Old 04-25-2015, 10:34 PM   #1
BRZJunkie
Drives: BRZ Sportech
Academic question
Could not decide where to post it but here it is. From max rpm, gear ratios, diff. ratio, wheel and OEM tires, it looks that you can reach 60.4 mph (97.2 kph) in second. I know it's not an exact science, but would explain the good time reported by Car&Driver for 0-60mph whereas the 0-100kph is nothing to write home about since you do have to shift to 3rd gear.
BRZJunkie is offline   Reply With Quote
Old 04-25-2015, 10:37 PM   #2
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
You own the car, can't you test it yourself?
The Following User Says Thank You to LucidMomentum For This Useful Post:
Choco (04-30-2015)
Old 04-25-2015, 10:45 PM   #3
BRZJunkie
That's a sweet answer! Thank's sooo much.
The Following 2 Users Say Thank You to BRZJunkie For This Useful Post:
Thorpedo (04-25-2015), Ultramaroon (04-25-2015)
Old 04-25-2015, 10:48 PM   #4
rucfj159
Drives: 15frs 89volvo765&780
I dont bother with speedo just look for the red light
rucfj159 is offline   Reply With Quote
Old 04-25-2015, 10:52 PM   #5
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
you have to launch the car
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Old 04-25-2015, 10:55 PM   #6
gramicci101
Off Topic
What exactly is your question?
The Following 3 Users Say Thank You to gramicci101 For This Useful Post:
brandonblt2 (04-26-2015), Lo (04-25-2015), Ultramaroon (04-25-2015)
Old 04-25-2015, 10:56 PM   #7
Teseo
Drives: frs
Who cares what say car & driver?
Teseo is online now   Reply With Quote
Old 04-25-2015, 11:01 PM   #8
BRZJunkie
Here's the numbers
babydriver (04-29-2015), frsvr4 (04-29-2015)
Old 04-25-2015, 11:03 PM   #9
rucfj159
On a closed course in a vacuum with perfectly formulated asphalt at the proper temperature Michael Schumacher could get a FRS 0-60 like the magazine says
Old 04-25-2015, 11:06 PM   #10
BRZJunkie
Actually it's more an observation than a question but how much time you loose by shifting. The best drivers and the loosy ones. I mean driving the car not abusing it.
Old 04-25-2015, 11:12 PM   #11
gramicci101
Off Topic
It's not just shifting. You don't spend a lot of time at the perfect rpm; you're either working up to it or moving past it, which means you're using less than max power. It would be interesting to see 0-60 from a cvt that could hold you at max torque and change ratios to speed the car up as fast as possible without bogging the engine.
The Following User Says Thank You to gramicci101 For This Useful Post:
Old 04-25-2015, 11:20 PM   #12
BRZJunkie
but actually if you compare our car to others, most people quote 0-60mph or 0-100kph. By using 0-100kph it looks worse because of the need to shift one more gear. That's all I was bringing up.
Old 04-26-2015, 05:28 AM   #13
OnkelC
OnkelC's Avatar
Drives: 2017 Fiesta ST
when playing top trumps, this is a genuine disaster. for the bragging rights, the low top speed is far more humiliating. for driving, zero of the expletive word is given. male enhancements can be had cheaper (sock in pocket etc.)
OnkelC is offline   Reply With Quote
The Following User Says Thank You to OnkelC For This Useful Post:
Tcoat (04-26-2015)
Old 04-26-2015, 09:29 AM   #14
Translation:
When in a d1ck measuring contest about speed you will come up short. Shove some socks down the front of your pants and call it a day.
D_Thissen (04-29-2015), OnkelC (04-26-2015)
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 12:41 PM
Oft question cooldandani Software Tuning 3 04-06-2014 12:17 AM
Serious question KslayFRZ Off-Topic Lounge [WARNING: NO POLITICS] 49 07-11-2013 04:46 AM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 03:11 PM
TCS/VSC question. Cheddar Scion FR-S / Toyota 86 GT86 General Forum 5 06-10-2012 09:29 PM
