Old 02-25-2015, 07:53 PM   #141
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
Oh, lord, that sounds terrible. So are we reasonably certain the course of events is:
1. Oil is lost, but we haven't determined for certain the reason
2. Oil pressure drops as a result
3. Rod bearing fails
If that's the case then the rods are not the problem, but merely a victim, oil pressure is not the illness, merely a symptom and the true culprit is whatever is causing the oil loss.
I know I have no plans to modify my engine beyond things like free breathing and an oil cooler, but a triple stack of aftermarket meters are part of the plan, water temp, oil temp and oil pressure. Those are the basics and I have never trusted stock gauges.
The Following User Says Thank You to themadscientist For This Useful Post:
marky (02-26-2015)
Old 02-25-2015, 11:26 PM   #142
BRZnut
Drives: BRZ DGM Limited
Originally Posted by Tank View Post
I did. I am also unsure what this means. The computer system shows a lapse in the service history from before I bought the car. I bought it used and was assured that any problems would still be covered under warranty for 60 months/60k miles from the date it was first sold.
Did you buy it from the dealer?? Did they tell you at the time of the sale that your warrantee is void since there was a "lapse in service" before you bought the car??? If not, how in the hell can they pull that crap now??? Unbelievable how Subaru/Toyota are NOT standing behind the twins!
Old 02-26-2015, 07:13 AM   #143
ZZT86
ZZT86's Avatar
Drives: BR86
No issues before this happened, other than tail light condensation.
Completely stock, hasn't been modified in any way.
Oil changes were done by the dealer (lifetime oil changes)
The rod knock started right when I came off a salt covered cloverleaf merging onto another highway. Never tracked or autocrossed. It is my daily commute to and from work, which is mostly highway. Occasionally "driven hard", but I'm not the type to bounce it off the rev limiter all day, or rev it when it hasn't fully warmed up yet. I can see no reason why this happened.
Just like me, my 86 gets an easy life most of the time. Could be the VVT system to blame as others have mentioned. This has me a little worried now that my car one day will go kaBOOM ! Pathetic really, imo if the 86 was a 'real' Toyota we wouldn't be here talking about this sh1t :/
I also can't help think that the oil weight itself has something to do with all this. I presume the oil weight used was the correct one as it was done by the dealer ?
Toyota SHOULD cover you, best of luck bud.
ZZT86 is offline   Reply With Quote
Old 02-26-2015, 10:19 AM   #144
HunterGreene
Hail Magnet
HunterGreene's Avatar
Well, at least we know exactly what to listen for soundwise. The second I hear it, if I do, I'm calling a tow truck.
It has priests in it?
Old 02-26-2015, 10:54 AM   #145
ajc209
Drives: GT86 Cosworth
I cant be bothered reading the whole thread but has anyone suggested that the crank pulley might be the problem?
The crank pulley is heavy on the FA20 because it dampens harmonics created by spinning crankshaft and by fitting a lightwieght pulley you are removing/changing this damping leaving the bearings vulnerable to failure due to excessive high frequency vibrations?
Its cheaper to fit a heavy crank pulley than to make more effort balancing the crank.....
ajc209 is offline   Reply With Quote
Old 02-26-2015, 10:59 AM   #146
HunterGreene
Hail Magnet
I am reasonably sure that the people who are experiencing this have stock setups. But then again, I am lazy like you and didn't read back.
Old 02-26-2015, 11:00 AM   #147
ajc209
Originally Posted by eriktherod View Post
Only two mods: The TRD drop-in air filter and the Perrin crank pulley.
I read enough of the begining to see he had a Perrin crank pulley....
Eriktherod, did you have the Perrin crank pulley fitted both times the bearing failed?
The Following User Says Thank You to ajc209 For This Useful Post:
HunterGreene (02-26-2015)
Old 02-26-2015, 11:08 AM   #148
Contrary to the common perception that this is a rampant problem that we are all going to experience of the five confirmed incidences I have found I believe 4 were stock.
ScoobsMcGee (02-26-2015)
Old 02-26-2015, 11:16 AM   #149
ajc209
IF they were 100% stock (A lightwieght crank is not stock) thats what 4 out of how many 1000's?
Hardly a rampant problem.
Old 02-26-2015, 11:50 AM   #150
My point exactly!
I am sure that there are many out there that hold the opposite opinion but nobody has put any firm evidence on the table that there are the 100s of incidents being claimed by some.
The internet is a wealth of information but the flip side is that it is very easy too take too little or inaccurate data and run with it!
Old 02-26-2015, 11:54 AM   #151
Tank
Mumbler
Tank's Avatar
Drives: Sensibly
I am currently waiting on 100% confirmation (the second video @marky posted in #141 is mine). No work will start unless authorized by the service representative (who happens to be in sunny Florida right now).
Tank is offline   Reply With Quote
The Following 2 Users Say Thank You to Tank For This Useful Post:
marky (02-26-2015), Tcoat (02-26-2015)
Old 02-26-2015, 12:05 PM   #152
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I'm just curious, when the bearing begins to spin, does the knock sound come on immediately and remain consistently? Is it something that could go away and come back? Are there any warning signs/sounds?
Fizz is offline   Reply With Quote
Old 02-26-2015, 12:51 PM   #153
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
True story on the knock though. If anyone hears this with their FA20 engine it would be very wise to just pull over, especially if you have any engine or drivetrain mods. Toyota (from experience) will use it to get out of any warranty work that causes the engine to cease, if they can. I ended buying my own replacement FA20 engine because my #4 rod broke and punched a nice "H" shape hole through the short block, while the car was idling in a parking lot I pulled over in.
I paid Subaru to break down the engine block since Toyota (Scion) dropped my case because of aftermarket parts. The Subaru tech wrote a sworn statement and took pictures of the breakdown to illustrate the faulty part...but I ended up not pursuing further action since Toyota won't take a paid and trained Subaru technician's word...even if Subaru designed most of the damn car. LOL.
But love my car now... not even remotely stock So bottom line... don't mess with the knock lol
shiro is offline   Reply With Quote
The Following 2 Users Say Thank You to shiro For This Useful Post:
Old 02-26-2015, 12:59 PM   #154
toeout
Once you hear the rod knock, there is no reason to baby it, the damage is already done. You gonna get a new short block and that's it, might as well clatter to the dealer's lot.
The only thing I'm curious about, is how often was the oil level monitored. I check mine weekly, at least, and I've never let it be lower than 1mm from max level.
IMO the only obligation for the owner is to keep the engine cooled and lubricated. If that's done, it better hold together, even if driven hard ( assuming engine is brought to working temp )
toeout is offline   Reply With Quote
Full Blown Stage 1 Short Block FullBlown Forced Induction 116 03-22-2019 08:29 PM
Upgraded short block installed? Yruyur Issues | Warranty | Recalls / TSB 13 01-28-2014 10:13 PM
Built B18B Short Block C130NAV Miscellaneous 0 01-04-2014 01:15 PM
FA20 oem Short Block 3k miles Area51 Engine, Exhaust, Bolt-Ons 29 09-13-2013 02:01 AM
WTB: short block or long block DOTman05 Engine, Exhaust, Bolt-Ons 2 07-14-2013 07:48 AM
