Old 03-26-2015, 03:06 PM   #15
P_say86
Drives: '13 asphalt frs
Originally Posted by JB86'd View Post
Did you undo the overpipe to front pipe connection??
No but I'll try that too
P_say86 is offline   Reply With Quote
Old 03-26-2015, 03:13 PM   #16
JB86'd
JB86'd's Avatar
Drives: JAWS
That's your problem. Undo the overpipe to front pipe connection (use PB Blaster or wd-40 and let it sit for at least a few minutes before trying) after that get everything lined up with bolts hand tight, then start tightening at the header to engine bolts. Then tighten the overpipe to frontpipe. Then torque everything in that same order. If it still doesn't line up, you have a fitment issue.
JB86'd is offline   Reply With Quote
Old 03-26-2015, 03:14 PM   #17
BlackMonarch
Drives: Red BRZ
Never seen fitment issues on a Tomei... The flange isn't bent or anything is it? Also; I'd strongly reccomend disconnecting everything from the header itself, and then installing the header. No over\downpipe etc, just the header alone going on, and then connect everything else.
BlackMonarch is offline   Reply With Quote
Old 03-26-2015, 03:23 PM   #18
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
When you say other side is on makes me think you pushed in one side completely, you do know you should try and push in both sides at the same time, making the studs come through evenly?
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
The Following User Says Thank You to yomny For This Useful Post:
strat61caster (03-26-2015)
Old 03-26-2015, 03:57 PM   #19
zastoke
I feel like you are doing something incorrectly here. I bought my UEL tomei from myjdmparts on Amazon two weeks ago, and had infamous performance install it last week. They had no fitment issues, and the car runs and sounds great.
zastoke is offline   Reply With Quote
Old 03-26-2015, 04:05 PM   #20
Teseo
Drives: frs
Or you can go to a muffler shop for installation.
Old 03-26-2015, 04:10 PM   #21
Koa
people who are saying I had no issues when I bought my Tomei aren't winning
people who are suggesting the dude takes 10 minutes to undo all exhaust components before attempting the header are winning
The Following User Says Thank You to Koa For This Useful Post:
Bergen23 (03-26-2015)
Old 03-26-2015, 04:19 PM   #22
BlackMonarch
Drives: Red BRZ
I did both. What now?
The Following User Says Thank You to BlackMonarch For This Useful Post:
Koa (03-26-2015)
Old 03-26-2015, 04:21 PM   #23
Koa
you sir broke my equation
The Following 3 Users Say Thank You to Koa For This Useful Post:
8R6 (03-26-2015), BlackMonarch (03-26-2015), DieselDog (03-26-2015)
Old 03-26-2015, 04:50 PM   #24
vroom4
Did you loosen the joint and try to spread it apart or push it together to make it fit?
vroom4 is offline   Reply With Quote
The Following User Says Thank You to vroom4 For This Useful Post:
RobertPaulson (03-26-2015)
Old 03-26-2015, 05:06 PM   #25
P_say86
I took a hammer and tap it a couple times till it went in. End of story haha
The Following User Says Thank You to P_say86 For This Useful Post:
chas3wba0 (03-26-2015)
Old 03-26-2015, 05:07 PM   #26
P_say86
P.s I tried everything and every suggestion
Old 03-26-2015, 05:36 PM   #27
vroom4
Ok, well that is the correct method, so congratulations.
Make sure you re-torque in a few days.
MokSpeed (03-26-2015)
Old 03-26-2015, 06:15 PM   #28
tennisfreak
Drives: 2018 BMW M240i
Use a blowtorch, they solve every problem
WTB Tomei Type 80, Tomei UEL headers Justin91M Want-To-Buy Requests 1 12-19-2014 12:42 PM
FAIL! X3 paulca Other Vehicles & General Automotive Discussions 9 07-29-2014 07:27 PM
Tomei Exhaust with Tomei Straight Pipe leech Engine, Exhaust, Transmission 10 01-07-2014 11:42 AM
fail BRZPDX Northwest 24 11-21-2013 08:24 PM
If the FT-86 is a fail...what will you do? SteelReign Scion FR-S / Toyota 86 GT86 General Forum 172 04-28-2011 03:49 AM
