Old 01-07-2015, 09:14 AM   #127
Foobar
SLO NO MO
Foobar's Avatar
I use my AC all the time, stage 1 vortech v3 kit, using the belt that came with it. Had the kit in place since spring 2013 and haven't had any issues. No issues downshifting either.
The Following User Says Thank You to Foobar For This Useful Post:
Jman1759 (01-08-2015)
Old 01-08-2015, 07:58 AM   #128
AJPG
Drives: 22RE, FA20, 4G63
Originally Posted by Jman1759 View Post
Hey fellas, I have read your warnings and prepped for my Vortech kit. I have upgraded the radiator, clamped all the hoses, installed catch cans, installed the check valve, and am ready for install this weekend. A couple questions from my reading:
1) some have said they no longer use the AC to reduce stress on the belt. Is this overkill? I live in the PNW and the air is always wet, I am always using the defroster with the AC. Thoughts?
2) some have mentioned this belt also will struggle under regular downshifting. I am a daily driver, no track. Should I start learning how to de-celerate with no downshifting and just invest in extra brake pads? Thoughts?
Hi
It is completely dependent on your driving habits...
Off course you can down shift and use your AC and if you drive like a normal person the belt could last as long as the original one (without the stress of the blower)... BUT you have to understand that the belt was design for certain amount of power, and the belt (black or blue) could move the blower with ANY pulley. In my case everything was and is aligned (SC, belt, pulleys) but if I try to use my car as I fly my motocross bikes I have change belts 3 to 4 times per oil change (3k miles), and I believe that's not so bad, if I went the turbo way and drive like I run out of medications maybe the engine and/or the trany were the things braking.
So it is a good idea to have an additional belt and some basic tools on the trunk, it doesn't hurt and could be change in 15 min without removing the sc.
Enjoy
AJPG is offline   Reply With Quote
Old 01-08-2015, 01:47 PM   #129
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
That is ridiculous.
Whatabouteggs is offline   Reply With Quote
Old 01-09-2015, 07:16 AM   #130
AJPG
Originally Posted by Whatabouteggs View Post
That is ridiculous.
Yup, that's why I change the way I drive, specially down shifting. If you try to get hot to a tight turn (late braking and down shift "aggressive" so the rpms get close to the rev limiter with the rear tires braking traction just before full throttle again "that could be 2 or 3 gears at the same time" (on the AT cars you can even down shift 4 gears at the same time)... But all that spinning in so little time is NO good for the belt... Also change the differential bushings (they start early wear noise) and yes this is abusing from the car, but that's why I didn't buy something expensive
So yes you can down shift, you can up shift, you can use you AC and you can even go to track events and the unit would hold.
As side note: it is more "rewarding" (and would let you know you car better) to take the turns in 3 or 4 gear at 35-45 mph... But then a little bit of more midrange would be welcome. Already with the 4.88 final drive.
Anyway take care and have fun
Old 02-15-2015, 02:22 PM   #131
Joeprelude
Joeprelude's Avatar
Drives: 2013 FRS, 2002 WRX Wagon
What size belt are you guys running? I was having to change my belt almost every 1000 miles (Gates Blue K060975rb). Emailed Vortech and they said that is the wrong size (even though manual states 97.5" belt) and stated that the k060970 (97.0") belt is the correct size on the 9psi pulley. Too bad gates doesnt make the blue belt in that size, or i just can't find it on their site.
Joeprelude is offline   Reply With Quote
Old 02-16-2015, 08:34 AM   #132
Foobar
SLO NO MO
Foobar's Avatar
Still on my original belt that came with the kit.
About 8.5k miles, 2 years. All seasons.
Old 03-09-2015, 05:50 PM   #133
RedFR-s
Builder/Driver/Enthusiast
RedFR-s's Avatar
Drives: 2013 FR-S 6MT Turbo Firestorm
Is anyone running the Vortech V2 with an OFT tune? I'm putting together a custom kit and I'm hoping to not have to replace my OFT.
Andy
1977 Triumph Spitfire 1500 - New Project
2013 Firestorm FR-S 6MT Turbo - Sold
2013 Honda CBR 250 Repsol- Toy
2017 Toyota Tacoma - The Rig
RedFR-s is offline   Reply With Quote
Old 03-09-2015, 05:51 PM   #134
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
The OFT supports the Vortech version 3 with stock pulley. You will need a different tuning solution with the 3
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
The Following User Says Thank You to Boofneenee For This Useful Post:
RedFR-s (03-09-2015)
Old 03-09-2015, 06:01 PM   #135
RedFR-s
RedFR-s's Avatar
I knew about the V3 in the OFT300 Kit. Wasn't sure how close they'd be since the V2 and V3 are very similar.
Worst case I'll have to put together a custom tune.
Andy
Old 03-09-2015, 06:39 PM   #136
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
If the boost curve is the same I'm not sure what would need to change in the tune? I would log a lot and make sure everything is ok but at the least it would be a very good start for a custom tune.
bee_are_zee is offline   Reply With Quote
The Following User Says Thank You to bee_are_zee For This Useful Post:
Old 03-09-2015, 08:06 PM   #137
DJCarbine
Thupercharged
DJCarbine's Avatar
If everything is the same minus bearings/seals/oil feed then I don't see why you would need a new tune.
Pretty sure the compressor is the same minus the bits required for oil feed.
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following User Says Thank You to DJCarbine For This Useful Post:
Old 03-10-2015, 09:29 AM   #138
AJPG
thanks!!!
Old 03-10-2015, 01:04 PM   #139
RedFR-s
RedFR-s's Avatar
Brian@vortech I'm trying to send you a PM but about the V2 charger I've got but no inbox room.
Andy
Old 03-11-2015, 04:03 PM   #140
RedFR-s
RedFR-s's Avatar
Can someone tell me whether the supercharger spins CW or CCW?
Andy
STX Rules and Setup Questions Scooby South Tracking / Autocross / HPDE / Drifting 3914 07-18-2023 05:16 AM
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 03:05 PM
Vortech Offical Owner Thread cjsporl1996 Forced Induction 2 03-27-2014 01:50 AM
Who to tune Vortech setup? pheoxs Forced Induction 18 02-20-2014 03:58 AM
Sprintex or Vortech, which setup has more potential? Turbowned Forced Induction 328 09-14-2013 12:09 PM
