| Software Tuning Discuss all software tuning topics. |
Drives: 2015 frs
Target afr
Good morning guys. I've searched and found some info. But some if it is conflicting. I know there are a ton of variables, but if you could pick a number. What would your target afr be on a supercharged frs on about 10lbs at wot.
I know it's a noob question, I'm not tuning my car, just trying to keep a safe eye on the wideband. Thanks! |
#2 | |
Drives: FT86
best to ask your tuner what afr they are targeting or look in your tunes ol fuel table or talk to @King Tut think he has one of those aem wideband guages |
#3 |
Drives: 86
11 - 12 at boost
#4 |
Drives: 2013 ultramarine Scion FR-S
0.85 lambda (12.5 AFR) is usually the bottom end of MBT, aka maximum brake torque.
I aim for 0.9 lambda (13.25 AFR), which tends to be dead center of MBT. Top end of MBT is usually 0.95 lambda (14.0 AFR). |
#5 |
Drives: UK GT86
Even on this engine? AND supercharged???
.: Stealth 86 :.
#6 |
Junior
Drives: a car
#7 |
It is more a matter of chemistry and thermodynamics than mechanics.
Most of the reason people go richer is to compensate for knock and then try to edge out more power. The power you make in that manner is fragile at best, and catastrophic at worst. Cars tuned this way are temperamental and unpredictable. In this case conservative tuning isn't running richer, it's running MBT and the appropriate ignition timing to suit. |
#8 | |
Drives: Subaru impreza STI, subaru BRZ
Best advice here ask your tuner. |
#9 |
Drives: 2013 FRS Whiteout
I think based on what my tuner set me to 11.1-11.7, i'm at 8psi. I'm sure there are variables and other things i'm not getting into because i simply dont know but to answer the OP's question.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
#10 | |
Drives: UK GT86
I'll also note here that finding MBT is actually done by changing ignition timing and not the AFR, not that AFR doesn't have an impact. Why do you think that running slightly richer but with more timing makes it more fragile or temperamental? You could argue that running some of the AFR range you specified at high RPM would cause too much heat that could damage components and almost certainly would kill cats. Surely the answer is you want the ideal middle ground, not sticking to an AFR as not all engines or setups are that theoretically perfect
.: Stealth 86 :.
#11 |
There's a torque plateau for ignition timing and air/fuel mixture. So there's a similar process for finding best AFR as there is for best timing. The plateau is broader and flatter for AFR.
You'll note I didn't set hard bounds for MBT. it's something you find empirically. |
| The Following User Says Thank You to burdickjp For This Useful Post: | Shiv@Openflash (02-17-2015) |
#12 |
NASA SpecE30 Racer
He is right about finding the best AFR and MBT, but tuners generally run richer not to make more power, but to provide more protection. Most tuners will target from 11:1 to 12.5:1 for a forced induction application.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#13 |
It's the same thing. They're trying to run more advance by adding fuel. Less fuel and less advance is healthier.
#14 |
Drives: UK GT86
No it's not. Running richer keeps things cooler, which has it's own purpose. I'm not sure how you equate running hotter is healthier?? Less fuel AND less ignition advance = hot EGTs, which over a length of time isn't likely to be good for valves or exhaust components.
It might be worth noting that the OEM tunes this car richer than you suggest, would you consider that unhealthy?
.: Stealth 86 :.
| 50$ at target don't know what to get | 1GiantTurtle | Off-Topic Lounge [WARNING: NO POLITICS] | 47 | 01-11-2015 12:42 AM |
| Idle Speed Target A-F | acj47 | Software Tuning | 0 | 12-09-2014 11:52 AM |
| FRS rc car @target $20 | mush | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 08-22-2014 01:38 PM |
| Free credit monitoring from Target | torqdork | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 01-14-2014 02:11 PM |
| Edmunds target launch | 1660 | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 08-18-2011 04:56 PM |
