Old 03-28-2015, 10:20 PM   #1
WayTooLoud
Drives: 2015 FR-S & 1991 MR2 Turbo (FS)
Wheel directory: Whistler 18x9.5 +35
Stock suspension. Clearence to strut is really close but no rubbing so far. Tires are 235x40x18.
A lot of poke in the front but that will clean up when I can afford coils.
WayTooLoud is offline   Reply With Quote
Old 03-28-2015, 11:16 PM   #2
Crazy Drew
Drives: Smells like tires when I drive
Looks good, I was strongly considering these before I had a different set of wheels fall in my lap. Can't wait to see it on coils.
Crazy Drew is offline   Reply With Quote
Old 04-26-2015, 04:24 PM   #3
Roflsquad
Drives: Blue subaru Brz
Looks great man got the 17x9 ones my self did you have to put anything on the hub and what lug nuts did you use?
Roflsquad is offline   Reply With Quote
Old 04-26-2015, 05:43 PM   #4
Jolt182
Jolt182's Avatar
Drives: Asphalt FRS
Wow nice rims man. I have a quick question for you guys though. 18x9.5 +40, on coilovers. Any idea what size tire I need to run to make these fit in the Front and Rear?
Jolt182 is offline   Reply With Quote
Old 04-26-2015, 05:54 PM   #5
IIDutch
IIDutch's Avatar
Drives: 2014 Firestorm FRS
May be able to help you, I'm on 19's and in the rear I have 265/30 for 9.5 wide and I dont rub, fronts are 8.5 225/35 but I'll run out and take a photo of how the tire sits
My offset is +40 as well
IIDutch is offline   Reply With Quote
Old 04-26-2015, 06:00 PM   #6
IIDutch
IIDutch's Avatar
This is 225/35, you'll probably want to stretch a 235/35 or 240/40 if you have 18x9.5 up front. Also I didn't have to roll my fenders and am not rubbing
Old 04-26-2015, 06:05 PM   #7
Jolt182
Jolt182's Avatar
Drives: Asphalt FRS
Thanks for the info man I really appreciate it!
Old 06-01-2015, 01:43 AM   #8
thien
Drives: Scion FRS
I'm running 215/40 in front. 225/40 in front will rub. 235/40 in the back is fine.
thien is offline   Reply With Quote
Wheel Directory: Volk Racing TE37 18x9.0 +45 Front / 18x9.5 +40 OmegaKnight Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-03-2016 09:09 AM
Wheel Directory: Work VS-XX 18x9.0 +34/18x9.5 +39 mav1178 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-13-2014 05:09 AM
Wheel Directory: Work Meister S1 3-Pc 18x9.5 +29 / 18x9.5 +24 PradiG Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 12-12-2013 04:15 AM
Wheel Directory: SSR Professor SP3 18x9.0 +24 / 18x9.0 +20 RZ86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 05-18-2013 05:14 AM
Wheel Directory: Volk Racing TE37 18x9.0 +45 / 18x9.5 +45 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 09-04-2012 01:25 PM
