| Software Tuning Discuss all software tuning topics. |
OFT 2.063 mileage.....
Jeebus, 27 MPG which is the highest I've ever gotten, and that included a lot of uphill passing lanes and hooliganism.
#2 | |
Drives: 2013 Asphalt Fr-S
I've been working on writing my own which is stable for a 90% stock car (I have just an AEM intake and cut snorkle) and using the 1.5x version tune.Issue I see, Shifting after a 2nd gear pull creates knock as I enter 3rd. IAM drops to .88 in the 2.063 and .98 in the V 1.5x Under "standard driving conditions" no knock is present in either tunes, so I am not certain of the issue shy of the snorkle causing HIGHLY turbulent air which makes any reliable tuning hard to do.
#3 | |
Drives: FT86
you will need to do Closed loop and open loop maf scaling. If your on a stage 2 tune you may also have to richen up the OL fuel table over 5000 once maf scaling done and or pull some timing. |
#4 | |
ETA: Props and kudos to Shiv and crew. It's rare to find a software shop that improves with every release. |
#5 |
Drives: 2013 FRS
#6 |
#7 |
Drives: 2013 FRS
#8 |
#9 |
Drives: 2013 SWP BRZ
Is it safe to say that if you're LTFT are off, your MPG will suffer? My LTFTs have been off recently due to exhaust leaks but I've also noticed my MPG suffering. It takes a lot to make it to 27mpg whereas before it would do 33-34 easily.
"Don't be a don'ter, do be a doer" - Johnny Wu
#10 | |
Drives: 93 MR2 Turbo; 2014 BRZ
In a properly running car (without an exhaust leak), the LTFT could be off 20% and you can still get 30 mpg. It just means the ECU is doing what it's suppose to, which is compensating for something that is out of wack (typically maf scaling). |
#11 |
I'm just happy with the mileage. The highest I've ever gotten was 25 on the first full tank. It's usually no better than 22-ish, and 17 with E85. This tank included 100 miles of hiway with long uphill passing lanes and idiots to pass at every one. I'll be very interested to see what the result of this tank will be.
| What's your mileage? | Aussie Jase | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 08-16-2020 08:10 PM |
| How much mileage on your FRS/BRZ? | AceNiNe | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 05-19-2013 07:06 PM |
| Gas Mileage | frosty86 | Hawaii | 12 | 10-09-2012 04:56 AM |
| how do you get the gas mileage in you sig? | EvoXDD | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 07-15-2012 02:22 PM |
| How much mileage do you have on your car now? | iff2mastamatt | Other Vehicles & General Automotive Discussions | 82 | 01-11-2012 01:48 AM |
