Old 03-24-2015, 10:27 AM   #29
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
OP, I have an FI FR-S with over 27K since the install (29K total). I've had zero issues with the kit. I've only tracked it once, and DD it ~70 miles. I'm not saying it's been perfect, but it's been very reliable.
kmbkk is offline   Reply With Quote
The Following 3 Users Say Thank You to kmbkk For This Useful Post:
Koa (03-24-2015), pdhami (05-25-2015), Tcoat (03-24-2015)
Old 03-24-2015, 10:53 AM   #30
Koa
Originally Posted by industrial View Post
I don't agree with most of what you say. The ringland issue exists but it's blown way out of proportion. I know all about the ringland "issue", I owned a 08' sti afterall. Read all about it on the forums but most of the time, it was people issues. Running intakes & downpipes without a tune, not keeping track of oil burning issues, bouncing off the rev limiter, etc. I met a guy yesterday that hasn't had to change his STI motor, not even once! That's what I call a bulletproof motor!~ Save the anecdotes for the fox news crowd.
Yeah, the evo makes more power than the sti with less mods. Therefore the sti is shit. Got it.
Yeah, the tmic will heat soak if your doing back to back drag strip runs or on the dyno. For the track? Seriously? Can't even do mild track use with a TMIC? Where do you even get this horseshit?
Ringlands for those 25x's were a point of failure across the board.. I agree with you that it has been blown into a damn near witchhunt on iwsti and nastysoc,
The truth is the engine is very sensitive to detonation and yes, with those shitty ass intakes, crap tune, poor maintenance and subaru's emissions-centric tuning paradigm that caused such a horridly long closed-to-open loop transition, the EJ25x has received a bad rep as being an unreliable that I believe is unfounded. I took my shitty EJ205 to 200k, 100k of that pushing the limits of that TD04 and on E85 for around 1/4 of that time.. WITH trim problems trying to shadetree tune it myself w/ modified XPT maps on RR
I don't think they're unreliable if one keeps an eye on oil consumption and common sense not to starve the engine out on high G, high load turns....
The reality is that we're seeing failures because of people's lack of due dilligence, treating it as an American iron block pig when it's a dainty, quick little duckling. A nimble one, but not too strong
but I do think they're a very expensive to mod engine, with exponential increase in cost as one ratchets up the limit of the platform. It's the nature of the beast, they aren't well seen over 450-500whp reliably for less than a full build and you know that being an owner of one and seeing whats happening in the community
The Following User Says Thank You to Koa For This Useful Post:
industrial (03-24-2015)
Old 03-24-2015, 11:52 AM   #31
BRZerk
Some guy in a white car
BRZerk's Avatar
Drives: 2013 SWP BRZ Limited
what kit and supporting mods do you run? do you have a build thread?
2013 Subaru BRZ Limited 6MT - Satin White Pearl
BRZerk is offline   Reply With Quote
Old 03-24-2015, 12:09 PM   #32
MAPerformance
Drives: Asphalt FRS
I also have 27k miles on my FRS, installed our turbo kit on it since 13k. No issues what so ever daily driving it (summer, fall, winter, spring). I do have our oil cooler kit and Mishimoto radiator just to be safe. However, I do not track the car or anything like that, but it is driven aggressively on the street. FI any car is a gamble no matter what, and you have to accept that risk. Especially your daily driver. It's been said a million times, if you can't afford the risk (blown engine etc) down the road, simply do not do it and enjoy the car the way it is. But it's a fun risk for sure. Keep the power at a reasonable level, good tune, keep an eye on everything, maintain it, and it should give you years of joy!
MAPerformance is offline   Reply With Quote
The Following 2 Users Say Thank You to MAPerformance For This Useful Post:
kmbkk (03-24-2015), Ny Brz (03-24-2015)
Old 03-24-2015, 12:21 PM   #33
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
I'm running the Treadstone kit. They used my car to R&D the kit, and did the install. I did have the car re-tuned last fall by JAMESM to smooth it out some. As for supporting mods I'm running a full 3" TBE, not other power mods. I do have a Koyo radiator to install and I'm considering an oil cooler.
Link to kit build thread: http://www.ft86club.com/forums/showt...ght=treadstone
Old 03-24-2015, 02:16 PM   #34
Ashikabi
Ashikabi's Avatar
TLDR; TRD supercharger doesn't void warranty right? More power plus reliable enough Toyota isn't worried about replacing engines
Old 03-24-2015, 03:04 PM   #35
Model Citizen
Lacking brains
Drives: frz
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 03-24-2015, 03:06 PM   #36
Ashikabi
Ashikabi's Avatar
Well correct me if I'm wrong but I was under the impression that if you got it installed thru the dealer it didn't void warranty. Ergo it must be sedate enough the dealer isn't worried about reliability.
Old 03-24-2015, 03:26 PM   #37
Scottemad123
Drives: 2014 SWP BRZ Limited
IIRC, the TRD supercharger was a race only unit and you were forced to buy two at the kings ransom of 27k.
Scottemad123 is offline   Reply With Quote
Old 03-24-2015, 03:29 PM   #38
Ashikabi
Ashikabi's Avatar
Why 2?
Old 03-24-2015, 05:02 PM   #39
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
So nobody other than professional race teams would buy it. It wasn't a consumer level TRD part. I believe they were 25k each, 50k total for the TRD FI system with a spare.
industrial is offline   Reply With Quote
New to me daily driver.. 95 M3. Dave-ROR Other Vehicles & General Automotive Discussions 58 07-17-2014 03:05 AM
Is your FR-S your daily driver? Drive Scion FR-S / Toyota 86 GT86 General Forum 136 02-10-2014 10:10 AM
FRS as a Daily Driver? Pake1 Scion FR-S / Toyota 86 GT86 General Forum 104 08-16-2012 12:48 AM
Will the BRZ be your daily driver WRXGuy1 BRZ First-Gen (2012+) — General Topics 47 05-23-2012 01:15 PM
BRZ as daily driver? Pakjk89 BRZ First-Gen (2012+) — General Topics 80 03-22-2012 10:50 AM
