Old 04-19-2015, 10:11 AM   #71
aagun
Drives: 86
just try change clutch oil
aagun is offline   Reply With Quote
Old 04-19-2015, 10:46 AM   #72
SpidyJ
Drives: 2013 FRS
Hmmm......has it worked for you?
SpidyJ is offline   Reply With Quote
The Following User Says Thank You to SpidyJ For This Useful Post:
H_K (11-23-2019)
Old 04-19-2015, 11:21 PM   #73
aagun
Drives: 86
i don't know maybe it help if the sound came from master cylinder .i replace the clutch bearing (bearing locked and fully burned ) and clutch disc (plastic locks for clutch disc springs melted and released the springs )at 80k km and i change oil clutch every 30k km , now it is at 115k km . i heard many sound from my clutch and i ignore it all until it shown any issues.
as i known the clutch system had 18 kind of issues that hard to detected until the parts fault
Old 04-20-2015, 01:09 AM   #74
Astroboy
Astroboy's Avatar
Drives: None
Lol, that sound in the video tho.
Astroboy is offline   Reply With Quote
Old 04-25-2015, 02:36 PM   #75
SpidyJ
Drives: 2013 FRS
Originally Posted by Monogram View Post
This has already been diagnosed and solved by Toyota. It's the accumulator in the clutch master cylinder.
I have an appointment on Thursday with the regional technician guy. The local service manager says the acccumulator in the clutch master cylinder is not the problem.
I hope this doesn't turn into a parts changing fiasco.
Old 04-25-2015, 10:02 PM   #76
ChrisTheMan
Drives: 2013 Rocket Bunny FRS
I'm not sure if you guys have figured it out yet or not but my car was doing that too for me almost every time I shifted with moderate acceleration from 1st to second and second to third. I checked my oil and saw it was low and put in some synthetic 0w-20 and haven't heard the noise since. Cant guarantee it will work for you but that was my fix!
ChrisTheMan is offline   Reply With Quote
Old 04-26-2015, 07:25 PM   #77
SpidyJ
Drives: 2013 FRS
Motor Oil?
Tranny Oil?
Hyrdraulic fluid for the clutch?
Old 05-02-2015, 01:43 PM   #78
SpidyJ
Drives: 2013 FRS
So they told me they diagnosed it with an electronic stethoscope, and the noise is coming from the Clutch Master.....just like Monogram said.
Part on order.
Wonder if they modified the part so the noise won't come back........
Old 05-08-2015, 08:05 AM   #79
SpidyJ
Drives: 2013 FRS
Clutch Master replaced and noise is gone........seems to shift smoother but may be my magination........Toyota woont let me keep the old part. Hope the new one doesn't start honking too after 7k mi.
Jond63 (05-08-2015)
Old 05-08-2015, 03:25 PM   #80
Jond63
Jond63's Avatar
Drives: FR-S Firestorm 2013
Dang, I guess I should bring mine in -- this noise drives me way more nuts than the crickets even!
Jond63 is offline   Reply With Quote
Old 05-11-2015, 01:23 AM   #81
Monogram
Drives: 2014 FR-S
The honk never came back in mine; The crickets, however, that's another story.
Monogram is offline   Reply With Quote
The Following User Says Thank You to Monogram For This Useful Post:
Jond63 (05-11-2015)
Old 09-30-2015, 04:19 AM   #82
slayv
slayv's Avatar
Drives: GT86 -14 "White Pearl"
I have noticed this same sound but I have also managed to investigate how it comes.
If I press clutch and still have some throttle pressed this sound come.
I dont get this sound anymore because I practiced to free throttle pedal before pressing the clutch
slayv is offline   Reply With Quote
Old 09-30-2015, 04:44 AM   #83
Fastbrew
Drives: 2014 Pearl White BRZ
I heard some of this but it turned out to be people honking at me.
Fastbrew is offline   Reply With Quote
Old 02-29-2016, 11:25 PM   #84
timfacchin
Drives:
Hi guys, just wanted to give a VERY long-term follow-up on this in the hopes it may help somebody else. Many thanks to all but especially Monogram for all of his (accurate) assistance.
I took my BRZ in for some warranty work at the end of last winter, one of those issues was this honking noise. Wouldn't you know it, as soon as I brought it in the honking stopped. Turns out, the honking noise is VERY temperature (and possibly humidity) sensitive. I happened to bring the car in on a random 70 degree day. No dice. Got the car back and sure enough, it was mostly gone.
Well, it's winter again here in NY and almost as soon as the temperate entered the 40s the old honk came back. It seems to be at it's loudest between 30* and 45* but I haven't quite nailed down a pattern.
Anyway, I waited for a nice cold patch and brought it in. It took some convincing to have them try the master cylinder on the clutch but they did the work and that fixed my issue. I've had several days since in the bad temperature range and all's been silent. Love it.
Also had them tackle the crickets while it was in...new high-pressure fuel pump and now I don't know what to do with all of the silence. I'm going to need a better stereo.
Thanks again to everyone for all of your help!
timfacchin is offline   Reply With Quote
For the not faint of heart.. NX NOS!!! Kit Sportsguy83 Engine, Exhaust, Transmission 84 03-01-2015 03:54 PM
South Sound Summer Jam 2013 | 8.18.13 | South Sound Speedway RussellM Northwest 13 09-05-2013 10:57 AM
Faint Clutch Smell - 6,000 Miles FnFast Issues | Warranty | Recalls / TSB 8 08-16-2013 05:17 PM
Amp no sound asher187 Electronics | Audio | NAV | Infotainment 8 08-15-2013 07:03 PM
What should the FR-S sound like? 1660 Off-Topic Lounge [WARNING: NO POLITICS] 26 07-31-2011 02:33 AM
