Old 04-19-2015, 08:09 PM   #379
Bader
Drives: 2013 WRB BRZ
I hate being a bother but can someone check this log for me? I would appreciate the input. It's OFT OTS 2.63 93 Octane timings run with our 98 Octane. I did the pull about 15 minutes after cruising on the high way.
http://www.datazap.me/u/baderebra/93...6-7-9-10-13-14
Bader is offline   Reply With Quote
Old 04-19-2015, 08:25 PM   #380
cameronjones239
cameronjones239's Avatar
Drives: 2015 Subaru BRZ Series Blue
I don't think running 98 octane on 93 tune is a good idea.. Even running 93 on the 91 tune isn't recommended. I could be mistaken
cameronjones239 is offline   Reply With Quote
Old 04-19-2015, 08:50 PM   #381
Bader
It's always safe to run higher octane fuel on a lower octane tune.
The issue with 98 RON is that it's not as good as 93 AKI. I'm just testing the fuel here since no one in my area gave me a clear answer.
Old 04-19-2015, 10:34 PM   #382
JB86'd
JB86'd's Avatar
Drives: JAWS
How many miles do you have on the tune? Your IAM is 1 but based on your FLKC, it's not gonna stay at 1.
JB86'd is offline   Reply With Quote
Old 04-19-2015, 11:05 PM   #383
Bader
I logged that pull about 15 minutes after I flashed ecu.
Old 04-19-2015, 11:26 PM   #384
JB86'd
JB86'd's Avatar
Drives: JAWS
I figured. It seems that the IAM won't drop for a while when the ECU is first learning even though you're seeing significant FLKC. Do another log after 50-100 miles on the tune.
The Following User Says Thank You to JB86'd For This Useful Post:
Bader (04-20-2015)
Old 04-20-2015, 12:21 AM   #385
Bader
Will do. Thanks.
Old 04-20-2015, 01:09 AM   #386
cameronjones239
Oops, yup you're right. Was thinking the opposite -_-
Old 04-20-2015, 05:50 AM   #387
Harro
Drives: 2014 Toyota 86
So this is one of my first posts here, thought I would post up a FI log.
I aplogise that the data channels weren't the best, it was a rush to get on the track and I didn't think driving around the track fidiling with the data logger was the best idea
http://www.datazap.me/u/harro/willow...5?log=0&data=8
Harro is offline   Reply With Quote
Old 04-20-2015, 06:12 AM   #388
steve99
Drives: FT86
Yes bit of knock fair bit in some areas
take note of rpm and load where its occurring and pull about half the correction value out of the base timing b map. running the 91 map wont fix it as the only change is timing over 5000 rpm reduced by about 1 degree.
Bader (04-20-2015)
Old 04-20-2015, 06:30 AM   #389
steve99
Drives: FT86
Does not look to bad , although i am no good on fi stuff.
Bit of knock flkc up to -1 degrees so not to bad, Check what your IAM is as you did not log it , should be 1. You could maybe pull a some timing out of the base timing B map where your seeing knock to be safe especially if your going to track regularly.
The oil temps are about 235 c and its been pretty cool in brissie, are you running an oil cooler and 10W30 or 10W40 oil ? as 225C is about the max temp you want to see on 0W20 oil.
Old 04-20-2015, 07:43 AM   #390
Harro
Hey Steve,
Thanks for the look mate, I'll log IAM next time and see what it sits at.
Yeah I'm running the mishimoto oil cooler, although it sits behind the intercooler for the SC - so it maybe getting a stream of hot air. May have to look at running 0-30W oil to get those temps under control.
Cheers for the feedback mate, I really appreciate it - next time I catch up with you at the track I'll make you an instant coffee
Old 05-01-2015, 08:18 PM   #391
Wolvenhaven
Drives: 2013 BRZ 6MT
I have no idea what I'm looking at here, so will you guys help me.
uncatted JDL UEL header
3" JDL overpipe and catted resonated front pipe
3" resonated Perrin catback Perrin intake tube
K&N air filter
Logged after flash(Sg 2 UEL v2.063 93 octane):
Start 125 miles, End 154 miles
http://www.datazap.me/u/wolvenhaven/...l?log=0&data=1
Wolvenhaven is offline   Reply With Quote
Old 05-01-2015, 09:17 PM   #392
phrosty
Did you mean to post a ~13 second log?
phrosty is offline   Reply With Quote
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 02:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 10:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 05:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 10:27 AM
