Old 04-27-2015, 10:57 PM   #15
86Tony
Drives: 2015 AOZORA EDITION
Any updates I might just call in tmwr to book an appointment. After I flash my car with OFT noise is only at idle when I Rev it a lil you can hear it but barley
86Tony is offline   Reply With Quote
Old 04-27-2015, 11:41 PM   #16
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I take my car in tomorrow. Will update when details become available.
Bobblehead is offline   Reply With Quote
Old 04-29-2015, 02:12 PM   #17
Bobblehead
Bobblehead's Avatar
Just got a call from the dealer.
It turns out its something to do with the input shaft on the transmission that's making this noise. Its weird, because I never had any shifting issues or anything of that nature.
They ordered a new transmission and I'll be getting it replaced May 13.
This sucks. From what I understand, its safe to drive. It just sucks.
Old 04-29-2015, 03:05 PM   #18
Xuningshen
Drives: Subaru BRZ
mine has had this too since probably.... 8k miles. I dont think its anything to worry about. And i'm honestly really surprised that the dealer is straight up replacing the whole trans for this "issue"
part of me thinks the noise will still be there(if they dont change out the clutch/pressure plate as well), or come back after several thousand miles. I'm genuinely curious. please report back.
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
Old 04-29-2015, 04:24 PM   #19
Bobblehead
Bobblehead's Avatar
Will do. It doesn't sound like a healthy noise and no one on the forum as said anything about it. I figured while I still have the warranty I might as well get it looked at.
Old 04-29-2015, 04:52 PM   #20
Xuningshen
Drives: Subaru BRZ
True, but thats probably a good thing then, that nobody has been saying much else because if its a sign of imminent failure, i'm sure we would've heard about it a lot now. most of the complaints is the notchy-ness and "grinding" (quotes because i think some people might be mistaking notchy for grinding. Some.... not all)
but actual failures of synchros/gears are basically limited to those running over 300 rwtq. i'm sure there has been a few bad ones out there though.
2014 WRB BRZ
Old 05-01-2015, 02:30 AM   #21
86Tony
Damn I'm going to have to book my appointment asap and hope I get a new transmission. Who cares if it sucks bro you getting a fresh new transmission and probably better then ever thanks for the update now I have to bring it in.
Old 05-14-2015, 11:36 AM   #22
86Tony
Booked my appointment for th 29th hope goes well. I will update if I get new tranny or not
Old 05-14-2015, 12:13 PM   #23
Koa
Understand that much more goes into the shifting system than the clutch and FW.. specifically input bearing, input shaft, and others that dude talked about. An off-kilter input shaft can oscillate and throw the otherwise well-functioning FW and clutch assembly off balance, thus chatter.
The Following User Says Thank You to Koa For This Useful Post:
Xuningshen (05-15-2015)
Old 05-14-2015, 10:07 PM   #24
Bobblehead
Bobblehead's Avatar
New transmission is in. So far there hasn't been any chatter noise upon a cold start (35F this morning) and normal idle.
I only noticed a brief noise when the A/C compressor kicked on after turning on the heat. I guess the problem is fixed. The dealership sent the defective tranny back to Subaru. I asked the parts/service rep if Subaru would say what failed or caused the failure, and he said no. If there was an issue with it, the only way they would know is through a bulletin or TSB.
I'll keep listening for the noise, but with it finally warming up outside it might be impossible to mimic the conditions.
The Following 2 Users Say Thank You to Bobblehead For This Useful Post:
NA_FRS86 (05-15-2015), Xuningshen (05-15-2015)
Cold rattle? JGalp Engine, Exhaust, Transmission 7 06-24-2018 02:25 AM
Flywheel Rattle? CB762 Issues | Warranty | Recalls / TSB 119 11-16-2016 11:09 PM
Rattle sound on cold start Frs32907 Issues | Warranty | Recalls / TSB 0 07-12-2014 11:36 AM
rattle sound cold start marky Issues | Warranty | Recalls / TSB 1 03-24-2014 07:16 PM
Flywheel / Clutch rattle topazsparrow Issues | Warranty | Recalls / TSB 7 07-05-2013 09:09 PM
