Old 02-13-2015, 12:25 AM   #1
b rawr z
b rawr z's Avatar
Drives: 2014 BRZ, 2008 Impreza
Inside rub on full lock
I was wondering if I can do anything other than spacers so I don't rub when I make a u turn. Lol
Current setup:
ST coilovers
17x9 +45
245/40
b rawr z is offline   Reply With Quote
Old 02-13-2015, 12:45 AM   #2
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
You're rubbing even with coilovers? I wonder if it's the tie rod?
smg1138 is offline   Reply With Quote
Old 02-13-2015, 12:53 AM   #3
b rawr z
b rawr z's Avatar
Maybe. Its only when I turn it all the way. Any way I can fix it if it's the tie rod?
Old 02-13-2015, 10:58 AM   #4
smg1138
smg1138's Avatar
I'm actually not sure. I'm kind of in the same situation right now. I have 17x9 +45 wheels and am hearing what sounds like metal on metal rubbing at full lock when turned to the left. I'm still on stock suspension though.
Old 02-13-2015, 11:28 AM   #5
b rawr z
b rawr z's Avatar
Yea it sounds like that. Either left or right and I'm lowered by like 2
Old 02-13-2015, 11:33 AM   #6
vroom4
http://www.maximalperformance.com/5m...ts-Kit-BRZ-FRS
You can select only the front, and with no lug nuts to drop the price significantly.
vroom4 is offline   Reply With Quote
Old 02-13-2015, 11:49 AM   #7
b rawr z
b rawr z's Avatar
I was hoping some other alternative lol
Old 02-13-2015, 12:19 PM   #8
vroom4
It involves a 6 pack of natty light and a sheet of plywood.
Old 02-13-2015, 12:22 PM   #9
b rawr z
b rawr z's Avatar
Lol :p
Old 02-13-2015, 01:09 PM   #10
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
pretty sure spacers or beating on whatever is rubbing is the only way to get around not rubbing.
Or using a 17x8 +45
The Following User Says Thank You to continuecrushing For This Useful Post:
b rawr z (02-13-2015)
Clunk on full lock left turn yomny Issues | Warranty | Recalls / TSB 5 11-17-2014 09:27 AM
FINAL RESULTS: Taking Full Blown Stage 1 To The MAX! @Pure Automotive (Dyno Inside!) Pure Automotive Forced Induction 57 03-28-2013 12:41 AM
Inside Line Full Test of the FRS KaliKev Scion FR-S / Toyota 86 GT86 General Forum 4 04-25-2012 02:16 AM
Inside Line - BRZ Full Test Review IntenseDVDA BRZ First-Gen (2012+) — General Topics 323 03-30-2012 12:05 PM
