Old 06-29-2014, 10:03 PM   #1
DAEMANO
Time Traveller
Wheel Directory: WedsSport SA-10R 18x8.5 et 45
@DarrenDriven Adding because I don't see this width (8.5") in the directory.
Dunlop Direzza DZ102 235/40/18
RS-R Sports-i -1.2" F/R
Flat caps are on order so shush! There's one on the front in the second image. Ghetto IK.
The Following 7 Users Say Thank You to DAEMANO For This Useful Post:
botbs (11-02-2014), ericmpena (06-30-2014), sergiomordo (03-24-2015), SkAsphalt (06-30-2014), trigger happy (05-15-2016), ultra (04-04-2015), WRB5titch (07-07-2014)
Old 06-29-2014, 10:42 PM   #2
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
That's a great looking wheel! Does it come any wider!
RiskyTrousers is offline   Reply With Quote
The Following User Says Thank You to RiskyTrousers For This Useful Post:
DAEMANO (06-30-2014)
Old 06-29-2014, 10:45 PM   #3
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
^ Yes, 18x9.5 +45. I wanted flat caps for my set, as well, but $160 for the set is ridiculous.
sdemo is offline   Reply With Quote
The Following User Says Thank You to sdemo For This Useful Post:
Old 06-30-2014, 01:21 AM   #4
DAEMANO
Time Traveller
Yep @sdemo and @Ny Brz rock 18x9.5"s that also look incredible. I chose 18x8.5 to run a square setup, to keep the weight down and visually I felt the concavity of the 8.5 suited the car just as well. Thanks!
Old 06-30-2014, 01:25 AM   #5
DAEMANO
Time Traveller
Yep the caps are pricey. I bought one just to see if I would like it and have the other 3 now on order. Got mine for $33 ea. from a famous vendor I won't name because their service has been very poor. I found that Nengun has a set of 4 for only $90, but shipping cost is unknown. You may check them out for a quote.
http://www.nengun.com/weds/center-caps
Old 06-30-2014, 08:23 AM   #6
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
Were caps not included with your wheels?
Ny Brz is offline   Reply With Quote
The Following User Says Thank You to Ny Brz For This Useful Post:
Old 06-30-2014, 10:16 AM   #7
DAEMANO
Time Traveller
Standard caps and some nice valve stems were included. I preferred the flat caps instead.
Old 06-30-2014, 11:29 AM   #8
Ny Brz
Hella Flush
Ny Brz's Avatar
Ahhhhhh i c......The flats do look nice but the free ones will do me just fine.
Old 07-01-2014, 12:30 PM   #9
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
Looks freaking gorgeous, do you know if they make 17s?
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
calmtigers is offline   Reply With Quote
The Following User Says Thank You to calmtigers For This Useful Post:
DAEMANO (07-01-2014)
Old 07-01-2014, 06:11 PM   #10
DAEMANO
Time Traveller
Thanks, I got the flat caps installed today. Now going to go a tad lower and maybe slip in a spacer, after that I feel like the wheel part is set. Yellow calipers anyone?
Here's a pic
To answer your question, Yes, there is a 17x7.5 et 48! I think it was supposed to make it to the US this summer.
Here's a pic (darker lugs and maybe flat caps would take it up a notch (IMO)).
Specs are here:
http://www.wedswheelsna.com/wp-conte...port_SA10R.pdf
The Following User Says Thank You to DAEMANO For This Useful Post:
calmtigers (07-01-2014)
Old 11-02-2014, 03:02 AM   #11
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Here is my winter set-up 18x8.5 +45.
Pictures will be uploaded once I have my flat centre cap installed =)
botbs is offline   Reply With Quote
The Following User Says Thank You to botbs For This Useful Post:
DAEMANO (11-02-2014)
Old 11-07-2014, 01:56 AM   #12
botbs
botbs's Avatar
Stock Height =)
The Following 2 Users Say Thank You to botbs For This Useful Post:
DAEMANO (03-23-2015), trigger happy (09-30-2015)
Old 03-23-2015, 03:37 AM   #13
steveholt
Drives: 2015 BRZ Limited 6MT
do you use hubcentric rings? if so any issues with the center cap fitment with the centering rings installed?
steveholt is offline   Reply With Quote
The Following User Says Thank You to steveholt For This Useful Post:
Old 03-23-2015, 04:22 AM   #14
DAEMANO
Time Traveller
I only have the wheels removed by mechanics experienced enough to know how to re-install wheels properly without rings. No hub rings needed or used. btw, here's a more recent pic.
@CSG Mike - If you like you can add this sizing to the wheel directory now that you've taken over for Darren
steveholt (03-23-2015)
18x8.5, sa-10r, sa10r, weds, wedssport
Wheel Directory: BBS RS-GT 18x8.0 +40 raptor87 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-09-2014 07:01 PM
Wheel Directory: BBS LM 18x8.0 +50 stoneman155 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 07-08-2013 08:55 PM
Wheel Directory: TSW Nurburgring 18x8.0 +45 / 18x8.0 +35 mike_ekim1024 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 04-10-2013 07:35 PM
Wheel Directory: WedsSport Maverick 210S 18x8.0 +?? / 18x8.5 +?? quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-04-2012 01:07 PM
Wheel Directory: Blitz BRW Profile 08 18x8.0 +45 / 18x8.0 +38 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-27-2012 04:34 PM
