Old 02-27-2015, 01:29 PM   #15
Ridgerunr
Drives: 2015 Series Blue
I hear what your saying, I have been a mechanic for 40+ years, 10 of them in a VW dealership working in the unit room rebuilding countless engines and trannys, so I'm pretty well versed in mechanical things. Maybe just a fluid change like several here have done, (which I plan on doing) will help the cold weather shifts.
Ridgerunr is offline   Reply With Quote
Old 02-27-2015, 01:52 PM   #16
Koa
I see now. Just FYI, the Aisin tranny is built to very tight tolerances, and as such, shifting when the tranny is outside of operating condition while it warms up will >always< be notchy. I don't know why people expect anything else...
here's a pretty awesome tip from another forum mate on shifting into second cold:
When starting out in first, sweep up to 3k rpm or so and hold it at constant load for 4-5 seconds, then shift into second as normal.
has really helped. I have Motul 300 in both diff and tranny, whiteline tranny insert bushing, TRD Quickshifter, MTec springs, a swapped 3/8" slave cylinder, as well as done the free easy clutch adjustment.. yet nothing helped that second gear crunch/notchiness until I incorporated this procedure into my driving habits... works 90%+ of the time, the other 10% of the time I'm being lazy and not being cognisant of the gate & input shaft speeds.
Here's some great threads on how to improve your clutch performance, some adjustments are free:
DIY Easy Clutch Grab Adjustment
http://www.ft86club.com/forums/showthread.php?t=8040
Ultramaroon's Slave Cylinder retrofit/upgrade
http://www.ft86club.com/forums/showthread.php?t=77390
Clutch Return Spring removal (I didn't do this one
http://www.ft86club.com/forums/showthread.php?t=35621
Old 02-28-2015, 01:18 PM   #17
Ridgerunr
The thing that will help the most...WARM WEATHER...THINK SPRING....SCREW THE GROUND HOG...
Old 02-28-2015, 02:37 PM   #18
Koa
ambient temps dont have much of an impact on the transmission bruv..
Old 02-28-2015, 03:00 PM   #19
jvincent
jvincent's Avatar
They do when the ambient is -25C.
Old 03-04-2015, 01:30 PM   #20
Ridgerunr
It does were I live, I just got the car the first week of November temps right though Christmas were in the 30-40, no problems shifting. Seems like when temps are under 10 it gets harder, the colder it gets the harder it gets to shift. Forecast for today is a high of 6 above, but in the 40's by the weekend....
