#603 | |
Hit the road and I'm gone
2290 (lbs)/155 (hp) = 14.8 lbs per 1 hp 2360 (lbs)/155 (hp) = 15.4 lbs per 1 hp As a reminder, the FR-S PTW ratio is: 2753 (lbs)/200 (hp) = 13.8 lbs per 1 hp Of course, we will have to wait for the true curb weight to be made available before a precise number can be provided.
Slip, slidin' away.
#604 |
The Fail Boat
Drives: CWP S.B.
With spec on ND if the gear selection is as good as NC it will be ahead of 86 on tech track cuz our torque dip....
#605 | |
So elite I'm 1338
Drives: WRB Subaru BRZ
I don't think the 3.5-5k torque dip is going to be a huge issue around the track. It will have an impact, but keeping the car above 5k rpm on the track isn't difficult in the hands of a good driver. On an autoX course on the other hand...
-Jack Burton |
#606 | ||
Drives: 2013 DZE/01 (sold for MX5 ND1)
The ND will make less power, but it'll have a significantly wider power band. That combined with its lower weight should make it about as fast as the FT86. A bunch of hypothetical benchracing: Miata Assumptions: Code:
Rollout 0
Shift time 0.2
Efficiency 0.85
Launch 4000
Cd NC: 0.34
ND: 0.33
Area NC: 2.140
ND: 2.135
Tires 2L models: 205/45R17
1.5L: 195/50R16
Gearing 2L models: 3.76 2.27 1.65 1.26 1 0.84 / 4.1
1.5L: 3.82 2.26 1.64 1.18 1 0.79 / 4.1
Mass (kg): NC2: 1227 (with driver)
ND2L: 1127 or 1158 (est with driver)
ND1.5L: 1086 or 1109 (est with driver)
Code:
car kg hp lbf*ft shift 0-60 1/4 NC2L 1227 167 140 7500 7.28 15.57 NC2L 1227 167 140 7200 7.34 15.63 ND2L 1158 155 148 7000 7.18 15.49 ND2L 1158 155 148 6800 7.20 15.51 ND2L 1127 155 148 7000 7.13 15.43 ND2L 1127 155 148 6800 7.15 15.46 ND1.5L 1109 129 111 7500 7.81 16.06 ND1.5L 1086 129 111 7500 7.74 16.00 FT86 Assumptions: Code:
Rollout 0
Shift time 0.2
Launch 5000
Cd BRZL: .28
FRS: .29
Area 1.97
Tires 215/45R17
Gearing 3.626 2.188 1.541 1.213 1 0.767 / 4.1
Mass (kg): BRZL: 1348 (with driver)
FRS: 1340 (with driver)
Code:
car 0-60 1/4 BRZL 6.92 15.31 FRS 6.91 15.31 Different testers get different times, and we've seen both the Miata NC2 the FT86 do 0-60 in the low 6s and the 1/4 mile in high 14s. But going by the specifications (and a lot of educated guesses) and using the same formulas, the ND should be only one or two tenths slower. It'll be interesting to see how it does in the real world. Many think the NC2 is slightly underrated, which the spreadsheet results support (looking at its on-paper vs real-world performance compared to the FT86). If the ND is underrated, it could match or even beat the FT86. Not sure if serious.
#607 | ||
ND > NC2 = FT86 But your second statement clearly shows: FT86 > ND > NC2 I don't really care either way and until someone actually tests the Miata, this is all just useless conjecture, but just thought I'd point out why others might not be following your logic. FWIW I agree with you that just looking at peak HP and curb weight is over-simplistic. Torque under the curve and gearing matter, as well as drivetrain losses, aero, etc.
2022 BRZ Build 2013 FR-S Build |
#608 |
So elite I'm 1338
I can't wait for a real test too. Everything I read has the top speed of 115 mph :P
-Jack Burton |
#609 |
Drives: 16 CBS WRX Limited
[ame="https://www.youtube.com/watch?v=XqsX1Obm29A"]Devil May Cry 4 Special Edition Teaser - YouTube[/ame]
#610 |
OK, you've lost me completely. What does this have to do with the thread? Or for that matter, either the Miata or the FR-S???
Slip, slidin' away.
#611 |
#612 | |||||
Now, consider that in the real world, it's: FT86 ~ NC2. In the quarter mile (again, going by specs/guesses), the FT86 has a slight advantage over the ND, which has a slight advantage over the NC2. In the real world, the FT86 and NC2 are very close. Which brings us to: Quote:
I look forward to the test drive.
#613 |
Drives: Low and fast
When it comes to making fun engines... Honda > Toyota
The fa20 is too boring |
#614 |
Well its a subi engine anyway
#616 | |
Drives: 2018 BMW M240i
Well Miata fans looks like there might be a 200(or more)hp version of the car after all.
| The Following User Says Thank You to tennisfreak For This Useful Post: | DAEMANO (03-16-2015) |
| WTB [FL]: Mazda Miata MX-5 03-05 and 06-08, manual transmission | SteelReign | Cars for Sale/Trade | 5 | 06-22-2015 03:01 PM |
| 2016 mazda miata (MX5) reveal 9 PM EST | Ernie L | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-03-2014 09:41 PM |
| FS: Supercharged 1992 Mazda Miata *$4000 OBO* | BRZZZZZZZZZZ | Canada Classifieds | 5 | 08-18-2014 05:44 PM |
| The Mazda 2 trully the FWD Miata NA! | Tbomb 25 | Other Vehicles & General Automotive Discussions | 24 | 01-14-2013 10:30 AM |
