Old 02-16-2015, 06:38 PM   #939
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by M23 View Post
@sales@delicioustuning.com
What are the best and your recommended EL headers sub <$1k?
For sure, JDL, Nameless, HKS are top notch quality headers..but trying to get an inexpensive, best bang for buck, type of catless EL header.
Which are the good ones though? OFH, PPE, P&L, Tomei, Skunk2, Rev Works, etc., etc.?
Sub $1,000, I'd say Tomei EL by far.
Sincerely,
The Following 3 Users Say Thank You to DeliciousTuning For This Useful Post:
M23 (02-16-2015), poorsche (02-16-2015), zdr93523 (02-18-2015)
Old 02-16-2015, 06:53 PM   #940
M23
Drives: 86
Coolio
M23 is offline   Reply With Quote
The Following User Says Thank You to M23 For This Useful Post:
Old 02-17-2015, 12:02 PM   #941
vaderbloke
Drives: 2014 Subaru BRZ
Zach,
My FlexFuel kit arrived Saturday. Looks very professional A couple of observations:
I presume the new tunes status is as post #936.
No fuel line tool in kit (no big deal for me as I already have one)
Short screws only engage about 1 thread. IMHO they need to be a little longer.
Any installation instructions available yet?
ETA on the Android app?
vaderbloke is offline   Reply With Quote
Old 02-17-2015, 02:26 PM   #942
DeliciousTuning
Originally Posted by vaderbloke View Post
Zach,
Vader,
Are you referring to our new NA tunes or your Flex Fuel update? Tool kits are being included on all future orders, they just hadn't arrived as of yet. They are here now! We could use longer screws, however the bracket is very thin and the next size up would protrude out the bottom of the bracket and abrade against the abs line, which is exactly what we're trying to avoid. We haven't had any issues with bolts coming loose or undone at their current size, but will look into perhaps a custom size bolt that will sit flush with the bottom of the bracket.
No install instructions available quite yet, working on getting a PDF up on the site. For now if you have any questions on install feel free to PM me. Android app is due by end of month if my last update on that holds true.
Sincerely,
The Following User Says Thank You to DeliciousTuning For This Useful Post:
vaderbloke (02-17-2015)
Old 02-17-2015, 04:46 PM   #943
vaderbloke
Zach,
I was waiting for the FlexFuel upgrade for the Innovate S/C 69/75mm pulley. Thanks for the heads up on the screws protruding issue. I will grind down my longer bolts, or maybe just add an additional washer or two
The Following User Says Thank You to vaderbloke For This Useful Post:
Old 02-17-2015, 07:02 PM   #944
DeliciousTuning
Originally Posted by No5ki View Post
Recommend a stage/tune with Tomei header stock op/fp and muffler delete? Drop in filter up top. Does aftermarket op/fp make a big difference?
Stage 2, with E85/Flex Fuel if you have it available! I wouldn't do a muffler delete unless you desire the sound. Overpipe and front pipe gains are negligible gains compared to header, and you do still want a little bit of backpressure in the system for low end torque retention. If street car, keep stock front pipe for low end. If race car, straight pipe and you'll lose low end but gain a small bit on top.
Sincerely,
No5ki (02-17-2015)
Old 02-17-2015, 08:40 PM   #945
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Man I would love to try your tune, but with my set-up it will cost me bunch. :-(
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 02-17-2015, 09:48 PM   #946
OkieSnuffBox
Drives: '23 BRZ Limited
@sales@delicioustuning.com forgive me if I missed it, have you played around with the Grimmspeed intake yet?
I notice on your site you recommend the AirRaid intake and JDL headers, just curious if you've tested the Grimmspeed.
Old 02-17-2015, 11:26 PM   #947
DeliciousTuning
PM me and I'm sure we can figure something out.
Sincerely,
Old 02-17-2015, 11:27 PM   #948
DeliciousTuning
We have tested and tuned the Grimmspeed intake on our latest trip to Mann Engineering. We quite like it, especially the fact that it needs virtually no MAF scaling since it so closely follows stock values. Good box!
Sincerely,
Old 02-18-2015, 06:33 AM   #949
Calum
That Guy
Drives: 2013 asphalt FRS MT
Sincerely,
Zach
Any gains?
Old 02-18-2015, 03:38 PM   #950
DeliciousTuning
You may see a little bit on top, but that's about it. The gains on a Stage 1 tune are really negligible compared to the stock intake with a high flow filter.
On an untuned car you would see more of a benefit with the Grimmspeed intake, the Stage 1 tune pretty much just overshadows it.
Sincerely,
Calum (02-18-2015)
Old 02-18-2015, 08:07 PM   #951
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
I get my package today, will I feel immediate gains after flashing it? will a stock flash
be available as well just in case I gotta go to the dealers?
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 02-18-2015, 09:16 PM   #952
DeliciousTuning
Hey Toni,
You should feel the gains immediately after flashing. The ecu will also continue to learn and add more power if it's happy, which it should be. If you ever need a stock tune, just email us and we'll send it over. I haven't run into a dealer that's able to tell an EcuTek tune is on a car, however. They certainly couldn't figure out one was on mine.
Sincerely,
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 04:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 06:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 06:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 02:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 03:33 PM
