Old 02-01-2015, 09:39 AM   #1793
SilverlightPony
SilverlightPony's Avatar
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
Originally Posted by Prog View Post
So...I'm having a dumb issue that I can't figure out. How do I set my own wallpaper with the wallpaper option in settings? I put some pictures on the unit, but I don't know what folder they need to go in.
Image storage location shouldn't matter much, if at all. As long as you can browse to it.
http://google.about.com/od/socialtoo...-Wallpaper.htm
SilverlightPony is offline   Reply With Quote
Old 02-01-2015, 05:44 PM   #1794
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Well, I'm dumb. I thought there was some sort of special process with this "CarDroid" version of Android. I got it all set now.
Prog is offline   Reply With Quote
Old 02-01-2015, 08:43 PM   #1795
SilverlightPony
This isn't CarDroid or whatever Google's specialized automotive version is called. This is straight-up Android, with a few tweaks (of assorted levels of sensibility) by Innotrends/Ca-Fi.
Old 02-02-2015, 12:28 AM   #1796
Prog
Prog's Avatar
I know it's not Android Auto (and I really hope Google will let us install that on this unit...), I just thought this highly customized version didn't work quite like real Android when it came to stuff like that. Pretty sure I saw it referenced as CarDroid somewhere... but anyway, thanks. I guess I was tired of sitting in my car for hours yesterday and didn't try hard enough.
Old 02-03-2015, 01:17 AM   #1797
Simok
Drives: 2013 FRS
So I took my car back to the installer and he fix the power antenna lead and amp lead. My door speakers are working. However, now I have like a buzzing/static on my back passenger side speaker only. Its volume dosent change with the radio volume either it stays the same if its all the way up.or all the way down.
I took it back to the installer and he checked his wiring and said it was all good. Then said most aftermarket units produce some feedback and I.could buy a "silencer" which might fix it.
Just wondering if anyone else had this problem or if this solution sounds right? Cause I have never heard of a silencer nor have I ever had noticeable feedback on any aftermarket unit I have ever used.
Simok is offline   Reply With Quote
Old 02-03-2015, 10:32 AM   #1798
V3rtigo
Drives: 2006 S2000
They sell ground loop eliminators which would remove the buzz if you had an rca cable between the head unit and an amplifier. Those can take a little out of the high range of the sound spectrum though. It also may be some defect in the unit itself or just a poor installation job.
V3rtigo is offline   Reply With Quote
Old 02-03-2015, 11:16 PM   #1799
raqe
Drives: 2013 FRS
It looks like there is a new firmware update.
http://ca-fi.com/store/index.php?rou...formation_id=7
Update notes:
*3 Change log January 07 2015:
  • Fixed duplicated app icon on the app page
  • Third party app icon does not show up on the app page
  • Music playback from SD/USB fluency enhancement
  • WIFI hot spot memory
  • Optimized the brightness
  • Add larger screen compatibility
raqe is offline   Reply With Quote
Old 02-03-2015, 11:58 PM   #1800
DC2R
Drives: 2014 Scion FR-S
Update notes:
Was about to post this. Anyone up for rooting it?
DC2R is offline   Reply With Quote
Old 02-04-2015, 01:46 AM   #1801
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Mobile hotspot, usually. Either a stand-alone unit or by enabling hotspot mode on your cellphone. Either way, there's a subscription cost for it.
Not with T-mobile....
Deathalo is offline   Reply With Quote
Old 02-05-2015, 06:23 AM   #1802
born2lose
Drives: Toyota GT86
ok, internal mic is definitely crappy, completely useless. has anyone tried installing an aftermarket one? I'm a bit dissapointed, have read on a different forum: Does not have external mic or mic jack (can be added by special request).
born2lose is offline   Reply With Quote
Old 02-05-2015, 08:00 AM   #1803
Foobar
SLO NO MO
Foobar's Avatar
Maybe try a USB mic? Anyone give that a shot yet?
Old 02-08-2015, 07:23 PM   #1804
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
Yea, half the time no one can hear me when I'm on the phone. I'm thinking about getting a bluetooth mic and routing it to where the OEM mic is. I believe there is DIY on this forum for this.
Pwolf is offline   Reply With Quote
Old 02-09-2015, 05:49 AM   #1805
E1c
Drives: GT 86
I asked Ca-Fi whether its possible to use an USB mic:
- Hi, no it is not.
E1c is offline   Reply With Quote
Old 02-09-2015, 11:57 PM   #1806
Pwolf
Pwolf's Avatar
What about adding a mic adapter to the HU (opening it, doing a little soldering)? Someone said you can request it with your order?
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 07:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 04:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 05:58 AM
