Old 05-16-2012, 02:32 AM   #43
Moto-P
Moto-P's Avatar
Drives: Many types of cars in R&D.
Rebound only or rebound and compression together?
Rebound and compression together, at RS-R's pre-set valve curve on each side, progressive. This can be custom tailored however, if requested, to a degree feasible in their designs.
Moto Miwa
www.club4ag.com
R&D Driving Engineer, Product Planning Consultant
Consulting Member at Cusco, OEM+, RS-R.
www.club4ag.com
Moto-P is offline   Reply With Quote
The Following User Says Thank You to Moto-P For This Useful Post:
Dimman (05-16-2012)
Old 05-16-2012, 02:48 AM   #44
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
quik1987 is offline   Reply With Quote
The Following User Says Thank You to quik1987 For This Useful Post:
Moto-P (05-16-2012)
Old 05-16-2012, 02:56 AM   #45
YukiHachiRoku
Lex Luger
YukiHachiRoku's Avatar
Drives: 2004 GS430
Arigatou!
YukiHachiRoku is offline   Reply With Quote
The Following User Says Thank You to YukiHachiRoku For This Useful Post:
Moto-P (05-16-2012)
Old 05-16-2012, 03:32 AM   #46
quik1987
quik1987's Avatar
Can you keep a record of your build on our board Member's Car Journals?
Moto-P (05-18-2012)
Old 05-16-2012, 03:46 AM   #47
Moto-P
Moto-P's Avatar
For anyone in SOCAL, PENSKE TOYOTA of DOWNEY is hosting the FRS party for us.
FIVE AXIS FRS
CUSCO FRS
3 of the FIRST 86 FRS
and 2 more from Toyota HQ...
A BUNCH of them will be there.
Tomorrow 7pm-9pm, Penske TOYOTA of DOWNEY (Wed 16th)
BE THERE if you want to see some FRS!!
Moto Miwa
www.club4ag.com
www.club4ag.com
The Following 2 Users Say Thank You to Moto-P For This Useful Post:
bestwheelbase (05-17-2012), ESBjiujitsu (05-16-2012)
Old 05-16-2012, 03:47 AM   #48
Moto-P
Moto-P's Avatar
I'll be keeping a log on my own webpage, Club4AG.com...and keep updating you all here when I do have news.
Moto Miwa
www.club4ag.com
www.club4ag.com
Old 05-16-2012, 05:39 AM   #49
Moto-P
Moto-P's Avatar
AS Promised.
Here is the photo of the FRS, with RS*R Sports-i installed, corner-weighted, and tuned and aligned at 35mm drop front, and 32mm drop rear.
The profile of the car starts to really look nice about this height, but wheels becoming more and more weak in visual impact~~! LOL!!
Waiting on some 18" but custom made is not exactly overnight.
I've always wondered if the red dots (low runout point) on the tires are matched to the wheels from factory...
Also, shark fin, color matched antenna was installed on the roof for promotional use for a company, BeatSonic (Japan and USA) who has taken care of every audio and lighting needs I had over many cars over the past recent years.
F:35mm R:32mm dropped on RS*R Sports-i Suspension, also with Beatsonic Shark Antenna by Moto@Club4AG, on Flickr
Earlier today, also, Apex-i Throttle Control module and high flow drop-in air filter installed for testing on FRS. I'll have something to write on these in a week or so...
APEXi High Flow Drop-in filter for FRS/BRZ. by Moto@Club4AG, on Flickr
Moto Miwa
www.club4ag.com
www.club4ag.com
The Following 8 Users Say Thank You to Moto-P For This Useful Post:
chulooz (05-16-2012), ESBjiujitsu (05-16-2012), Fly Guy (05-16-2012), LSxJunkie (05-19-2012), Nardi330 (05-16-2012), Slartibartfast (05-19-2012), TRD_07 (05-21-2012), ZetaVI (05-16-2012)
Old 05-16-2012, 06:35 AM   #50
Moto-P
Moto-P's Avatar
http://www.ft86club.com/forums/showthread.php?t=6271
YES. I have them on now on my FRS, and here is the preliminary writeup and photos.
Moto Miwa
www.club4ag.com
www.club4ag.com
Old 05-16-2012, 07:46 AM   #51
Nardi330
Nardi330's Avatar
Drives: 86
Moto san, what is the ground clearance now with this setup?
Thx
Nardi330 is offline   Reply With Quote
The Following User Says Thank You to Nardi330 For This Useful Post:
Moto-P (05-18-2012)
Old 05-16-2012, 08:21 AM   #52
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Originally Posted by Matt Andrews View Post
Couple quick questions. Sorry in advance if I missed some of these details in the write up.
1. Do these have independant compression and rebound adjustments? Or are they single adjustables?
2. Will RSR share with you who manufactures their valving? I would be suprised if they make their own considering the volume of dampers they produce. I'm only asking to see if it is a known reputable company.
3. I assume these are aluminum bodied dampers. Did you happen to wiegh them compared to the stock units?
4. Did you change your alignment specs from stock to this? I'd be suprised that steering input would change because of the shock a noticable amount without toe changes.
Are you in SoCal? My car arrives in the next couple weeks. I'd be curious to see how the RSR damper performs on track to other offerings.
Best,
Matt Andrews
Originally Posted by Moto-P View Post
All alignment specs can be set to original specs with mild 20mm drop, though we recommend slightly bit more camber at front if using more aggressive tires and partaking in motorsports (1-2degrees). Just how much depends on stage and road racing conditions, and again, driver skills to actually put that to use effectively.
