Old 04-30-2015, 01:25 AM   #1
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Better mileage after long drive
14 base FR-S, just over 1 year now.
16k miles
Just took it on an 600 mile trip, getting 1mpg or better driving to work now. Just put 1/2 a tank of real petrol, no ethanol, in on the trip. Seems to have made a difference as I'm getting 27.5 driving to and fro work now.
Any insights. Cleaner fuel system from all petrol super? Not sure, no other changes otherwise.
jeepmor is offline   Reply With Quote
Old 04-30-2015, 01:36 AM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
How is your MPG being measured?
-alex
Old 04-30-2015, 01:51 AM   #3
Vincenttam
WtsTofu
Vincenttam's Avatar
Drives: Ultramarine fr-s
Best way to measure it is with gas receipt, pencil and paper. The reading on the odometer is off by a little.
Vincenttam is offline   Reply With Quote
Old 04-30-2015, 02:02 AM   #4
Tromatic
Mine reports increased mileage after highway travel as well in fifth or sixth. It's an extremely optimistic little indicator, off by as much as five mpg sometimes from the actual result from doing the math.
The Following User Says Thank You to Tromatic For This Useful Post:
strat61caster (04-30-2015)
Old 04-30-2015, 02:47 AM   #5
jeepmor
Data is from the car itself via gauges. I do record fill ups via paper log, but didn't check. Just Looking at the car gauge.
I did have that long drive, and put some pure dino fuel in there. That's likely the anomaly. Wondering if injector are that sensitive or of the pure dino petrol cleaned out my system.
Old 04-30-2015, 03:48 AM   #6
InspGadgt
InspGadgt's Avatar
Drives: 2015 Scion FR-S (Asphalt)
It is normal for long drives to increase fuel mileage. Typically on a long drive you stay at a more consistent speed for longer and do less accelerating so your fuel economy is better. It will stay up there for a bit longer when you resume normal driving patterns but will eventually average back out to what you were getting before.
InspGadgt is offline   Reply With Quote
Old 04-30-2015, 11:44 AM   #7
It might be within experimental error ........
GreenMonster (04-30-2015)
Old 04-30-2015, 01:04 PM   #8
extrashaky
Drives: 2014 BRZ Limited
Unfortunately you can't trust that thing. It is estimating your mileage by average fuel flow rather than actual miles driven divided by actual fuel used. I installed a mileage calculator on my phone (which does the pencil and paper calculation for you at each fill up), and the car's computer is consistently 3 to 4 mpg off.
If you use the car's computer, that bump after highway use could just be a side effect of the way the car calculates fuel economy. If it's averaging fuel flow, and you just had a long period of lower fuel flow, it's going to average that into the initial calculation back in city driving. It would appear to have a bump whether there really is one or not.
Do it with real numbers instead. There's no reason to have to keep a notebook and do math when you can download an app for your phone that will do it all for you.
Old 04-30-2015, 02:18 PM   #9
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Nah, assuming the car is in working order with no anomalies the driving cycle, that is the type of driving dictates the fuel economy you get in the moment with no lasting effects.
Highway efficiency > stop and go/city efficiency > wide open throttle
At least, when it comes to your wallet (as pure physics/engineering efficiency favors WOT) combustion engines like steady state.
You're telling us that you're seeing +1 mpg. Is that on your average that you have never reset over 14k miles? Is that on this tank of fuel? Is this on the tank of fuel afterwards? Is this the average of three tanks of fuel?
That statement is open to interpretation so you'll get lots of diagnoses (doctor my stomach hurts, it's either the leftovers or cancer).
By the next tank of fuel you'll be back to normal.
http://www.ft86club.com/forums/showt...18#post2071818
ineedyourdiddly
Tcoat (04-30-2015)
Old 04-30-2015, 03:46 PM   #10
Zhangy
Drives: 2015 FRS
Just reset the Overall MPG reading so you get a more accurate picture for your current trip's MPG. Since it showed the long term average, it's not going to change much in just a trip unless of course you reset it
Zhangy is offline   Reply With Quote
Old 04-30-2015, 06:44 PM   #11
Tromatic
E85 is a much better solvent that pure gas is.
Old 04-30-2015, 07:47 PM   #12
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Originally Posted by extrashaky View Post
... actual miles driven divided by actual fuel used.
billwot is offline   Reply With Quote
Old 04-30-2015, 08:15 PM   #13
jblmr2
jblmr2's Avatar
It's always been my understanding that non-ethanol gas will produce better mpg than ethanol "enhanced" fuel. Back in the day when all gas was gas, not a gas ethanol mix, I got 2 to 4 more mpg. Around here non-ethanol is hard to find and usually goes for a premium price. You have to do some number grinding to determine if its worth while.
jblmr2 is offline   Reply With Quote
Old 05-01-2015, 03:04 PM   #14
strat61caster
Yes, ethanol has less energy per unit of volume than 'straight gas' so you will see a mileage decrease as you need to put your foot down a little more to go the same speed. It also corrodes certain rubbers used in older cars and soaks up water which could be bad but typically neither is a problem as most people drive newer cars and we typically burn enough fuel all the time for the moisture collection to ever come to anything meaningful.
Ethanol is more knock resistant so you can run more advanced timing and higher compression ratios to compensate for the lack of energy per volume, that's why E85 tunes show such good gains on stock everything else (Sprint/Outlaw racecars run straight ethanol). And since it is renewable it is likely that ethanol in some form is here to stay to subsidize fossil fuels, it's only cheap now because of government subsidies but the fact that we can grow it and process it on this continent are not something to laugh at.
ineedyourdiddly
400+whp Mileage Reaper Engine, Exhaust, Transmission 28 02-02-2016 02:59 PM
Most mileage while FI Triumphrider Forced Induction 14 09-15-2014 09:27 AM
What's your Mileage? XxSuPrAxX Scion FR-S / Toyota 86 GT86 General Forum 100 10-26-2013 04:30 PM
Cinco de Slamo Meet in Long Beach NY (Long Island) whitefrs New England 11 05-01-2013 10:03 AM
TGIF[R-S]: Can You Drive a Rear-Wheel Drive Sports Car All Year Long? No5ki Scion FR-S / Toyota 86 GT86 General Forum 27 01-06-2013 09:30 PM
