Old 08-11-2014, 03:21 PM   #85
fatherfork
Fears Hiccups
fatherfork's Avatar
Drives: Toyota badged 2013 Whiteout FR-S
Sorry I've been absent for a while guys. When I sold the car I didn't take the third brake light I made out (because I'm an idiot). So I don't have the original and stupidly didn't take any measurements. I don't really have a way to make these anymore, and I'm not sure I have the motivation I had when I owned the car.
Thanks for the compliments, and good luck to anyone whole wants to make one of these for their 86. It's really not that difficult or expensive and I would encourage anyone who is the least bit inclined to try to build one.
fatherfork is offline   Reply With Quote
Old 08-11-2014, 04:40 PM   #86
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
The Following User Says Thank You to Silver Ignition For This Useful Post:
07jazzrs5gt86 (05-17-2016)
Old 09-10-2014, 02:02 AM   #87
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
finally done
Followed OP's example and got it finished and and installed yesterday.
Name:  headliner 3rd brake light.jpg
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
The Following 2 Users Say Thank You to FLYFISHR For This Useful Post:
BabaYaga (10-07-2014), fatherfork (09-11-2014)
Old 04-23-2015, 04:17 PM   #88
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
I don't suppose you would be willing to send me the templates you used for that, or sned me a rough diagram?
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 04-23-2015, 04:59 PM   #89
FLYFISHR
FLYFISHR's Avatar
I will take measurements and pictures of mine in a couple of weeks when I drop the headliner to add some soundproofing.
The Following User Says Thank You to FLYFISHR For This Useful Post:
MemphisR (04-24-2015)
Old 04-27-2015, 02:11 AM   #90
FLYFISHR
FLYFISHR's Avatar
hope this helps
I did everything as I went along with out any plans. hope there is enough info in the pictures to help.
Old 04-27-2015, 09:19 AM   #91
Silver Ignition
APEXHNTR
They sell an almost exact replica of this on FT86Speedfactory...OP I hope you're involved because if you're not I'd be PISSED.
#1867 of 2500
Old 04-27-2015, 05:33 PM   #92
gtishtar
Drives: 86
if you're referring this one http://www.ft86speedfactory.com/inte...ight-2005.html. Actually it's from intec in japan, https://www.intecjapanstore.com/prod...product_id=116
gtishtar is offline   Reply With Quote
Old 04-28-2015, 09:36 AM   #93
Silver Ignition
APEXHNTR
Originally Posted by gtishtar View Post
Yep...someone check and see if Intec is subscribed to this thread
#1867 of 2500
Old 04-28-2015, 11:32 AM   #94
Rosticles
Drives: 1966 Mustang, 2013 FR-S
It's not a unique idea.
http://www.ft86club.com/forums/showthread.php?t=72225
http://www.ft86club.com/forums/showthread.php?t=75887
Rosticles is offline   Reply With Quote
The Following User Says Thank You to Rosticles For This Useful Post:
codesplice (04-29-2015)
Old 05-20-2015, 03:45 AM   #95
notout86
Drives: GTS 86 auto
Ideally I too would like the light up the top but as a simple compromise,can anyone see a problem with taking the LED-array
and its diffuser out of the housing and just putting it at the base?
I tried just laying it to one side of the housing and it is under half the height and 3inches/75mm closer to the glass making the view
out the back much better. It can actually be pushed in the crack for a simple friction fit.
Possibly a section could be cut out of the shelf to lower it more.
I tucked a bit of black felt under and up over the back and over the top and meeting the glass to stop reflection in the glass
and it will not rub or rattle. It looks neat and would match black felt covering the holes left in the shelf.
The wiring was not long enough for me to try driving around in that temporary position but it would reach if centred.
Any comments before I detach the three-legged monster?
GTS86 Auto (Australia)
Old 05-20-2015, 11:37 AM   #96
Rosticles
@notout86
There is a lot of regulation on the third brake light that I would be afraid of infringing when lowering the CHMSL (Center High Mounted Stop Lamps). "High Mounted" is in the name because it is supposed to be a certain distance higher than the other two brake lights for the purposes of individual distinction and visibility. The entire reason it has UFO landing gear might be to satisfy these requirements. Raising the light only increases the satisfaction of these rules, but lowering it might break them.
Also, this is how I understand it in the US. It may be different in 'Stralia.
notout86 (05-21-2015)
Old 05-20-2015, 11:37 AM   #97
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
My concern with that would be making sure that it's still high enough to be easily visible over the trunk / spoiler (if equipped). I don't think it should be an issue, but that's definitely something to be considered before you do anything you can't easily reverse.
If you do it, we'll need pics
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
The Following User Says Thank You to codesplice For This Useful Post:
Old 05-21-2015, 02:14 AM   #98
notout86
Drives: GTS 86 auto
Thanks Rosticles and codesplice. Yes I guess there is some legal height requirement to explain the OE design. I gave that more thought. I checked with our State automobile club technical advice people and they think it would be ok. As you know, the whole idea of those lights is to allow following drivers to be able to look through rear windows of cars in front and get prior warning of braking.
In the case of lowered cars, the light could be lowered more than I have in mind and I do not think that is ever taken into account. In many cases, up at the roof line is often higher than ideal and cannot be seen.
I am safety conscious (rear view camera fitted etc etc) and the high OE design itself is something of a safety hazard, and when it reflects in the glass, the effective height as seen by the driver is doubled! My proposed lower mod, with black felt sounds like a win-win.
As for re-locating at the top of the glass INSIDE our cars, that is great for view restriction BUT introduces a small rear-passenger head banging hazard.
Compromises wherever you look. I am concluding it would be best to have TWO such lights ...... one low and one high or just stay at home.
The Following User Says Thank You to notout86 For This Useful Post:
codesplice (05-21-2015)
ZILLA: (How-To) *REAR FOG LIGHT WITH BRAKE LIGHT* MOD! ZILLA DIY (Do-It-Yourself) Guides 117 09-19-2017 11:17 AM
**PHASTEK** Rear Fog Light/Brake Light Kit for the Scion FR-S and Subaru BRZ PhastekSport Exterior Parts - Lighting 57 07-10-2017 09:14 PM
4th Brake Light/Rear Fog Light Kit FRS/BRZ/GT86 - $59.95! Vicious LED Groupbuys 58 01-05-2014 06:13 PM
For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! Vicious LED Exterior Parts (Aero, Lighting, Etc.) 9 08-25-2013 08:26 PM
4th Brake Light Mod boredom.is.me Cosmetic Modification (Interior/Exterior/Lighting) 1 12-29-2012 02:46 AM
