Old 03-26-2015, 04:17 AM   #491
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
Originally Posted by sixthree View Post
Does anyone have this setup lowered without camber?
I'm deciding between +35 / +45. I have st coilovers installed and my brz is currently dropped 1.4inches. Deciding between getting the +35 or +45. The +45 is a bit cheaper in my area but too many stories of rubbing. No plans on getting a BBK either and not a fan of the poke I see on some of the cars I see on this tread although I plan on getting 245/40/17 tires. Not sure if i'll poke. Sorry for the noob questions. First time getting rims/wheels. Does the stock suspension have a camber adjustment option or do I need to get aftermarket lca/camber bolts/etc
I'm lowered 1" on Hotchkis springs with camber set at -.8 front/0 rear (front camber bolts, rear LCA's). The shoulder of the tire is pretty well flush with the fender up front (barely tucks over bumps). Since you're another half inch lower they would "naturally tuck" a little more, and you may be required to run a slight bit of negative camber to clear the fenders. I went +35 because I'm on lowering springs and wanted more clearance near the spring perch. On coilovers, you will have more clearance with a +45 if you want to avoid any poke (and could use a spacer to bring them out towards the fender slightly if you wanted).
Kwaziekeller is offline   Reply With Quote
Old 04-13-2015, 01:34 PM   #492
congee
congee's Avatar
Drives: SSM BRZ
Whats everyone using to clean their rpf1s? I just got my black rpf1s and looking to clean it safely and maybe apply a sealant or wax. Any recommendations?
congee is offline   Reply With Quote
Old 04-13-2015, 02:30 PM   #493
SG02WRX
SG02WRX's Avatar
Drives: SWP WRX HATCHBACK
Best stuff on the market. Sonax wheel cleaner.
http://www.sonaxusa.com/tag/sonax-wheel-cleaner
SG02WRX is offline   Reply With Quote
Old 04-13-2015, 02:52 PM   #494
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Here is my baby with her new wheels. Enkei RPF1 with Hankook RS3 245/40/17. I am headed to my favorite road tonight to snap some better pictures. Check out my build thread for more.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 04-13-2015, 03:05 PM   #495
congee
congee's Avatar
Drives: SSM BRZ
I was looking into this as well. Do you recommend the regular or clean plus???
Old 04-14-2015, 01:27 AM   #496
JS + BRZ
Drives: 2010 MS3
Looking good. How did you get those white writing on the tires? Looks pretty cool.
This is mine.
I'm actually trying to find the same wheels in black for a trade. Please let me know if any of you have the black ones and want to trade for silver ones!
BRZ+335 by JS + MS3, on Flickr
Old 04-14-2015, 01:40 AM   #497
2much
I wanna go fast
Drives: 2013 FR-S 6MT
No...
dont!
2much is offline   Reply With Quote
Old 04-14-2015, 01:43 AM   #498
nyfries
Drives: 14 FRS Whiteout
Yea silver are much more rare than the black one. On the note of white lettering. I Rememebr seeing a documentary on RWB porsche. Nakai apply the white lettering by cutting out the stencil of the letter and than spray painting it white. Not sure if it's the same method here
nyfries is offline   Reply With Quote
Old 04-14-2015, 07:24 AM   #499
Takumi788
JHerbert Racing
Takumi788's Avatar
I used an oil based paint pen you can get at any craft store. When I did this last year I bought a Sharpie version. This year I couldn't find the Sharpie and went with a brand called Craft Smart. It works really well. Buy the thinnest marker possible or else it comes out looking like a 2nd grader did it.
If you are interested, I added better pictures in my build thread
Old 04-14-2015, 10:50 AM   #500
nyfries
^cool ! How long does the lettering last?
Old 04-14-2015, 11:45 AM   #501
Takumi788
JHerbert Racing
Takumi788's Avatar
Its is still on my old wheels that I did a number of autocross and track days on. Its pretty permanent.
Old 04-20-2015, 12:16 PM   #502
nastynate88
nastynate88's Avatar
Drives: 2014 BRZ
Gooooooooooold
Everything's been installed and dialed in. Special thanks to Anthony@Oakos for all of his help and excellent customer service!
nastynate88 is offline   Reply With Quote
Old 04-23-2015, 12:06 PM   #503
KayC
Drives: 2013 whiteout FRS 6mt
KayC is offline   Reply With Quote
Old 04-23-2015, 12:12 PM   #504
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
Originally Posted by KayC View Post
Suspension info? Looks great.
Jesse36m3 is offline   Reply With Quote
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
