Old 02-21-2015, 03:03 PM   #15
Stewie
Stewie's Avatar
Drives: '15 - WRB Brz Limited
Koni vs Bilstein is almost Coke vs. Pepsi. I'd be happy with either but lean towards Bilstein.
I just switched from Koni to custom valved Bilsteins on my Mini and they're very good.
- Andy
I'm gonna end up going with rce springs. I think I remember reading on here some where that the yellows paired better with the non "sport" bilsteins.
Since I'm thinking tarmac springs because they were designed with the notion of being paired with higher/better performing shock/struts, which shock/strut do you think they pair best with Andy?
2015 WRB Brz Limited 6MT
2001 BMW 540i 6MT M-Sport (sold)
2001 BMW 325ci 5MT (sold)
1988 Volvo 740 Turbo 4MT w/ electric OD/5th gear (sold)
Stewie is offline   Reply With Quote
Old 02-21-2015, 07:11 PM   #16
M23
Drives: 86
Bilstein...then have RCE or Blistein custom re-valve them (for around $420) to perfectly match your Tarmac springs
M23 is offline   Reply With Quote
The Following User Says Thank You to M23 For This Useful Post:
Stewie (02-21-2015)
Old 02-21-2015, 08:27 PM   #17
Stewie
Stewie's Avatar
That sounds like a great idea. Thank you.
The Following User Says Thank You to Stewie For This Useful Post:
M23 (02-22-2015)
Old 02-21-2015, 09:53 PM   #18
Honestly you could go either way. Most go with the B8 shocks for the tarmac springs.
- Andy
M23 (02-22-2015), Stewie (02-23-2015)
Old 02-24-2015, 02:28 PM   #19
M23
Drives: 86
After doing some simple cost calculations; I think you'd get the most bang for the buck by just getting RCE T0 (cheaper/same-price..and at the same time already built (no down time) and valved perfectly) than re-valving B8/B6s.
Swift Spec-R or Tarmac: $375 or $330
B8 or B6 shocks: $900
Total: $1275
Revalved Total (+$420): $1650-1695
RCE T0: $1700
Stewie (02-27-2015)
Old 02-24-2015, 02:55 PM   #20
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
I have B8s with RCE Yellows. Harsh for our roads here but no complaints otherwise.
BRZZZZZZZZZZ is offline   Reply With Quote
The Following User Says Thank You to BRZZZZZZZZZZ For This Useful Post:
Stewie (02-27-2015)
Old 02-26-2015, 08:40 AM   #21
makinen
makinen's Avatar
Drives: Toyota 86
I have RCE Tarmacs with Konis.
After some adjustment phases, I've stuck at some points with easy DD-able setting. But when I went to the track, same setting worked fine.
makinen is online now   Reply With Quote
The Following 2 Users Say Thank You to makinen For This Useful Post:
Racecomp Engineering (02-26-2015), Stewie (02-27-2015)
Old 02-26-2015, 09:08 AM   #22
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
As RCE said, Coke v. Pepsi...
Konis are nice because you can adjust them for when/if you need to install Wife/MIL in car...
You can't go wrong with either setup IMO.
-mike
AZP Installs is offline   Reply With Quote
The Following User Says Thank You to AZP Installs For This Useful Post:
Stewie (02-27-2015)
Old 02-26-2015, 04:31 PM   #23
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Originally Posted by Stewie View Post
Non adjustable. But the Koni's are only adjustable for rebound if I'm not mistaken.
Correct. I inquired with Koni about specifications and this was their reply:
Thank you for contacting us her at KONI NA. The struts and shocks are not shorten and are similar in stroke and min and max length to OE dampers. The optimized valving and rebound adjustable damping allows for the use with lowering spring and increased spring rates. When designed by KONI engineers, the sport valving is selected based on performance and ride using the factory springs. If the car has performance upgrades (springs, wheel/tire packages, etc.) or the driver wants the car a bit more aggressive, most people find the optimum setting in the 1/2 to one full turn from the full soft range. Over the extended life of the damper or if the driver wants a specific firm handling characteristic, the dampers can be adjusted up higher. One of the great advantages of KONI adjustable shocks is that there is no specific spring for matching optimum performance. Instead you can adjust your KONIs to match your springs. Most performance springs have a higher spring rate than the vehicle's original springs.Since the shock controls the motion of the spring, increased spring rates require more rebound damping for control and that is one of the reasons why KONIs are rebound adjustable (and some are double adjustable). The KONI adjustment range is typically about 100% (twice as firm at the full firm settings at the full soft setting) to allow for proper damping of OE springs and high rate performance springs.
