Old 04-03-2015, 06:57 PM   #309
swarb
Originally Posted by Kelbyat07 View Post
5k? I was planning to change my oil every 3,500 miles bcause I will be using E85. Do you think 5k would be safe for me
You really don't know unless you send your oil out for testing. You can look at other people's test results with a similar setup, but in the end everyone drives different and in different environments/fuel/car/oil/etc.
2013-2014 factory recommend interval is 7,500miles.
2015(brz at least) is 6,000miles
Suggested/recommend cut in half when running e85.
But look at the test results, some people have good test results and some can run up to 10k on a stock setup.
Do whatever you are comfortable with, get it tested and go from there. I would suggest 4k(your 3,500 ok too) and get it tested, good medium between 3k and 5k, while be a little bit on the safe side.
Old 04-03-2015, 08:06 PM   #310
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
Going to do my 2nd oil change at 5000 miles. I'm at 4600 right now. Did my 1st oil change at 2500 with Eneos Sustina.
For this 5000 mile change, i'm going with Royal Purple. Should be interesting!
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
Old 04-04-2015, 12:57 AM   #311
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
Alright thanks. I think all I have to worry about right now is which brand of oil to use haha
Kelbyat07 is offline   Reply With Quote
Old 04-04-2015, 06:58 AM   #312
troek
troek's Avatar
Drives: 2012 Toyota 86
Originally Posted by marky View Post
Nice.. looks like I'll be running 5-30 from now on ince I get running again..
N/A or forced induction power?
NA, and yeah i meant 5w30, the hks oil i buy here is 5w35 for some odd reason. it even says on the can its equivalent to 5w30... lol
troek is offline   Reply With Quote
Old 04-04-2015, 07:06 PM   #313
BC-Boy
BC-Boy's Avatar
Drives: 2013 Brz sport-tech
I run 1 quart mobile 0w40 11.99$ and top up the remaining 4quarts with mobile 0w20 39.99. Oem filter , used to run amsoil 0w20 signature it burnt 1-1.5 quarts in a 5000km cycle, i also ran toyota 0w20 and the mobile mix i find keeps the engine very quiet and burns no oil at all, redline mt90 is my favorite in the trans keeps it quiet on idle and shifts silky smooth compared to oem or amsoil 75w90 gl4 mtf
BC-Boy is offline   Reply With Quote
Old 04-04-2015, 07:09 PM   #314
BC-Boy
BC-Boy's Avatar
It nets me a 0w25 ish heavier 20 weight i prefer the one quart 0 40 to half half with 0 30 just outta personal preferance
Old 04-04-2015, 09:30 PM   #315
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
Not bad, I have mixed some 5w-30 with the 0w-40 before. Mobil 1 (on their website) has an official post in their FAQ section using those two as a comparison saying it is safe to mix. Personally, I like the higher zinc in the 0w-40. The 15w-50 also offers the higher zinc as well. It just easier to get these oils at walmart and auto stores vs other oils that may need to be special ordered.
Shot some pictures off of Mobil 1's website on the oils for you guys. Furthermore, the link attached is a current rebate offer Mobil 1 is doing until 31-MAY-2015 on getting $15 off 5qts and 1 oil filter. It's a great deal
https://apfco.net/secure/R8235W/Home/Entry
Name:  Screen Shot 2015-04-04 at 8.22.36 PM.jpg
Name:  Screen Shot 2015-04-04 at 8.23.01 PM.jpg
Name:  Screen Shot 2015-04-04 at 8.23.22 PM.jpg
Name:  Screen Shot 2015-04-04 at 8.29.51 PM.jpg
shiro is offline   Reply With Quote
Old 06-06-2015, 07:34 AM   #316
keonigt
Drives: 2022 BRZ
Which mobil 1 0w-20 oil do you recommend?
- Extended performance, super synthetic, or advanced fuel economy
keonigt is offline   Reply With Quote
Old 06-08-2015, 04:40 AM   #317
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Monil 1 or royal purple. Ive seen how RP treats internals.
Old 06-08-2015, 10:48 AM   #318
JellyForSale
That Striped FRS
JellyForSale's Avatar
Drives: 2013 Ultramarine FR-S 6MT
I use Royal Purple in everything from atv's to Diesel Trucks, always treated me well.
JellyForSale is offline   Reply With Quote
Old 06-08-2015, 01:10 PM   #319
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
What was the reason you stopped using Sustina and began using RP?
Old 03-11-2017, 09:15 PM   #320
Prax
Drives: 2017 BRZ Inazuma Edition
I'll just leave this here. Old thread I know, but none the less.
Japanese BRZ manual recommends up to 5w40. Maybe this is already known.
[IMG]https://uploads.tapatalk-cdn.com/20170312/3***3ba488e958270564ce590744e5be.jpg[/IMG]
Sent from my Nexus 6 using Tapatalk
Prax is offline   Reply With Quote
Old 03-12-2017, 12:02 AM   #321
Prax
This is also the high-performance specs for oil recommended by Subaru in Japan:
LES PLEIADES Zero 0w30.
It's specs are just slightly lower than Mobil 1 Full Synthetic 0w40...
Old 03-12-2017, 01:07 AM   #322
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I use all 0w30 mobile1 for the full oil replacement and have for the past 35k. I recommend the 0w30 and oil change between 4K and 5k.For trans I've been using motul 500 which can making shifting in 1st rough when cold but nice and buttery once everything warms up.
DandoX is offline   Reply With Quote
