#99 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | lead82 (04-28-2015) |
#100 |
Off Topic
I've learned that with a sliding caliper, you can use a wood clamp to push the caliper against the rotor before you unbolt it, guaranteeing that the pistons go in straight. This is probably common sense, but I certainly felt accomplished when I figured it out.
#101 | |
Drives: FT-86
I've never said anything about the STI swap because i never used them. I simply stated that (for me) i rather have a kit designed to work for this car than doing a swap, EVEN if its effective and very good for that matter. No problems with the swap, just think that many people (like myself) would rather go on the BBK route for the confidence that the kit provides.
#102 | |
Obviously, you gotta wait till the brakes are cool, but yeah. |
#103 |
Junior
Drives: a car
Nope!! Get em while they're hot! Fresh off the track, nice and warm at 500* F!
#104 |
Drives: 2005 Toyota Camry
Not exactly STi Brembos, but I swapped a set of Endless Mini 6-pot calipers off a '02+ WRX onto the BRZ. My research was primarily focused on the equivalent systems between the GD WRX and comparible upgrades available for our cars.
Both Endless + Wilwood lists the same size caliper/caliper piston/rotor upgrades for the two cars, different part numbers but otherwise the same overall kit. 8 months and 10k street/track miles later, they still work well. Current tally is 8x track, 2x autocross, 1x drift events. I'm about at the end of life on the current set of pads and have Winmax W5 on order. http://www.ft86club.com/forums/showthread.php?t=49454 -alex |
#105 | |
Drives: FT86
From a simple search on AP Racing Website, BRZ and WRX have VERY VERY VERY similar parts numbers for Caliper Type, Brake Disc, Disc Mounting Kit and Brake Pads(Pads are exactly the same part numbers). Fronts have little different parts number, I'm assuming that because of the brackets. But please explain why these calipers are so similar but yet installing STI brakes on BRZ is dangerous. Front BRZ Front 6 Piston AP Racing BBK https://www.apracing.com/product_det...32mm_disc.aspx STI Front 6 Piston AP Racing BBK https://www.apracing.com/product_det...9040y1003.aspx Rear BRZ Rear 4 Piston AP Racing BBK https://www.apracing.com/product_det...35_x_24mm.aspx STI Rear 4 Piston AP Racing BBK https://www.apracing.com/product_det...24mm_disc.aspx |
#106 | |
Even the caliper physical shape is different: WRX/STi: https://www.apracing.com/drawings/P16.341.pdf BRZ: https://www.apracing.com/drawings/P16.318.pdf Edit: no one cares about caliper size or shape. We care about rotor size, pad size, caliper piston size, and how this impacts brake bias. -alex |
#107 |
#1819
Drives: Lightning Red Subaru BRZ
After reading the posts it just seems like some people think that putting brakes that are perfectly safe on a WRX STI on to a BRZ would cause the car to crash instantly.
I think there's nothing wrong with people who want to install STI calipers onto their twin. I do think its wrong to create fear mongering when you don't have all the facts. Facts not opinions. |
| The Following 2 Users Say Thank You to mrha For This Useful Post: | BunnyRZed (05-05-2015), Jive Turkey (04-29-2015) |
#108 | |
#109 | |
#110 |
Off Topic
Drilling and slotting remove mass from the heat sink (rotor) which makes it less effective at absorbing heat from the pads. You could make more effective change with fluid, titanium pad shims (debatable), and cooling ducts. Make sure you point the ducts towards the inside of rotor so you're directing air over the vanes, as opposed to pointing straight at the surface of the rotor.
#111 | |
#112 |
Drives: 4-Runner Sport - 13' BRZ SportTech
Someone needs to rename this thread to "the speculation about using STI brembos on the twins"
Top Tier Imports - Check out my build journal HERE
| The Following 2 Users Say Thank You to protpibe For This Useful Post: | Jive Turkey (04-29-2015), xkalelx (05-10-2015) |
| The Truth Will Set You Free~ | Kiske | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 01-06-2015 08:53 AM |
| Moment of truth. Humor is welcome! | gt8613 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 11-11-2014 03:08 PM |
| any truth to this? | fluffy-reindeer-slayer | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 06-11-2014 09:00 PM |
| An inconvenient Truth | Maxim | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 06-17-2011 11:35 PM |
