go_a_way1
Old 04-24-2015, 01:26 PM   #2157
CSG Mike
CSG Mike's Avatar
Originally Posted by LS1M View Post
I don't think that's required outside of California, is it? Last time I checked, here in Texas they just plug into the odb2 port & if it shows the emissions tests are completed and the SES light is off, you pass.
Yes, the CARB tune is only mandatory to be legal in California. Other states may vary.
Passing inspection is not the same as being legal; you can pass smog quite easily with an illegal car in California, but if you get cited for modifications or emissions violations, then that CARB sticker is going to save you a massive headache AND a massive fine.
In CA, if you have a history of smog citations, then every smog you get will require you to get a STAR test, instead of just a OBD2 readiness test. There's more than one reason to get the CARB tune, especially in California.
Outside of California, if you're planning on keeping your stock cats, chances are the CARB tune is more developed than something your local tuner can throw together on a dyno in just 4 hours. There's more to a tune than just doing a lot of WOT pulls and making adjustments to open loop operation for maximum safe power.
Old 04-24-2015, 03:19 PM   #2158
uRBAN_Metal
Drives: '13 BRZ
You cannot go to a tuner, with you oft, and ask them to give you a tune. They can't.
Having owned an OFT in the past, this is absolutely untrue. All of the maps are open and easily editable in RomRaider. The biggest reason tuners wouldn't tune with the OFT were the incredibly long write times, which I've been told have been reduced, and they would have to use a set of tools they weren't used to.
It may be possible that JR are using features of EcuTek in the CARB map that are not available in the OFT, but that doesn't mean you can't tune with it. The hard part would be finding someone willing to develop a map for you with the tools available. It's been done with the Vortech and SBD kits, there's no reason it can't be done here. I switched to EcuTek because I didn't want to deal with the hassle of making the OFT work, when working with a reputable tuner was easily accessible.
uRBAN_Metal is offline   Reply With Quote
The Following User Says Thank You to uRBAN_Metal For This Useful Post:
Boofneenee (04-24-2015)
Old 04-24-2015, 03:21 PM   #2159
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
You're essentially stuck with what OFT provides you, and they haven't provided any sort of JRSC compatible map, nor do I forsee one coming in the future. This picture from @DeliciousTuning sums it up perfectly.
0 ecutek issues. Plenty of OFT issues.
You're getting a JRSC, not a KWSC, right?
That's a pretty misleading picture, which was also mentioned in that thread it was originally posted in.
Old 04-24-2015, 03:22 PM   #2160
CSG Mike
CSG Mike's Avatar
I would not be comfortable using a tune using the tables that are currently editable with OFT.
Your car, not mine.
Just as you sold your OFT, the sheer number of them for sale, used, should speak for itself.
Old 04-24-2015, 03:30 PM   #2161
uRBAN_Metal
Drives: '13 BRZ
Your car, not mine.
My point was that anyone can most certainly tune any setup with the OFT if they wanted to, regardless of your decision to drive the car. You said it can't be done, when it has been for quite some time. As far as I'm aware, however, you can't get into hybrid speed density territory with the OFT, which is probably what you're talking about.
Again, I have an EcuTek tune and am perfectly happy with it. My car won't be blowing up any time soon.
Old 04-24-2015, 03:31 PM   #2162
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
Your car, not mine.
Most of those are people either selling their cars or going FI. At least you can resell them at almost full value. Can't say the same for Ecutek.
ApolloSki is offline   Reply With Quote
The Following User Says Thank You to ApolloSki For This Useful Post:
uRBAN_Metal (04-24-2015)
Old 04-24-2015, 03:37 PM   #2163
uRBAN_Metal
Drives: '13 BRZ
This is very true. I used my tablet for over a year and a half and sold it for 50 dollars less than what I paid for it. It is an incredible value for what it is good at, NA tuning for common mods. It's definitely not as powerful or tuner friendly as Ecutek, however.
Old 04-24-2015, 03:42 PM   #2164
ApolloSki
Stealth
ApolloSki's Avatar
I agree. I used my tablet for about a year as well and it worked great for me. Definitely cannot beat a custom dyno tune though, but still decently does the job.
I use my OFT as a monitoring system now until I decide to sell it. Its awesome how they keep coming out with new monitoring features.
Old 04-24-2015, 04:18 PM   #2165
CSG Mike
CSG Mike's Avatar
The irony here is that I dislike EcuTek, but I support it because there just isn't a better (affordable) tuning solution for the platform.
Sigh.
Old 04-24-2015, 05:41 PM   #2166
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Your car, not mine.
Yout speaking a load of arrogant crap. Their are tuners that can use the OFT. If they can use romraider they can use the off. You see issues with people who use the oft for a few reasons . yes, it will occasionally have a problem and will require Shiv to fix, two the OFT is everywhere and very popular among the gt86 crowd. The more users the more of a chance a problem will occur and a thread pops up three, most users of OFT ,admittidely myself, are noobs. We noobs have a lot of questions and make up issues that usually get squashed. Like the guy who leaves his oft plugged in all night and wonders why the battery won't start the next day.
It had its limitations for sure but its a new tuning product and its growing. I hope some day it replaces ecutek because fuck licensing fees and its cheaper.
You pretty much dominate this Jackson thread and I enjoy reading your RD comments but this struck me in a way were I felt compelled to speak up.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 04-24-2015, 05:41 PM   #2167
enivid
enivid's Avatar
Drives: WRB JR BRZED
I know a local guy that tried to tune his kw kit with oft, didn't work so well.
enivid is offline   Reply With Quote
Old 04-24-2015, 05:48 PM   #2168
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
He dominates the thread because he had more experience with the JRSC than everybody, barring JR themselves...
ScionOfHorus is offline   Reply With Quote
Old 04-24-2015, 06:46 PM   #2169
kurbkilla
kurbkilla's Avatar
Drives: Scion FRS (Asphalt)
Sorry if this was covered, I didn't see it.
Can you add the mishimoto cold air intake or any bumper intake to the jackson racing supercharger? Would it make a difference?
I know the kit is intercooler it just seems like you could get cleaner, cold air, then just having an open air filter in the engine bay.
kurbkilla is offline   Reply With Quote
Old 04-24-2015, 07:59 PM   #2170
CSG David
CSG David's Avatar
No. It does nothing special.
The Following User Says Thank You to CSG David For This Useful Post:
kurbkilla (04-24-2015)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