I wish Tokico made Illuminas for our cars as the adjustment adjusts compression & rebound together.
I'm still trying to get more info on the Cusco's before I make my decision to go with the Bilsteins.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
Stewie (02-27-2015)
Old 02-26-2015, 04:35 PM   #24
No warranty on the Cuscos makes the choice easy for me. And I (generally) like Cusco.
- Andy
Stewie (02-27-2015)
Old 02-27-2015, 02:55 AM   #25
Stewie
Stewie's Avatar
Total: $1275
RCE T0: $1700
True...but I liked some of the points made regarding being able to adjust the rebound, so I looked up what ft86speedfactory.com had going on
Rce tarmacs 330
Koni complete set 865
Total= 1,195
Seems that without the revalve, it's Coke vs Pepsi like Andy and others have said. The benefits of the Koni's adjustability might just be the deciding factor. There's a meet coming up next month. Gonna see if I can go for some short drives with 86 owners to see which will be best for me.
Thanks for all the input thus far. Please keep the opinions, thoughts, and experiences coming.
M23 (02-27-2015)
Old 02-27-2015, 03:18 AM   #26
M23
Drives: 86
Decision Decisions.
Bilstein's awesome quality, warranty and affordable serviceability/rebuildability
or
Koni's, or Cusco's, adjustability
Old 02-27-2015, 11:22 AM   #27
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
I've had both on the same car in the past and prefer the Koni's. Not only are they adjustable but they are less harsh than the Bilsteins. I've had Bilsteins, even custom valved, and always find them to be harsh on the street. Even their PSS9/10's are pretty harsh. The supposedly "greatly tuned" Bilsteins on the Lotus Elise were stupid harsh on the street.
So, yeah, not a fan of anything from Bilstein that I've tried.
Sleepless is offline   Reply With Quote
The Following 3 Users Say Thank You to Sleepless For This Useful Post:
M23 (02-27-2015), rapidcars (04-24-2018), Stewie (02-27-2015)
Old 02-27-2015, 11:41 AM   #28
Koa
Rce tarmacs 330
Total= 1,195
Gotta ask- why do you need adjustable dampening?
Koni's are cool for that and all, but the quality is outwardly subpar to bilstein's. Who knows how the two's valving quality compares, as few have dissected those shocks and compared them.
I have B8s & sportlines on my rig, perhaps you'd like to take her for a drive sometime and see how you like it? I'm pleasently surprised given the sportlines' less-than-stellar drop and rates. "Harshness" is definitely subjective, but the real question is how the two shocks perform. Not saying Koni's don't perform as well, they very well may.. just want to underline that performance and harshness aren't mutually exclusive
The Following User Says Thank You to Koa For This Useful Post:
Stewie (02-27-2015)
Koni Yellow vs. Bilstein B6 vs. Bilstein B8 shattered_memory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 01-04-2017 12:22 PM
WTB: Used Bilstein B14 or B16 InvalidJohnny5 Brakes, Suspension, Chassis 0 03-11-2014 11:40 AM
FS: RCE Yellow, Koni struts and pre cut housing for Koni's. Dinko Brakes, Suspension, Chassis 21 12-16-2013 11:32 AM
KONI SHOCK VALUE SALE limited time only @ Circuit Motorsports! Lower prices all Koni Circuit Motorsports Brakes, Suspension, Chassis 115 08-30-2013 11:29 AM
Koni inserts or wait for full Koni replacements Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-18-2013 06:48 PM
