#141 |
rekt ☑ not rekt ☐
| The Following 5 Users Say Thank You to Ultramaroon For This Useful Post: | Andrew025 (03-28-2015), fatalelement (10-06-2015), gramicci101 (03-28-2015), JustBoostin (04-08-2015), Koa (03-28-2015) |
#142 |
Drives: UK GT86
The AVCS doesn't impact the valve lift, in Subaru terms that's AVLS
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | Koa (03-28-2015) |
#143 |
Drives: MY15 86 GTS
This guy is a TROLL right? Has to be !
#144 |
Kuruma Otaku
No.
He's just stubborn and does incomplete research on ideas he has an insufficient grasp on. None of the fundamental concepts he writes about are truly incorrect. But how he interprets them usually is. For example, reversion is a thing, and it's bad. But physical anti-reversion systems can also interfere with another aspect of wave tuning that is good. Make sense?
Because titanium. |
| The Following 3 Users Say Thank You to Dimman For This Useful Post: |
#145 | |
Custom User Title
Drives: Asphalt FR-S MT
Well I'm gonna go show people how square wheels are better.
| The Following 2 Users Say Thank You to boredom.is.me For This Useful Post: | mig86 (03-28-2015), Ultramaroon (03-28-2015) |
#146 |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
The strange thing about the anti-reversion header, was that it didn't suck any worse than it did. In fact, it didn't start restricting power till it got over 5500 RPM. What this showed me is that the place to make changes is in the ECU, not in the header.
I'm re-installing my catless midpipe right now. My MPG will go down, but with the right AVCS tuning I should be able to reduce the duration on the exhaust to compensate for having less back-pressure. I can change this just for the RPM range up to 3000, so I can still have performance when I need to, but better mileage when I don't. For those snarky sarcastic bastards that just have to pick on everything I do, Here's some cannon fodder for you; I'm currently REMOVING the sway bars from my car to give it a better ride. How's that for an idea? Totally insane right? |
#147 |
#148 | |
Drives: Neptune GR86
Every time I see you say "back pressure", it shows you have a fundamental misunderstanding of exhaust.
![]() Last edited by Andrew025; 03-28-2015 at 10:09 PM. |
| The Following 2 Users Say Thank You to Andrew025 For This Useful Post: | Hyper4mance2k (03-31-2015), wparsons (03-31-2015) |
#149 |
Why, to prevent yourself from breeding?
Reducing the exhaust AVCS retard amount closes the exhaust valves sooner, reduces overlap, increases cylinder fill %, and increases the compression ratio. I might even have to back off the timing a smidge also, since a higher CR increases the chances of detonation. |
#150 |
Because compromise ®
Drives: Red Herring
A square wheel is much better than a triangular wheel because it has one less bump per revolution.
| The Following 4 Users Say Thank You to Captain Snooze For This Useful Post: |
#151 | |
You would think someone with your amount of "knowledge" would do some better testing as well considering you're trying to prove pretty much everyone on here wrong.
![]() Last edited by Andrew025; 03-28-2015 at 10:31 PM. |
#152 | |
Alexandrino_Auto
Drives: series.Blue
Where do you learn these things? I suggest reading a book on basic automotive engineering, or taking a class before you go any further. I'm not trying to be a jerk, but seriously... Go take a class at your local CC, or UTI, or something, anything. You know the basic terminology, but your understanding is fundamentally flawed. I really am starting to think you might just be the biggest, most epic troll and you're just pranking everyone.
The Shadetree Project: I turn wrenches
| The Following 4 Users Say Thank You to Hyper4mance2k For This Useful Post: |
#153 | |
Trust me, I'm the Doctor
Thanks for the lesson (without the math... otherwise I'd need to go dig up my old college notes).
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#154 |
Drives: Lightening Red BRZ Ltd.
Hey, can't knock this guy. He had an idea, experienced with it, and reported. At the minimum, we all learn something from the discussion in this thread. Kudos for trying and getting ideas flowing. There's something to be said about experimenting and learning things first hand rather than from a book or a forum.
| The Following 3 Users Say Thank You to himbo For This Useful Post: |
| Tags |
| guy knows nothing, world's last, zero facts |
| Wtb ft86 uel header | 86socal | Want-To-Buy Requests | 1 | 08-23-2014 10:00 PM |
| Anti A-Hole Button | ButtonMasher | Off-Topic Lounge [WARNING: NO POLITICS] | 45 | 07-25-2014 01:55 PM |
| Eibach Anti-Roll Kit | babykwiss | Canada Classifieds | 1 | 07-14-2014 10:29 AM |
| Fastest FT86 in the World 9.10@256km/hr! | Bahraini86 | Forced Induction | 94 | 02-19-2014 01:25 PM |
| is it necessary to change anti-roll bar? | yuli8466 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 06-25-2012 11:58 AM |
