#29 |
I always get a chuckle when you guys post a pic and say "it rained today guess I have to wash it again"!
#30 | |
#31 |
Sleeper
Drives: WRB_BRZ
So, got into the car to drive to the dealer an hour after the wrecker left. Started it, put it in gear and bam - it won't move again(frustrated to the peaks at this point). This time I gathered some courage(from this thread) and rocked it even harder than before(I honestly didn't like doing that
), the clicks became squeaks and tire started to spin. Backed it up and drove straight to dealer 20miles away. They inspected it, spinned it and came back with the expected response "No issues, you're good to go". They also tell me that I should've left it on the flat-bed, so they could replicate the issue but since I drove it to them, they cannot replicate it to find out the cause. I bought their BS(maybe true) and came back home. Ultimately convincing myself that it could be the "frozen to the ground" issue like you suggested. But trust me, it felt much more serious than that to me.
#32 |
Drives: 2010 Scion xD
Next time ask them if you can leave it there cause it does it after sitting for a while.
#33 |
Drives: 2013 Subaru BRZ
Sounds like a potential brake issue from your earlier post (right after the flat bed let it back down). Possible that the 20 miles drive changed whatever was happening and the dealership really couldn't find anything.
Build Thread:
http://www.ft86club.com/forums/showthread.php?t=43355 |
#34 |
Build Thread:
#35 |
Drives: 2017 BRZ
FWIW, twice I've had the rear brakes frozen (hand-brake not used in the garage) after sitting for a while (weeks+) in the garage. Possibly the front, come to think of it. Both times, on the trip home prior to parking, the weather was kind enough to slather the car in snow and slush and who knows what ugly concoction as a result of the crews spewing countermeasures around the roads to deal with the weather.
It pops loose with a bang (the one time I almost went into the edge of the garage door! I pull in so I can't pull straight out so my wife has more room, since she drives regularly and I do not...) It emits a horrid screeching noise for a little bit. Clears up after a bit of a drive, and no troubles. The fact the car was pushing straight is why I wonder if I had the fronts freeze up too. I'm in Chicago... alley access (or lack of access, what with the ice lump now parked in front of my spot... guess I'm not driving any time soon! Yes, the battery is on a tender...) I should add, I also had a similar issue on my Neons when they were parked for a little while. Rear discs stuck to pads - I assume rust filled the gap between pads and disc to cause the issue - at least, that's how it looked. The first time I had an issue it was the e-brake, which is when I learned not to park with it! I had to do a full rebuild. |
| Anything happening around Madison WI | jybrd | Great Lakes | 110 | 05-08-2015 01:34 PM |
| Anything happening in PDX this weekend? | edocura | Northwest | 5 | 08-21-2013 11:15 PM |
| What's Happening this Weekend? (Nov 1st-4th) | TyperRspec789 | Mid-Atlantic | 27 | 11-03-2012 12:11 AM |
| well, its finally happening... | carbonBLUE | Scion FR-S / Toyota 86 GT86 General Forum | 46 | 10-16-2012 08:39 AM |
| any UT happening? | Celica00 | Southwest | 6 | 09-11-2012 11:03 AM |
