Old 01-30-2015, 03:29 PM   #1443
CSG Mike
CSG Mike's Avatar
Originally Posted by M23 View Post
@CSG... what's your current full header back exhaust setup? Anything stock still? Stock catback?
Tomei EL header, Tomei OP, Tomei FP, stock catback.
Gonna warn you it sounds like complete ASS on cold startup because the catback is not designed to muffle that kind of flow.
Old 01-30-2015, 03:42 PM   #1444
M23
Drives: 86
Yes...I'm sure that catless setup + oem catback would be raspy as all heck, lol.
Planning to finally get a catback? If, yes, which? I wonder which is the quietest, classiest sounding, but still lightweight (ie: not a dual tip with huge full muffler)
M23 is offline   Reply With Quote
Old 01-30-2015, 03:49 PM   #1445
CSG Mike
CSG Mike's Avatar
We are but we haven't found one that we like (in terms of sound)...
Old 01-30-2015, 04:04 PM   #1446
Firestorm_86
Drives: FRS
I would suggest the HKS Legamax. It's tips are gigantic, so if you can get some normal sized ones welded on, I'd bet you'd have some good sound.
Firestorm_86 is offline   Reply With Quote
Old 01-30-2015, 04:44 PM   #1447
CSG Mike
CSG Mike's Avatar
We tested one; it was too loud for us. We have a lot of Nazi police officers around here, and we also need to be able to test stealthily.
Old 01-30-2015, 04:59 PM   #1448
sw20kosh
Drives: 2013 Black FR-S
What about a Q300 or a Perrin
Old 01-30-2015, 05:07 PM   #1449
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Some Jackson Racing dyno charts to review the thought of FlexFuel.
First dyno chart up for baseline comparison:
Blue Lines - Delicious Tuning Flash & Go Tune (91 oct)
Red Lines - Jackson Racing CARB Tune (91 oct)
Green Lines - Completely Stock Scion FRS (91 oct)
Second dyno chart up for FlexFuel review:
Red Lines - Delicious Tuning Flash & Go Plus FlexFuel Tune (E85)
This is definitely a killer package on and off the street. The power increases across the board with ethanol on the Jackson Kit really make this a blast to drive.
To answer some questions we have been asked a few times about FlexFuel, and in the simplest explanation of how it all works.
With our FlexFuel BlueTooth Hardware kit on your vehicle AND our Flash & Go Software Tune upgraded for FlexFuel you will be able to make all the power ethanol provides when filling up with E85. And you will also be able to fill up on 91 octane whenever you want, maybe where ethanol may not be available while driving.
There is no need to switch between maps, no need to reflash your vehicles ECU, no need to do anything except drive. Literally you pull up to the fuel station, pump in Ethanol or 91 or some combination and drive off, our system does the rest.
Cheers,
William Knose
Old 01-30-2015, 05:14 PM   #1450
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
hnnngggggg
I need to stay out of this thread
Old 01-30-2015, 05:32 PM   #1451
CSG Mike
CSG Mike's Avatar
Both too loud. We need a LARGE muffler, preferably without packing and just baffling.
We got something coming we're excited about
Old 01-30-2015, 05:44 PM   #1452
sw20kosh
Or custom make one. Put a big muffler/resonator in the mid-pipe too. Preferably offset inlet and/or outlet.
That's what I did and I pass 90 db sound check at MRLS with 3" exhaust.
Old 01-30-2015, 06:50 PM   #1453
Calum
That Guy
Drives: 2013 asphalt FRS MT
^^ That.
Old 01-30-2015, 06:52 PM   #1454
Calum
That Guy
Cheers,
William Knose
I take it that's all factory exhaust?
Old 01-30-2015, 07:11 PM   #1455
DeliciousTuning
Yes sir.
Old 01-30-2015, 07:53 PM   #1456
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Yes sir.
Very nice!
Flex fuel "Bluetooth" kit?? Hmmm... Need to research more...
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
