Old 04-28-2015, 11:12 AM   #15
puma
crew chief
puma's Avatar
Drives: Race car FR-S
Originally Posted by jdp530 View Post
I have a brand new unit. Puma, when I go to 'online' I can see all of the ECU channels, and values for each channel, but under last column 'measurement', its showing ERR. in each box for all but the first five channels. So I am assuming ERR. is an error message?
Firmware 46.03.18 shows on screen.
logging is not going to work because as of now, solodl doesn't communicate with the car's ecu, either you set it up wrong or connection is bad but logging is not going to work until you fix this.
puma is offline   Reply With Quote
The Following User Says Thank You to puma For This Useful Post:
CSG Mike (04-28-2015)
Old 04-28-2015, 11:36 AM   #16
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
What mode is your unit in? If you're not in circuit, try lowering the S/F tolerance distance. Also, lower the recording start window.
I am in point-to-point mode.
I am not aware of how/where to adjust S/F tolerance. Is this done on the unit or on the PC using software?
also, since we're on this subject, what is the "track width" field for and how does it affect the data acquisition?
Old 04-28-2015, 12:12 PM   #17
CSG Mike
CSG Mike's Avatar
The tracks are, for lack of a better word, a "line" of location data points. The track width is how much tolerance there is for deviation from that width in which the AIM considers you to be "on track". It also affects where it thinks your set start/finish point is, so you may want to lower it, but it also requires you to have more satellites locked in for accurate readings. Make sure the AIM has a clear view of the sky.
CSG Mike is online now   Reply With Quote
Old 04-28-2015, 01:33 PM   #18
jdp530
Drives: 2014 BRZ
Puma, I have used someone elses solo DL in my car a couple of months ago and it worked fine. I guess I need to figure out how to clear contents and reload software and see if that will correct the problem.
jdp530 is offline   Reply With Quote
Old 04-28-2015, 02:25 PM   #19
redlined600
redlined600's Avatar
Drives: Fr-s
Originally Posted by rice_classic View Post
James Colborn has a whole Youtube series about how to best use your AIM SOLO (DL and non DL). He occasionally races with the Compass 360 and Bimmerworld teams and hosts seminars here in the NW for local racers. I don't want to take away from CSG Mike but I thought these were generally very good how-to videos that others may benefit from.
Colborn's series
https://www.youtube.com/playlist?lis...tlZ8XXpycC980Z
Here's an excellent one to start with
These are great. While I use RaceChrono(android app), as opposed to the Solo, it outputs a file format that allows me to use the AIM software for analysis, I found these videos quite helpful.
If I were looking for a standalone datalogger it would be the Solo DL. I think AIM really hit a home run with the solo units.
Also thanks to CSG for providing support like this.
EDIT:I was actually incorrect, the software I use is Circuit tools, not AIM. They are similar in enough ways that the videos were helpful.
redlined600 is offline   Reply With Quote
Old 04-28-2015, 05:30 PM   #20
jdp530
Drives: 2014 BRZ
Mike, my car is totally stock except for tires and oil cooler. And, its a 2014 BRZ.
Old 04-28-2015, 06:00 PM   #21
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
It definitely sounds like it may be an OBDII port issue if everything is loaded up on the unit properly.
Here is the next test.
Leave the unit turned off, plug in the OBDII connector to the OBDII Port, then plug in the silver connector to the AIM Solo DL Unit (the port without the cap) and see if your AIM unit turns on and is "charging" from the OBDII port. That will at least let us know if there is power coming from the OBDII port to the unit.
-mike
AZP Installs is offline   Reply With Quote
Old 04-28-2015, 06:28 PM   #22
jdp530
Drives: 2014 BRZ
Mike, it turns on as soon as I plug in the connector.
Old 04-28-2015, 09:34 PM   #23
AZP Installs
Ok so it is getting power at least from OBDII.
If the proper channels are loaded onto the unit, it could be an OBDII port issue.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
Old 04-28-2015, 10:33 PM   #24
CSG Mike
CSG Mike's Avatar
@jdp530
Hmmm... do you know anyone else locally with an FRS or BRZ you can plug the unit into?
Old 04-29-2015, 02:55 PM   #25
jdp530
Drives: 2014 BRZ
I will have a chance to run in another car this weekend.
The Following User Says Thank You to jdp530 For This Useful Post:
CSG Mike (04-29-2015)
Old 04-29-2015, 05:01 PM   #26
CSG Mike
CSG Mike's Avatar
Keep us posted!
Old 04-29-2015, 06:16 PM   #27
mkivsoopra
I sometimes have issues with my OBD2 port, probably from doing too many EcuTek flashes. My workaround is to use an OBD2 extension cable between the car and the AIM Solo cable, and that seems to do the trick.
mkivsoopra is offline   Reply With Quote
Old 04-30-2015, 11:17 PM   #28
jdp530
Drives: 2014 BRZ
I couldn't resolve the ECU data issues even with the help of the AIM guys so I am returning it so they can check it out. I had the latest software and firmware updates. AIM customer service looked at the screens and couldn't see anything wrong with config.
CSG Mike (04-30-2015)
2014 SCCA Solo Nationals/Pro Solo Finale thread edj Tracking / Autocross / HPDE / Drifting 206 09-19-2014 12:34 PM
SCCA Socal Solo 2 at El Toro, Socal, 3/22-23, noob questions JB86'd Tracking / Autocross / HPDE / Drifting 52 03-29-2014 05:00 AM
Wax Sealant Pad Questions / Care Questions l0aded Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 03-25-2014 12:19 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 09:08 AM
