Old 04-19-2015, 02:18 AM   #1
Thet
Drives: Blue
What to look out for in buying a used exhaust?
Buying a n1 invidia ti tips exhaust 2nd hand
Anything i should be looking out for prior to buying?
Thet is offline   Reply With Quote
Old 04-19-2015, 02:25 AM   #2
Worn or odd shaped flange boltholes or cracked welds will show it was loose or improperly installed.
Scrapes or dents (of course)
Abnormal rust patterns.
Jrryjms07 (04-19-2015), Ultramaroon (04-19-2015)
Old 04-19-2015, 02:28 AM   #3
Holes in the sides are bad. Holes in the ends are ok.
Chimera (04-19-2015), Tcoat (04-19-2015)
Old 04-19-2015, 02:32 AM   #4
Holes in the ends are generally regarded as required although I am sure there is at least one person on here that would debate that.
Old 04-19-2015, 02:59 AM   #5
I'm looking at a used catback that has normal rust patterns. Those are ok, right?
Old 04-19-2015, 03:14 AM   #6
tyrantcf
Drives: '16 WRX, CBR1000RR
Yeah that's fine. It's that really red rust from leaky blinker fluid that you need to look out for.
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
The Following User Says Thank You to tyrantcf For This Useful Post:
Old 04-19-2015, 04:45 AM   #7
Tbird232ci
Drives: 2013 FRS
That would be me.
http://kalecoauto.com/index.php?main...products_id=42
Tbird232ci is offline   Reply With Quote
The Following User Says Thank You to Tbird232ci For This Useful Post:
Tcoat (04-19-2015)
Old 04-19-2015, 05:03 AM   #8
Originally Posted by Tbird232ci View Post
seems legit
2much (04-19-2015), Jrryjms07 (04-19-2015), Tcoat (04-19-2015)
Old 04-19-2015, 10:13 AM   #9
As long as there isn't one shaped like Jesus you should be fine!
Old 04-19-2015, 11:01 AM   #10
Guess I should clarify what I mean by "abnormal rust". Parts that are supposed to be stainless should have no rust at all. If they do then you may not be getting what you are being told you are. Also any welded joint may have a small colour change or even a light coating of rust but if the coating is heavy or extends more then a short distance down the pipe it may have been overheated during welding.
Old 04-19-2015, 11:39 AM   #11
dnieves
Drives: FR-S 10 Series
Article on stainless steel rusting:
http://www.sperkoengineering.com/html/Rust.pdf
dnieves is offline   Reply With Quote
The Following 2 Users Say Thank You to dnieves For This Useful Post:
Tcoat (04-19-2015), Ultramaroon (04-19-2015)
Old 04-19-2015, 02:59 PM   #12
Excellent article. Speaking of "free iron," this reinforces one of the corrosion control practices I learned long ago in the Navy: Never use a wire brush on anything but untreated steel/iron. Ceramic abrasives are electrically neutral and therefore do not promote pitting.
Scotch‑Brite™ for the win.
Tcoat (04-19-2015)
Old 04-19-2015, 03:00 PM   #13
But wouldn't that make it the holy grail of exhaust systems?
Tcoat (04-19-2015)
Old 04-19-2015, 05:58 PM   #14
stock
stock's Avatar
Drives: 2015 FRS Steel (manual)
Mice living in the muffler
stock is offline   Reply With Quote
The Following 2 Users Say Thank You to stock For This Useful Post:
help! buying a used car Abflug Other Vehicles & General Automotive Discussions 0 01-30-2014 06:57 AM
Help with buying an STI Lip Kit merlin2111 Cosmetic Modification (Interior/Exterior/Lighting) 2 06-05-2013 10:35 PM
If you are buying a BRZ how old are you? blackmist27 BRZ First-Gen (2012+) — General Topics 205 03-07-2013 09:18 PM
Why I am buying a BRZ BMWDAD BRZ First-Gen (2012+) — General Topics 37 01-01-2012 10:01 PM
