Old 02-20-2015, 11:30 PM   #1
Stewie
Stewie's Avatar
Drives: '15 - WRB Brz Limited
Koni's or Bilstein's??
Koni's or Bilstein's? That is the question.
Philosphy of use: daily driving and maybe some auto cross
Desired effect: better damping. better performance. smoother ride?
2015 WRB Brz Limited 6MT
2001 BMW 540i 6MT M-Sport (sold)
2001 BMW 325ci 5MT (sold)
1988 Volvo 740 Turbo 4MT w/ electric OD/5th gear (sold)
Stewie is offline   Reply With Quote
Old 02-20-2015, 11:38 PM   #2
qwerty66
Drives: frs
Bilstein
qwerty66 is offline   Reply With Quote
The Following User Says Thank You to qwerty66 For This Useful Post:
Stewie (02-21-2015)
Old 02-21-2015, 12:38 AM   #3
swarb
Wow that's a tuffy. Almost like "frs or brz?" I personally like koni's but I have never used it in our application. Are bilsteins adjustable? For other applications from what I remember they were not. That was the main reason for my choice.
The Following User Says Thank You to swarb For This Useful Post:
Stewie (02-21-2015)
Old 02-21-2015, 01:01 AM   #4
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Bilsteins all the way.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following User Says Thank You to Apoc For This Useful Post:
Stewie (02-21-2015)
Old 02-21-2015, 01:49 AM   #5
grodenglaive
Drives: asphalt FR-S
had koni yellows on my MINI - they were awesome, but when one blew a seal it took 2 months to get a warranty replacement.
grodenglaive is offline   Reply With Quote
The Following User Says Thank You to grodenglaive For This Useful Post:
Stewie (02-21-2015)
Old 02-21-2015, 02:24 AM   #6
Panman
Panman's Avatar
Drives: 86 GTS
I have B6s and love them - the faster you go the better they feel. Track for one or more of HPDE/Regularity/Sprints/Drift/Skidpan 2 times a month, canyon carving in the mix also.
Non-adjustable, but I don't feel the need for it. Koni's are adjustable and cheaper, however I'm happy with my choice.
Panman is offline   Reply With Quote
The Following User Says Thank You to Panman For This Useful Post:
Stewie (02-21-2015)
Old 02-21-2015, 02:39 AM   #7
Stewie
Stewie's Avatar
Anybody run both? Present application or otherwise? All input is appreciated. Seems lopsided for bilstein thus far...
Old 02-21-2015, 02:41 AM   #8
Stewie
Stewie's Avatar
Non adjustable. But the Koni's are only adjustable for rebound if I'm not mistaken.
Old 02-21-2015, 10:37 AM   #9
was385
Drives: MT WRB BRZ Limited, 2007 911s
Went through this same thought process and ended up with bilsteins and rce Tarmac springs. Unless you really feel like you need adjustability, bilstein just makes a better quality part.
was385 is offline   Reply With Quote
The Following User Says Thank You to was385 For This Useful Post:
Racecomp Engineering (02-21-2015)
Old 02-21-2015, 10:56 AM   #10
Stewie
Stewie's Avatar
How do they compare to stock for the day to day driving duties. Smoother? Harsher? Do your teeth rattle on rough roads?
Which springs are you running?
@was385
Which bilsteins did you end up with? I'm leaning towards the rce tarmacs as well...
Old 02-21-2015, 11:39 AM   #11
was385
@was385
I got the B8s. It's definitely a little harsher at low speeds but not bad at all. At highway speeds it's a lot more comfortable though. There's a bump on my route home from work that I used to have to slow down to about 40mph for and it still shocked the whole car. With the bilsteins, I go over at 65-70 and barely feel it.
The Following 3 Users Say Thank You to was385 For This Useful Post:
Fizz (02-21-2015), M23 (02-21-2015), Stewie (02-21-2015)
Old 02-21-2015, 11:55 AM   #12
Pat
Pat's Avatar
Drives: 2023 BRZ
Good to know. I put about 200,000 miles on some Bilstein Sports with my old A4. I think i blew four of them in that time. I was pretty disappointed in that, but they always were quick to warranty them. I'd buy them again. I don't have any first hand experience with Konis, though.
The Following 2 Users Say Thank You to Pat For This Useful Post:
Old 02-21-2015, 12:15 PM   #13
Fofofawcett
Drives: GBS BRZ
Koni shocks
Just wanted to chime in since I have Koni adjustables.
http://www.ft86club.com/forums/showthread.php?p=1487005
They have been really great for me and I don't think you are giving up any quality by going with the koni. That being said, I have heard nothing but good things regarding bilstein as well.
The adjustability of the konis is pretty cool. Yes, you end up mostly using 1 setting, but like I said in my thread, it does a lot more than you think. Personally, I really enjoyed dialing in the rebound and having a "different" feeling car once in a while. Hopefully this helps!
Fofofawcett is offline   Reply With Quote
The Following User Says Thank You to Fofofawcett For This Useful Post:
Stewie (02-21-2015)
Old 02-21-2015, 02:17 PM   #14
Koni vs Bilstein is almost Coke vs. Pepsi. I'd be happy with either but lean towards Bilstein.
I just switched from Koni to custom valved Bilsteins on my Mini and they're very good.
- Andy
AZP Installs (02-26-2015), Stewie (02-21-2015)
Koni Yellow vs. Bilstein B6 vs. Bilstein B8 shattered_memory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 01-04-2017 12:22 PM
WTB: Used Bilstein B14 or B16 InvalidJohnny5 Brakes, Suspension, Chassis 0 03-11-2014 11:40 AM
FS: RCE Yellow, Koni struts and pre cut housing for Koni's. Dinko Brakes, Suspension, Chassis 21 12-16-2013 11:32 AM
KONI SHOCK VALUE SALE limited time only @ Circuit Motorsports! Lower prices all Koni Circuit Motorsports Brakes, Suspension, Chassis 115 08-30-2013 11:29 AM
Koni inserts or wait for full Koni replacements Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-18-2013 06:48 PM
