Old 04-16-2015, 12:38 AM   #1
Drakelee117
Drives: Subaru BRZ 2015
Proper maintenance when you have to leave the car for two months?
I have to fly back to my hometown in China for two months give or take a couple of weeks, and I will have to leave my less than 1K miles BRZ in the Sunny Florida for the summer. After that, I will have to drive all the way from Florida to California for college. Is there anything I should be careful about when I leave the car?
I might have to leave it under Sunshine (with cover) but I am trying to see if I can put it in a garage somewhere. Will the battery run out and should I be prepared in case that happens? Also, since I will have to drive more than 3k right after I come back in August and I might not have the time to get an oil change and other inspection, I plan to change it earlier (I wanted to upgrade the transmission oil and break fluids anyways), is that preferable?
Drakelee117 is offline   Reply With Quote
Old 04-16-2015, 01:10 AM   #2
pantdino
Drives: Firestorm 2013 FR-S
My collector cars sometimes sit for 2 months-- no big deal.
But your battery might very well go dead in that time period. If you can put it in a garage and get a Battery Maintainer to keep the battery fully charged it would be a lot better.
Regarding the oil change, Scion stipulates changing every 7.5 months or 7500 miles, so follow those recommendations.
What brake fluid do you plan to upgrade to? DOT 4 is fine and I wouldn't worry about "upgrading" unless you plan track events.
Jim
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 04-16-2015, 01:54 AM   #3
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
Fuel inside the car might begin to expire. Try leaving less than 1/4 in the tank, so when you get back you can fill up on fresh gas.
carma143 is offline   Reply With Quote
Old 04-16-2015, 08:59 AM   #4
Drakelee117
Jim
What if I can't?
Old 04-16-2015, 09:08 AM   #5
WesleyG
Drives: 2014 Satin White Pearl GTS auto
Car will be fine, disconnect the battery if you are concerned that it will run down, but I doubt it.
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto
WesleyG is offline   Reply With Quote
Old 04-16-2015, 10:34 AM   #6
P3tras
Drives: Subaru BRZ '13 WRB
We constantly store car for winter (5 months) a year. Just disconnect battery negative terminal, as battery will discharge (half, if not full capacity). PB batteries wear out very quickly when not full. It would be best to fully charge battery before leaving (with external charger) and leave it disconnected. You will be able to lock/unlock car with key
As for fuel and oil - I wouldn't worry at all. Fuel definitely won't go bad in such time period and oil does not go bad so quickly as well (you could change it every 2 years if you drive rarely). 7 month oil change is recommended taking short drive cycles in mind (warm up, couple miles drive, cool down). When car sits in place oil can definitely sit longer than 7 months.
P3tras is offline   Reply With Quote
Old 04-16-2015, 11:07 AM   #7
ls1ac
ls1ac's Avatar
I leave cars in Fl. each summer when I travel north, if you want to keep the presets and "learned" parameters then a battery tender or a solar charger will be needed. Leaving the tank drained is ok but leaving a partial tank of gas is not recommended as almost every night the temperature drops below dew point, and water condenses out. By filling the tank there is very little air moving in and out from temperature and barometric changes. If you can find fuel with no ethanol "called REC fuel" that is used in boats it will absorb less water. I add stable to the fuel to help keep it from separating. I leave collector cars for extended periods all the time. The very best is to have a friend start and run long enough to get op to running temp every couple of weeks.
Old 04-16-2015, 06:44 PM   #8
torqdork
torqdork's Avatar
Drives: RV-7
What if I can't?
Consider renting a secure storage unit with electrical power.
Having a friend starting it every couple of weeks as mentioned is a good idea. Also, considering the climate, have them run the a/c on full cold, fresh air to floor and w/s while the car warms up to dry condensation and help prevent mold formation.
torqdork is offline   Reply With Quote
Old 04-17-2015, 01:04 AM   #9
Poodles
Drives: 2015 Series.Blue
Not a good idea to leave it so low with ethanol these days. More likely to rust the tank (though I have no idea what our tanks are made out of...)
Personally, I'd throw some sta-bil in, throw some desiccant packets into the car (easy to make your own from silica based cat litter), and either remove the battery (to be put on a tender at some other location) or have the tender at the car.
Personally I'd be more worried about the weather getting to it if it's not in shelter.
Old 04-17-2015, 08:53 AM   #10
Drakelee117
For the battery to charge, should I just keep the car running or do I need to run it at certain speed?
Old 04-17-2015, 04:58 PM   #11
Tbird232ci
Drives: 2013 FRS
This. I've had motorcycle tanks rust quickly and fuel gel in the carbs within a month or two. Fill the tank and use a fuel stabilizer. The ethanol in fuel will absorb water and degrade the fuel more quickly than gasoline of the old days.
Tbird232ci is offline   Reply With Quote
Old 04-17-2015, 05:25 PM   #12
pinski
Stole my avy from zGrinch
pinski's Avatar
Drives: 2015 Audi S3
Two months isn't that long, but you may also flat spot your tires. Best way to keep them from flat-spotting is to get your car on jackstands. You could also get the little rubber pads that you'd roll the car up onto that would inhibit this from happening.
I would also find somewhere that you can store it indoors - a garage or rented storage space. That time out of the Florida sun will do your car a lot of good. Make sure it's clean when you put it away as well... not to mention getting a shiny car out of storage will be that much nicer!
2015 Audi /S3 | Panther Black | DSG
Gone...2014 BRZ, 2010 Lexus IS F-Sport, 2006 Mazda MX5, 1997 Mustang GT
pinski is offline   Reply With Quote
Old 04-18-2015, 12:10 AM   #13
torqdork
torqdork's Avatar
Drives: RV-7
For most Denso alternators like ours I've seen, 2,200rpm+ provides maximum output. Idling won't cut it and become a net negative drain.
The Following User Says Thank You to torqdork For This Useful Post:
Tcoat (04-18-2015)
Proper maintenance for a steady diet of e85 Kronos Software Tuning 44 11-20-2014 02:43 PM
I'll Just Leave This Here... Vicious LED Off-Topic Lounge [WARNING: NO POLITICS] 13 08-24-2013 03:22 PM
Scratches: Fix it or leave it? Mandy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 05-07-2013 11:34 AM
24 Months Free Maintenance? ashtray BRZ First-Gen (2012+) — General Topics 53 02-14-2013 11:30 AM
I'll Just Leave This Here. Asterisked Accolade Off-Topic Lounge [WARNING: NO POLITICS] 11 06-11-2012 09:59 PM
