| Software Tuning Discuss all software tuning topics. |
Drives: 1992 Isuzu PuP, 2014 FR-S
is the ECU a Subaru or Toyota unit?
Title pretty much says it all. Much thanks to anyone who has the answer.
#2 |
Drives: MT Raven Black FRS
It's a Toyobarunit
| The Following User Says Thank You to TJ3000 For This Useful Post: | nickw14 (04-20-2015) |
#3 | |
Drives: FT86
no you cannot just swap out an ecu, they are a coded set ECU Imobiliser and Dash Cluster plus FOB keys. you either swap all components in set or obtain new ecu then get toyota/subaru to re-code the security set. Last edited by steve99; 04-16-2015 at 02:15 AM. |
| The Following User Says Thank You to steve99 For This Useful Post: | RMP (04-16-2015) |
#4 | |
Badass Member
Drives: 2014 SWP BRZ Limited
Edit: Addition to what I said. All imobilizer and alarms are very similar to any toyota..the locking beeping sound is the same as the camry, corolla, and prius. Im pretty sure Subaru and Toyota worked with Denso with the control of the whole vehicle. So recap. Its actually really hard to tell. Last edited by Kayysonie; 04-16-2015 at 08:43 AM. |
#5 |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
It's Toyota hardware with software programmed for/by Subaru. Toyota Techstream logs into it seamlessly. The real nutcracker though is the automatic transmission control unit. I haven't seen any posts about anyone cracking into it yet.
#6 | |
Drives: 2013 FRS, with boost by ATS Racing
...and Tundra. My boss and I can't tell which car is beeping if he hits his '07 Tundra button at the same time I hit my FRS one. It actually might be the same as my wife's IS250..I'll have to give that a listen again. As said, Toyota's Techstream works without fail. Oddly enough though, it is wired like a Subaru. At least the door lock circuit is (WRT to locking the doors with a turbo timer running). |
#7 |
Drives: 2014 SWP BRZ, MT
I'm inclined to say Subaru, it's similar to the electronics in the 2015 WRX ECU, but that doesn't say too much since Denso probably makes that too and they have more of a say in how the low level electronics work as long as it works the way Subaru/Toyota wants it to.
The answer is racecar. Always.
#8 |
Drives: 2015 Series.Blue
D4S system is Toyota's, so I'm inclined to say it's purely Toyota for this...
#9 |
Drives: FT86
The ECU is very similar hardware denso (similar microprocessor) and runs similar software (with added bits for DI/PI to the Subaru Forester, XV ECU, this was why the romraider/tactrix guys were able to "crack" it so quickly.
#10 |
Drives: GR Corolla
Toyota TechStream was able to change the default recirculation on my Monogram HVAC from on to off (fresh air).
#11 |
Drives: Scion FR-S Monogram (Whiteout)
If you got anything from the answers, it's toyoburu
#12 |
Señor Member
@RMP why does it matter?
1974 TA22 Celica
2013 86 GT |
#13 |
Drives: point A to point C. Screw point B!
tl;dr
It's a Denso unit. Toyota and Subaru both use Denso units. So its a moot point trying to label it as a Toyota or Subaru. |
| Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling | Hachiroku | BRZ Photos, Videos, Wallpapers, Gallery Forum | 113 | 11-21-2020 01:02 PM |
| STI ~ Subaru | TRD ~ Toyota | JDM Lanyards & Toyota Emblem Overlay for Scion FR-S! | KI_ZN6 | Groupbuys | 173 | 01-15-2016 01:56 PM |
| Toyota 86 GTS stock head unit won't turn on. | ZN6_88 | AUSTRALIA | 3 | 04-23-2014 08:50 AM |
| Toyota sized Kenwood Navigation unit | Laurie | Electronics | Audio | NAV | Infotainment | 36 | 09-26-2012 12:07 PM |
| Subaru/Toyota Coupe spotted in Socal with Subaru Plates | owsiu | Scion FR-S / Toyota 86 GT86 General Forum | 150 | 05-25-2011 10:27 PM |
