pushed to the back burner and a friend is using my GoPro at the moment. I'll look at doing that here in the coming weeks though. I'll let you know.
Old 07-05-2015, 05:42 PM   #167
natasharae36
Drives: 13 SWP BRZ
Hi I was curious as to if you could help me.. I was doing the ac part of the brz.. and for some reason some lights are working and the others aren't? Is there something I am doing wrong with the soldering? Is there a way to actually burn out the LED light it self is there an issue with having to much solder.
Old 07-08-2015, 01:15 PM   #168
Aqrab
guys
from the previews pictures , where is the chime speaker ?
Aqrab is offline   Reply With Quote
Gauge Cluster on FRS tonytduc Scion FR-S / Toyota 86 GT86 General Forum 16 07-24-2017 09:56 PM
BRZ cluster gauge swap? InYOHface Cosmetic Modification (Interior/Exterior/Lighting) 31 03-25-2017 06:31 PM
WTB gauge cluster Basti Want-To-Buy Requests 3 04-09-2014 02:54 PM
Gauge cluster mod? kALMIGHTY Scion FR-S / Toyota 86 GT86 General Forum 8 11-27-2013 10:59 PM
Want to try a gauge cluster experiment with me? stockysnail Northwest 2 04-12-2013 10:57 AM
