Old 02-06-2015, 04:11 PM   #1401
AVOturboworld
I am currently running our intake system for the turbo models on my personal turbocharged fr-s. We will be releasing that in the very near future.
Old 02-06-2015, 04:16 PM   #1402
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
Is the same intake Japan is running in their BRZ?
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
Old 02-06-2015, 04:17 PM   #1403
AVOturboworld
Yes, I'm running that together with the larger intercooler. A new fuel pump upgrade (a major one...) is coming from Japan that we will be testing with e85 on the whole setup.
Old 02-06-2015, 05:00 PM   #1404
Draco_PR23
Fiebru
Draco_PR23's Avatar
Looking forward to it, I want to upgrade a few things but we don't have e85
Current Cars:
Old 02-07-2015, 04:34 PM   #1405
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Originally Posted by Musickmixxer90 View Post
the perrin Cai doesn't give you any fitment problems with the pulleys? idk why, but for some reason I worte that it had that problem when i was doing research on different intakes. maybe I just read somethign wrong
No issues with mine, but you will have to fab up a simple bracket to hold the intake in place. The bracket will mount to the front cross member, under the bumper.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 02-08-2015, 08:56 AM   #1406
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Has there been any word yet on the upgraded turbo? Seems like
forever ago, but still no pricing or option to order on the avo site.
gdrider77 is offline   Reply With Quote
Old 02-20-2015, 06:32 PM   #1407
kbogarto
Drives: 2013 BRZ limited WRB
The oil line that goes into the top of my turbo leaks oil. Not a lot but enough I can smell the oil burning off the turbo at red lights. I have tried tightening it but it feels pretty tight already. My question is how tight is that bolt designed to be. Am I in danger of damaging the fitting if I really put some force into it. I guess my other option is removing it and putting Teflon tape or something on it. Suggestions?
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
Old 02-20-2015, 08:44 PM   #1408
M1K3
M1K3's Avatar
Drives: vrooom...
I used high temp thread sealant:
M1K3 is offline   Reply With Quote
Old 02-20-2015, 11:35 PM   #1409
robr
Drives: 2013 FRS, with boost by ATS Racing
Do NOT use Teflon tape on any part of the oil feed line. Use a liquid sealant like pictured above if you feel the need.
But, the supplied fitting is ><just too long for the block and bottoms out before it crushes the crush washer. You'll want to pick up a fresh pair (two, 2) of crush washers, pretty sure 1/2" is the size you want...pull yours and match it up best you can. I suggest two new ones, but I can almost guaranty that the one installed right now has no sign of use so you might be able to get away with reusing it. But they are so cheap I wouldn't bother. Without replacing the restrictor with a slightly shorter one, the double crush washer method is seemingly the best solution I've found so far.
robr is offline   Reply With Quote
Old 02-21-2015, 05:25 AM   #1410
kbogarto
Awesome, thanks for the advice I'll do that.
Old 03-04-2015, 02:06 PM   #1411
toast
Drives: 14 BSP Edelbrock BRZ
Originally Posted by AVOturboworld View Post
The breather tank is designed to catch the majority of the fumes, but if you are doing extended 120mph runs, there is probably so much oily fumes going through there that a bit of the oil is going to make it past.
I'm a few pages behind, but how do oil vapors make it outside of the charge pipes like shown Flasher's picture?
toast is offline   Reply With Quote
Old 03-04-2015, 02:39 PM   #1412
AVOturboworld
He didn't have a breather tank system, and was doing extended high-rpm driving on the autobahn. Likely the vacuum of the intake pulled a bit of oil up the vent line off the oil reservoir, and that's is where the oil came from. We always will heavily suggest a breather system for any type of extended high rpm driving, whether autobahn or the track, for this reason.
Old 03-04-2015, 02:57 PM   #1413
toast
I guess I don't understand - the vent line is connected to the intake to use that vacuum to pull in vapors and burn them off? If that is the case the oil should be inside the pipes. What is spitting it to the outside?
Old 03-04-2015, 03:13 PM   #1414
AVOturboworld
The vent line is connected to the inlet pipe via a simple barbed straight fitting (since it's only under vacuum, never pressurized). Oil likely seeped at the fitting and blew upwards onto the pipe - doing 220km/h will do that.
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
