Old 04-15-2015, 03:34 PM   #127
0351USMC
0351USMC's Avatar
Drives: 2014 FRS JRSC'd
Originally Posted by churchx View Post
0351USMC: i'd advise to not do both lightweight crank pulley and lightweight flywheel, but choose between them, as some familiar with EJ and FA20 engine maintenance/rebuilding, reported here observed soon appearing bearing failures/heavy wear in cases where both were installed. Rest of pullies - no problems (but of course almost no gains, as stock are not as big/heavy as crank or flywheel ones). And if choice is LWCP or LWFW, imho better go for later one, though then again former might be simpler to replace.
Assuming this proves to be true, what should I look out for to see if this is becoming an issue? If it's not working as well I can pull off the crank pulley as its easier, and it's not as much of a hit on the checkbook when I resell it (but keep the rest of the set).
0351USMC is offline   Reply With Quote
Old 04-16-2015, 02:19 AM   #128
churchx
churchx's Avatar
Drives: 2014 GT86
It's your car, your parts, your choice . In defence of NST view Perrin and FT86 SpeedFactory reps also posted that it should be safe. I myself prefer to play more on safe side, as it's my daily driver car that i plan to use many years to come, and if cited Infamous Performance warned against changing both, probably would go for one of them. He also posted that he prefers lightening FW on manual and CP on automatical. Don't know reasoning behind that, always driven manual shifter only, no clue about specifics for autos, hence planning on using all LW pulleys but CP one, LWFW & carbon driveshaft in future on mine.
0351USMC (04-16-2015)
Old 04-19-2015, 06:56 PM   #129
DC2R
Drives: 2014 Scion FR-S
HMMM I have both a 13lbs flywheel and all lightweight pulleys on the engine I am putting in now only the Crank one has not been installed as I need to use the starter trick once it was on the car.
If these motors are internally balanced I did not expect to have an issue with running both that concerns me as I refuse to not run a LWFW as that provides the best rev response... not to mention I also bought a one piece lighter drive shaft too....
lol yeah i was tempted to jam a wrench against the car and turn the motor over to break the alternator bolt loose. Only ever done it on a $400 buick. Will borrow a impact when possible.
DC2R is offline   Reply With Quote
Old 04-21-2015, 12:25 AM   #130
DC2R
Soooooo I went to the dyno...........
The Following 2 Users Say Thank You to DC2R For This Useful Post:
Hyper4mance2k (04-21-2015), tennisfreak (04-21-2015)
Old 04-21-2015, 12:49 AM   #131
Zaneman
Drives: 2013 BRZ limited
And.....
Zaneman is offline   Reply With Quote
The Following 2 Users Say Thank You to Zaneman For This Useful Post:
Old 04-22-2015, 12:54 AM   #132
DC2R
So I just dynoed my car. Below are my results. According to everything I read I should be at 200 WHP or more.
This would mean that Openflash header, Openflash E85 tune, and a pulley kit net you only 14 WHP?
Filter, stage one, 93:
174 WHP, 143 WTQ
Filter, stage 2 UEL, Openflash header, E85, pulley kit:
188 WHP, 149 WTQ
I was hoping to see what power these added and report back. Unfortunately it seems something else is off. Might start new thread. Don't want to derail this anymore.
Old 04-22-2015, 02:07 AM   #133
churchx
churchx's Avatar
Drives: 2014 GT86
Imho it should be more from just catless header & E85 & of the shelf tune. I'd expect ~ 30hp from these only. Your gains sounds more like for stock tune. For noticeable gains from lightening rotational mass imho also worth to think about lightened drive shaft & wheels for that to play bigger role. Though don't know if it will show up in dyno, it certainly should in real driving.
P.S.
You haven't mentioned, but imho worth to install also aftermarket dropin airfilter, if you haven't already. Should be cheap.
Old 04-22-2015, 06:16 PM   #134
NonStopTuning
NonStopTuning's Avatar
Drives: AE86
174 WHP, 143 WTQ
188 WHP, 149 WTQ
P.S.
A few things to consider when using dynos...
Weather will affect dyno numbers. Going to the dyno today in 70 degree weather and then going back in the future in 90 degree weather will affect numbers. Humidity levels will also affect numbers. Changes in dyno calibration/recalibration can and will also affect numbers. We could go on and on.
This is the exact reason why we always conduct our before and after numbers on the same dyno, on the same day, to try to keep those other factors as unchanged as possible.
Bottom line though, your numbers are up, that matters more than anything else.
Best of luck with all your projects!
NonStopTuning is offline   Reply With Quote
Old 04-22-2015, 06:17 PM   #135
NonStopTuning
Drives: AE86
Any new user reviews, photos, etc?
please
Old 04-22-2015, 08:08 PM   #136
DC2R
P.S.
The first dyno was filter and stage 1 tune.
Same dyno, same weather.
Old 04-27-2015, 10:29 PM   #137
NonStopTuning
Drives: AE86
Anyone else with new pics and reviews?
Old 04-27-2015, 10:44 PM   #138
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I notice they are made from 6061 aluminum. Whats stopping a company from making it out of titanium?
Old 04-28-2015, 03:33 AM   #139
churchx
churchx's Avatar
Drives: 2014 GT86
Costs. For example - are you ready to pay 3x-4x of current price just to have them made of Ti? And even if you are .. it more likely will be one-off, as not much other customers have no budget constraints, hence prices will be even above that. Economy of scale.
(And don't think just of material costs. Tooling may be needed different to cut from ti billets, tooling wear might be different, time and manhours to manufacture and so on ..)
The Following 3 Users Say Thank You to churchx For This Useful Post:
cdrazic93 (04-28-2015), DC2R (04-29-2015), NonStopTuning (04-29-2015)
Old 04-29-2015, 12:00 AM   #140
NonStopTuning
Drives: AE86
AST 5200 Dampers Updated 25th Feb DYNO CHARTS ADDED Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 12-17-2015 06:06 AM
NonStopTuning FRS BRZ Pulley Kit Group Buy NonStopTuning Groupbuys 8 05-23-2015 03:27 PM
NonStopTuning 3 piece Pulley Kit - RED harkbrz Canada Classifieds 4 11-01-2014 01:12 PM
NonStopTuning Short Shifter, Info, Ideas, Feedback thread NonStopTuning Engine, Exhaust, Transmission 5 10-23-2014 11:38 PM
Run in method Dyno charts Surok AUSTRALIA 0 10-08-2012 12:29 AM