As for me, I had my car corner- weighted at each end with me in the car, precisely to center the contact patch between left and right. I didn't worry too much about fore/aft adjustments, as that is more inherently dependent on what type of racing, venue, and tires/brakes and adhesion and it can vary greatly, so I just left the overall balance alone from stock, and accepted the change slightly, just to personalize the looks of the car (height fore/aft) as more a priority (Yes I like my fast cars, looking good too, but functional. )
1. Single adjustable, but they do custom design each application to the cars, so the balance of how they change in relation to the requirements are pretty spot-on in my previous 4 sets I used on each car.
2. RS-R manufactures and designs the case, piston, valves and all hardware components in-house, and I've visited the manufacturing facilities near Osaka, Japan, so I trust them that much.
3. These are aircraft grade aluminum shell cases and ends, (I forgot that the actual T rating of the alloy). For the FRS set, the suspension coil and shock assembly with mounts, weighed 3lbs less than OEM parts removed to replace (total of all four ends). While the OEM's weight is mainly in the large coil springs, the majority of weight on the RSR Sports-i is in the case shell and valve/piston which seems much more strong than OE internals and shell case.
4. Due to the very long lower arms and steering rack pivots as well as toe-locator rods, the FRS needed minimal correction of 0.4 mm at both ends of the rack-ends, to bring the toe back to where it was originally with OE height, this, at 32mm drop. I'd need to re-check after a few dozen miles to see if any settling of bushings or springs caused any changes, but that's what I see at this time, 1 day after installation.
Yes, I am in Los Angeles/South Bay area and hope to meet you soon for a cup of coffee or snacks~!
This is good Stuff...as my own build with my BRZ will become reality here soon.
Matt Andrews..thanks for the intelligent questions. You seem to have similar goals in mind with this platform that I do.
Moto... you insight is phenomenal and respected. Thank you..
I have a couple of questions also:
-What type of competition are you going to participate in?
I will be building my BRZ to SCCA Solo spec in whatever Street Tire Class it falls in.. as I have already started to accumulate the needed parts, rims/tires etc to facilitate this..
-Moto, is it wise to say going with a stiffer rear, even tho slightly, makes it more neutral??? Since it is a new platform, Spring Rates were a crapshoot. I was going to start with 8k/8k.. but that sounds to stiff?? now.
-With 35mm maximum drop, would Steering Compensators ie: Bump steer kits/Ball joints be a wise investment?
-Will you still be using the stock swaybars? or are you planning a upgrade there?
-Care to share your Corner weight info???
-If you were to run camber, How much would you run, Do you have any idea of the how much Static Camber you have during aggressive driving?? And do you know if Toyota or Subaru is going to offer 'crash Bolts' to be able to get more camber out of the stock mounting???
- how much room do you have between the shockbody/spring and the inside of the tire at this point??
Thanks sooo much for your time..The information you are providing will go a long way in my own build. Much appreciated
Bill
Scooby South is offline   Reply With Quote
Old 05-16-2012, 08:59 AM   #53
ZetaVI
Gundam Meister
ZetaVI's Avatar
Drives: A Gundam
Awesome photo. Can't wait to see your custom 18's. How long does it take to get custom wheels?
The Following User Says Thank You to ZetaVI For This Useful Post:
Moto-P (05-17-2012)
Old 05-16-2012, 09:04 AM   #54
ESBjiujitsu
MUST HAVE MORE 86 ! ! !
ESBjiujitsu's Avatar
Drives: Mazdaspeed 6 2.3 AWD Turbo
Moto.....your car looks amazing. the drop is perfect! Please take as many pictures as your car as you can physically post!!!all angles when ever you have a chance. its just so beautiful!!! And thank you for your posts.
WISH LIST: Whiteout FRS- Bronze 18' race rims, Cooper Zeon RS3-S tires,
Cusco Coilovers, Cusco 6 point cage, CF Lip spoiler, CF F1 Mirrors, HKS GT-86 SC
92 carmy -> 86 corolla-> Honda S2000 -> Audi TT -> Mazdaspeed6 -> NEXT UP TOYOTA FT-86!!!!
ESBjiujitsu is offline   Reply With Quote
The Following User Says Thank You to ESBjiujitsu For This Useful Post:
Moto-P (05-17-2012)
Old 05-16-2012, 10:54 AM   #55
sirus
86 Owner
sirus's Avatar
Drives: White GTS 86
Thanks for the informative posts! Decision making just got harder... *sigh*
On the road. Check your mirrors!
sirus is offline   Reply With Quote
The Following User Says Thank You to sirus For This Useful Post:
Moto-P (05-17-2012)
Old 05-16-2012, 11:23 AM   #56
StuttterButtter
Yes i have a stutter
StuttterButtter's Avatar
Drives: 94 Acura Integra
APEXi has a FRS/BRZ muffler system available. It will be on sale starting next week!
Yeah but i love the sound of the RS-R Exmag sounds so nice.
That Shark fin looks nice i wish that was a factory option
StuttterButtter is offline   Reply With Quote
The Following User Says Thank You to StuttterButtter For This Useful Post:
Moto-P (05-17-2012)
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 856 06-14-2018 03:53 PM
US Subaru BRZ Port Installed Accessories and Packages List and Prices eikond BRZ First-Gen (2012+) — General Topics 42 04-28-2015 08:45 PM
Live Pics of Subaru Boxer Sports Car Architecture (BRZ) from Geneva! + Press Release Hachiroku BRZ First-Gen (2012+) — General Topics 103 09-14-2011 05:05 PM
Dealer Installed Badges ToyotaObsession Scion FR-S / Toyota 86 GT86 General Forum 55 05-14-2011 01:16 AM
Turbo FT-86 G-Sports pics from 2010 Australian International Motor Show Calais FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 49 11-04-2010 06:40 PM
