Old 02-19-2015, 04:27 PM   #2521
car_roll
Drives: Nuisance BRZ
Stock...
Are all tires above that treadwear really that bad? Trying to base my car off GTA enthusiast class specs...
#teamnuisance
I do like, YouTube or something, IDK.
Shameless Plug
car_roll is offline   Reply With Quote
Old 02-19-2015, 04:33 PM   #2522
juliog
juliog's Avatar
Drives: 86
Achilles 123 are UTQG 220 I think. Pilot Super Sports are UTQG 300, and cheaper than Primacys.
juliog is offline   Reply With Quote
Old 02-19-2015, 05:08 PM   #2523
ddeflyer
I never drove my Primacies on track, but from what I've heard they are actually pretty good once you get them warm.
I would avoid the Michelin PSS if you are looking to use them on track; the center wet compound greases out pretty quickly so you need to be careful about how use use them. That said, they are a fantastic tire if you aren't looking to heat them up too much.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
Old 02-19-2015, 05:13 PM   #2524
CSG David
CSG David's Avatar
You can only warm them up slightly, but their heat range is very small. Like the PSS, they will grease out and chunk. Maintaining temperature is key to success.
Old 02-19-2015, 05:16 PM   #2525
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
The stock tires are terrible on track IMO.
The PSS are a great combo tire between street and track but like David said, you need to maintain control and not overheat them by scrubbing speed with the tires.
I ran PSS on my 2011 STi for a season of track and 2 years on the street. IMO they were more than adequate and I run in the Instructor/Advanced groups at HPDE. They also have great longevity as I put about 20K miles including a season of HPDE on them and no real signs of wear other than the usual evidence of tracking them.
If you are overheating your tires on track you should consider running smoother as that will make you faster and wear your tires less
-mike
AZP Installs is offline   Reply With Quote
Old 02-19-2015, 05:30 PM   #2526
ddeflyer
-mike
In 100+ weather the PSS's center section will grease out very quickly even if you are very smooth. You can mitigate it some by running the tires under inflated (I think I was doing about 35 or 36PSI where as pyrometer was suggesting 38 or so) so you are cornering on the shoulders. This still can cause issues though towards the end of the session if you didn't take as much out as was really needed. Overall, I think it is better to focus on other tasks than trying to deal with variably greased tires. It took me a long time and some experiences with other tires before I figured out the quirky behavior of the PSS tires.
As I said, I have no actual experience with the Primacies so I totally believe you about them.
Old 02-19-2015, 05:35 PM   #2527
Pat
Pat's Avatar
Drives: 2023 BRZ
Let's ensure everyone understand these descriptions are relative. PSS is a MUCH faster tire on track than the OEM tire. Not even in the same ballpark.
Old 02-19-2015, 07:46 PM   #2528
car_roll
achilles 123 is actually banned from the class i intend to compete in
edit: hmmm just double checked the regulations and i guess they "unbanned" them...
#teamnuisance
Shameless Plug
Old 02-19-2015, 09:14 PM   #2529
CSG Mike
CSG Mike's Avatar
-mike
But that means I gotta go slower D:
Old 02-20-2015, 07:12 AM   #2530
AZP Installs
I can't speak for 100+ ambients as we only see 90s at most here in the Northeast.
Also any of these summer tires here we are talking about would be for a relative novice looking for a tire that can be used for both street/daily driving as well as the occasional track day. Any of us who are up in the higher classes would likely be looking at dedicated or near dedicated track tires in the R888 class of tire IMO.
-mike
Old 02-20-2015, 07:13 AM   #2531
AZP Installs
Haaaa. Smooth FEELS slower but actually isn't slower. But you know that already Mikey!
-mike
Old 02-25-2015, 01:41 PM   #2532
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Asking since you're the resident RE11A fan (and I'm pretty set on those tires):
RE11A, 17x8 ET48 OZ wheel, stock dampers with RCA yellows and camber whiteline bolts (-1.8 on front alignment).
Mostly DD with some parking lot autocross 3-5 times/year. 245/40 vs 225/45 - both will fit the wheel. Subjectively I like the fat look of the 245 but am worried I'd need a 5-10mm spacer to clear the stock strut and the steering feel will be meh/flexy since I'm at the smaller rim size limit.
I do have the FT electric SC which breaks the stock tires loose just by gunning it, but not a full turbo/SC setup.
I've been stuck on this for awhile - it's only 2cm. :P
Khyron686 is offline   Reply With Quote
Old 02-25-2015, 04:55 PM   #2533
CSG Mike
CSG Mike's Avatar
AutoX? Go with the wider tire. You may need a spacer, but is that legal for your AutoX setup? If you get spacers, get ARP extended studs and open ended lugnuts.
I believe the RE71R supercedes the RE11A, but I have not yet tried them.
Old 02-25-2015, 07:46 PM   #2534
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Someone help me understand how PSS's work so well on GTR's. I have two friends that use them on their highly modified street legal cars for dual duty. They came in first and second at the NARRA time trials at Sebring in the TTU class with 2:16 laps. Two months later one of them is running 1:14's at Roebling on the same set!
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
