Old 02-12-2015, 11:40 AM   #141
tennisfreak
Drives: 2018 BMW M240i
Originally Posted by airjonny View Post
It's right in the middle and more than just 1k. I can't drive it like I stole it everyday.
Originally Posted by Tromatic View Post
LOL. The dip is 1k wide. How hard is it to drive outside it? And it is there just to piss people off, as well.
ETA: You can get the software to edit and flash your ECU for exactly zero bucks.
If they were serious about keeping this car in the lineup, they would let you mix and match and custom order your car. Not sure I'd pay 35K for an FR-S, though. When Scion does a RBR (Rocket Bozo Release) we will know the car is dead.
It's really not that hard.
The dip is the killer thing more than overall power when it comes down to it and there are real everyday situations where its not easy to avoid the dip but it becomes a problem.
I had one today.
Rush hour traffic two highways merge together and one entry ramp on far right side that is also an exit ramp. The exit is about 600 feet after the 3 merge together.
I am on left highway merging into the main highway. Traffic crawls there at about 10mph.
The far right lane which is the entry/exit lane is practically empty and the cars that are in it are doing 40-50mph.
I have to go from far left to far right because I need to take that exit.
So I am in the 10mph traffic moving across lanes needing to get in that exit lane in less than 600 feet.
Once I get in the most right lane next to the exit lane I am still doing 10 mph because of traffic.
Now I have to time my entry to the next lane perfect because those cars are going 40-50mph.
Lowest gear I can go into is second.
Well there is the f_cking dip and I am flooring the sh!t out of my car to get up to speed fast. It takes way too long to get out of that dip and up to speed.
The Following User Says Thank You to tennisfreak For This Useful Post:
Bristecom (03-16-2015)
Old 02-12-2015, 12:02 PM   #142
torqdork
torqdork's Avatar
Drives: RV-7
Originally Posted by nikitopo View Post
I suspect "style Cb" is a marketing and customer satisfaction test before they go formally into the 2nd generation. I suspect 2nd generation (if it'll exist) will resemble somehow this special edition. Don't expect too many changes or a major redesign of the platform. They'll just try to go into a broader market by converting the car to a bit more "premium" image.
We know a refresh is coming next model year and a Gen. II after that. How much different it'll be will fuel dozens of threads between now and then. Looking back, the changes between generations of their last boutique model, MR2, were major. Only the drivetrain layout remained the same. I'm hoping for big things while they keep the fundamentals like light weight, low cost and f/r intact.
torqdork is offline   Reply With Quote
Old 02-12-2015, 12:47 PM   #143
raven1231
We know this how ?
Old 02-12-2015, 02:11 PM   #144
torqdork
torqdork's Avatar
Drives: RV-7
Statements from Toyota/Scion execs linked on this forum.
Old 02-12-2015, 02:25 PM   #145
sofrsnsokleen
GEARS!!???
sofrsnsokleen's Avatar
Drives: raven black 2013 scion fr-s
Location: the southeast side of san antonio, where the players play!
I don't see a difference in the "regular" updates.
I do like the CB though, reminds me of classic british roadsters/Aston Martins. When I first got my fr-s I thought a nice billet grill would look cool.
sofrsnsokleen is offline   Reply With Quote
The Following 2 Users Say Thank You to sofrsnsokleen For This Useful Post:
Choco (02-14-2015), strat61caster (02-12-2015)
Old 02-12-2015, 02:31 PM   #146
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
-anecdote-
Dude, slow down and double clutch into first, slowing down from 10 mph to 5 mph (I've gotten into first at 10 mph, 5 mph is cake) isn't going to get you rear ended and you'll be creating space to get a run at it, flooring it from first to second up to 50 mph should take like 5-6 seconds.
And since you know the commute so well you could just shift into first a couple hundred feet beforehand when the traffic stops (I'll bet that it happens more often than not).
Planning yo, that's the fun bit of this car for most of us. You can't break bones with a scapel but you can still kill with it.
You could also feather the clutch from 10 mph up to 25-30 keeping the revs up to stay in the powerband, but people bitch about replacing clutches sooner than every 200k miles for some reason...
Old 02-12-2015, 10:55 PM   #147
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Change ur transmission oil first lol on stock fluid the fastest I can shift it in 1st is 6 mile dead. Once I change the trans fluid I can go into 1st no problem at all under normal driving condition.
Old 02-12-2015, 11:34 PM   #148
wbradley
Sarcastic SOB
wbradley's Avatar
FYI, Cyberstork is a company in Japan that markets alternate gauge face designs. They are basically a film that can be installed in place of stock gauge facing. They would have supplied the special gauge face design for the Toyota Cb package. Low volume models will use outsourced parts.
Old 02-13-2015, 12:47 AM   #149
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
I had one today.
At 10mph in 2nd gear, your engine is revving at 1229RPM assuming stock gearing, tires, etc in a 6MT FR-S. Diesels are about the only vehicles that accelerate quickly from 1300RPM.
Quentin is offline   Reply With Quote
The Following User Says Thank You to Quentin For This Useful Post:
strat61caster (02-13-2015)
Old 02-13-2015, 01:06 AM   #150
tehwegz
Drives: Coming Soon
or electric vehicles. Which are eerie to drive at first. Ford CMax, Chevy Volt make like 300lb-ft instantly.
tehwegz is offline   Reply With Quote
Old 02-13-2015, 02:34 AM   #151
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Can I say this is second gen? Or mid face lift
hanabie is offline   Reply With Quote
Old 02-13-2015, 02:42 AM   #152
2JZ-GTE
What license?!
2JZ-GTE's Avatar
Drives: 2015 Scion FR-S
I think the fender triple LED looks cool BUT THATS IT ...
2JZ-GTE is offline   Reply With Quote
Old 02-13-2015, 03:46 AM   #153
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
A preparation for 2nd generation. They did it before. They presented the 1st generation a year before its production as a prototype and they said that this is almost what they'll give us.
Old 02-13-2015, 06:46 AM   #154
Neither, it is a special edition that we may not even get here. No announcement from Scion North America yet which would sort of say we aren't.
raven1231 (02-13-2015)
Auto Art Toyota GT86 "Limited" RHD iketiak Miscellaneous 0 11-04-2013 05:53 PM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Toyota GT86 fails "moose" test JoeBoxer Scion FR-S / Toyota 86 GT86 General Forum 4 10-25-2012 07:58 PM
Designing the Toyota GT86 - 4 Part Feature by Toyota Design Chief, "Dezi" Nagaya Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 26 03-19-2012 01:37 AM
FHI Press Release 16th/12 "SUBARU BRZ CONCEPT - STI" ft86cbx BRZ First-Gen (2012+) — General Topics 2 11-16-2011 11:59 AM
